nixx Posted June 13, 2024 Posted June 13, 2024 BDCOM(tm) P3600-08E Software, Version 10.1.0G Build 126776 ниже настройки, которые относятся к агрегации: Скрытый текст interface GigaEthernet0/6 description --Uplink-agg1-- aggregator-group 1 mode lacp switchport trunk vlan-allowed 1122 switchport trunk vlan-untagged 1122 switchport mode trunk switchport pvid 1122 storm-control broadcast threshold 500 storm-control multicast threshold 500 no storm-control unicast threshold ! interface GigaEthernet0/7 description --Uplink-agg2-- aggregator-group 1 mode lacp switchport trunk vlan-allowed 1122 switchport trunk vlan-untagged 1122 switchport mode trunk switchport pvid 1122 storm-control broadcast threshold 500 storm-control multicast threshold 500 no storm-control unicast threshold ! interface Port-aggregator1 description --Uplink-Agg-- switchport trunk vlan-allowed 1122 switchport trunk vlan-untagged 1122 switchport mode trunk switchport pvid 1122 после ребута получаем, что по gi0/6 бегает трафик, а gi0/7 скучает с поднятым линком вот в таком состоянии: Скрытый текст #show inter gi 0/7 GigaEthernet0/7 is up, line protocol is up(LinkAggregateFailed) protocolstatus upTimes 1, downTimes 0, last transition 2000-1-1 0:1:30 Ifindex is 39, unique port number is 7 Description: --Uplink-agg2-- Hardware is Giga-FX-SFP, address is 0055.b1f6.7f3f (bia 0055.b1f6.7f3f) MTU 1600 bytes, BW 1000000 kbit, DLY 10 usec Encapsulation ARPA Auto-Duplex(Full), 1000Mb/s, Flow-Control Off Transceiver Info: SFP,LC,1310nm,1000BASE-X,LOS:no SM 20KM DDM:YES,Vend:Modultech,PN:SFP-G-WDM35-20LC SerialNum:LT2305021999,Date:2023-05-08 DDM info: TX power:-4.54 dBm, RX power:-4.80 dBm SFP temperature:48.00 C,supply voltage :3.24V,Bias Current.:19.20mA DDM Thresholds: Low-Alarm Low-Warning High-Warning High-Alarm TX power(dBm): -10.00 -9.00 -2.00 -1.00 RX power(dBm): -30.00 -26.99 -3.00 -2.00 SFP temperature(C): -10 -5 75 85 Supply voltage(v): 3.00 3.10 3.50 3.60 Bias Current(mA): 1.00 1.50 65.00 70.00 5 minutes input rate 35 bits/sec, 0 packets/sec 5 minutes output rate 1115 bits/sec, 1 packets/sec Real time input rate 0%, 0 bits/sec, 0 packets/sec Real time output rate 0%, 1245 bits/sec, 1 packets/sec peak input rate 408 bits/sec, Jan 1 00:01:31 peak input rate 0 packets/sec, peak output rate 1936 bits/sec, Jun 12 10:54:54 peak output rate 1 packets/sec, Jun 12 04:25:28 Received 5235 packets, 670080 bytes 0 broadcasts, 5235 multicasts, 0 ucasts 0 discard, 0 error, 0 PAUSE 0 align, 0 FCS, 0 symbol 0 jabber, 0 oversize, 0 undersize 0 carriersense, 0 collision, 0 fragment 0 L3 packets, 0 discards, 0 Header errors Transmitted 149626 packets, 20122556 bytes 0 broadcasts, 149626 multicasts, 0 ucasts 0 discard, 0 error, 0 PAUSE 0 sqettest, 0 deferred, 0 oversize 0 single, 0 multiple, 0 excessive, 0 late 0 L3 forwards #show aggregator-group detail Aggregator-group detail information ----------------------------------- Group: 1 Speed: 1000 interval: 30 AggregatedCount: 1 LastAggregated: 01-01 00:01:32 LastDetached: ------------------------------------------------------ System ID : 32768 0055.B1F6.7F38 Partner : 32768 D4D7.48BD.7100 Group ID : 32768 0055.B1F6.7F3E state : lineUp Max Ports : 8 ports : 2 ------------------------------------------------------ Flags: U - Port line status Up. D - Port line status Down. F - lacp abled(FullDuplex Mode). A - port Aggregated in Group. State: a - LACP is Running In Active Mode. p - LACP Passive Mode l - LACP Use LongTimeOut. s - LACP synchronization. d - LACP use default setting. e - LACP Expired. Port: g0/7 Status: Up Individual Aggregator-group : 1 Mode : Lacp Lacp infomation Actor |Partner Port Flags State Pri |Port Pri State System g0/7 UF alg 0 |274 32768ags 32768-D4D7.48BD.7100 RX SM: Current PT SM: FastPeridic SL SM: ready_N ready FALSE FALSE =>Unselected Mx SM: Detached Tx SM: NTT Count Interval(ms) FALSE 1 290 Received LACP Packets: 5235 Sent LACP Packets: 144813 Records: Aggregated Detached Counter 0 Port: g0/6 Status: Up Aggregated Aggregator-group : 1 Mode : Lacp Lacp infomation Actor |Partner Port Flags State Pri |Port Pri State System g0/6 UFA algs 0 |261 32768algs 32768-D4D7.48BD.7100 RX SM: Current PT SM: SlowPeridic SL SM: ready_N ready TRUE TRUE =>Selected Mx SM: Aggregated Tx SM: NTT Count Interval(ms) FALSE 1 19230 Received LACP Packets: 5222 Sent LACP Packets: 4833 Records: Aggregated 01-01 00:01:32 Detached Counter 1 shutdown / no shutdown порту 0/7 решили проблему, но с чего такая фигня? ребутил я только эту железку, на той стороне оборудование было живо и не ребутилось (на той стороне стоит циска, не наша, доступа нет). агрегацию портов только подняли неделю назад, это был первый ребут с момента включения. можно, конечно, еще поребутить для гарантии повторяемости ситуации, но днем некрасиво, а ночью спать хочется ) Вставить ник Quote
