npv Posted June 6, 2024 Posted June 6, 2024 Добрый день. Досталась в наследство cisco as5350 уже настроенная и перестал работать е1. Кто сможет подсказать, что проверить? Я правильно понимаю, что проблема в физике(кабель, порт, настройки принимающей стороны)? AS5350#show controllers e1 3/2 brief E1 3/2 is up. Applique type is Channelized E1 - balanced Description: No alarms detected. alarm-trigger is not set Version info of slot 3: HW: 256, PLD Rev: 1 Framer Version: 0x8 Manufacture Cookie Info: EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x05, Board Hardware Version 1.0, Item Number 73-5267-01, Board Revision E0, Serial Number JAE061804TT, PLD/ISP Version <unset>, Manufacture Date 4-May-2002. Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line. Data in current interval (725 seconds elapsed): 0 Line Code Violations, 0 Path Code Violations 0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins 0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs Total Data (last 12 15 minute intervals): 2024937 Line Code Violations, 25252 Path Code Violations, 118 Slip Secs, 1147 Fr Loss Secs, 78 Line Err Secs, 0 Degraded Mins, 47 Errored Secs, 0 Bursty Err Secs, 30 Severely Err Secs, 1155 Unavail Secs show dialplan number 555680 Macro Exp.: 555680 VoiceEncapPeer555680 peer type = voice, information type = voice, description = `', tag = 555680, destination-pattern = `555680$', answer-address = `', preference=0, CLID Restriction = None CLID Network Number = `' CLID Second Number sent CLID Override RDNIS = disabled, source carrier-id = `', target carrier-id = `', source trunk-group-label = `', target trunk-group-label = `', numbering Type = `unknown' group = 555680, Admin state is up, Operation state is up, Outbound state is down, incoming called-number = `555680$', connections/maximum = 0/unlimited, DTMF Relay = disabled, URI classes: Destination = huntstop = disabled, in bound application associated: 'DEFAULT' out bound application associated: '' dnis-map = permission :both incoming COR list:maximum capability outgoing COR list:minimum requirement Translation profile (Incoming): Translation profile (Outgoing): incoming call blocking: translation-profile = `' disconnect-cause = `no-service' advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4 type = pots, prefix = `', forward-digits all session-target = `', voice-port = `3/2:D', direct-inward-dial = enabled, digit_strip = enabled, register E.164 number with H323 GK and/or SIP Registrar = TRUE fax rate = system, payload size = 20 bytes supported-language = '' Time elapsed since last clearing of voice call statistics never Connect Time = 0, Charged Units = 0, Successful Calls = 0, Failed Calls = 13, Incomplete Calls = 1 Accepted Calls = 0, Refused Calls = 0, Last Disconnect Cause is "29 ", Last Disconnect Text is "temporary failure (41)", Last Setup Time = 1044293. Matched: 555680 Digits: 7 show dial-peer voice 555680 VoiceEncapPeer555680 peer type = voice, information type = voice, description = `', tag = 555680, destination-pattern = `555680$', answer-address = `', preference=0, CLID Restriction = None CLID Network Number = `' CLID Second Number sent CLID Override RDNIS = disabled, source carrier-id = `', target carrier-id = `', source trunk-group-label = `', target trunk-group-label = `', numbering Type = `unknown' group = 555680, Admin state is up, Operation state is up, Outbound state is down, incoming called-number = `555680$', connections/maximum = 0/unlimited, DTMF Relay = disabled, URI classes: Destination = huntstop = disabled, in bound application associated: 'DEFAULT' out bound application associated: '' dnis-map = permission :both incoming COR list:maximum capability outgoing COR list:minimum requirement Translation profile (Incoming): Translation profile (Outgoing): incoming call blocking: translation-profile = `' disconnect-cause = `no-service' advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4 type = pots, prefix = `', forward-digits all session-target = `', voice-port = `3/2:D', direct-inward-dial = enabled, digit_strip = enabled, register E.164 number with H323 GK and/or SIP Registrar = TRUE fax rate = system, payload size = 20 bytes supported-language = '' Time elapsed since last clearing of voice call statistics never Connect Time = 0, Charged Units = 0, Successful Calls = 0, Failed Calls = 13, Incomplete Calls = 1 Accepted Calls = 0, Refused Calls = 0, Last Disconnect Cause is "29 ", Last Disconnect Text is "temporary failure (41)", Last Setup Time = 1044293. Вставить ник Quote
jffulcrum Posted June 6, 2024 Posted June 6, 2024 С другой стороны кодирование поменяли, может ресетнули свою железку и встал по дефолту AMI3 или B8ZS Вставить ник Quote
npv Posted June 7, 2024 Author Posted June 7, 2024 Спасибо. Проблема оказалось с портом на другой стороне. Перенесли конфиги на другой порт и ошибки прошли Вставить ник Quote
