ready Posted April 1, 2006 Posted April 1, 2006 Здраствуйте, не могли бы вы подсказать ... если конечно компитентны в этом вопросе: FreeBSD 5.4 не подключается к интернету через PPPoE... rc.conf: ppp_enable="YES" ppp_mode="ddial" ppp_nat="YES" ppp_profile="name_of_service_provider" ifconfig_de0="inet 213.154.220.46 netmask 255.255.255.252" #defaultrouter="192.168.0.99" gateway_enable="YES" hostname="myserver" ifconfig_rl0="inet 192.168.0.98 netmask 255.255.255.0" network_interfaces="lo0 rl0 de0" defaultrouter="213.124.220.46" inetd_enable="YES" named_enable="YES" named_flags="-u bind -g bind" linux_enable="YES" usbd_enable="YES" nfs_server_enable="NO" nfs_client_enable="NO" firewall_enable="YES" firewall_type="Open" ppp.conf: default: set log Phase tun command # you can add more detailed logging if you wish set ifaddr 10.0.0.1/0 10.0.0.2/0 name_of_service_provider: set device PPPoE: de0 # replace xl1 with your Ethernet device set authname unlimited set authkey ***** set dial set login add default HISADDR pppoe.conf: default: set log Phase tun command # you can add more detailed logging if you wish set ifaddr 10.0.0.1/0 10.0.0.2/0 name_of_service_provider: set device PPPoE:de0 # replace xl1 with your Ethernet device set authname unlimited set authkey ******* set dial set login add default HISADDR /var/log/ppp.log: Apr 1 10:53:35 alfaclub ppp[198]: tun0: Warning: : Cannot send a netgraph mess> Apr 1 10:53:35 alfaclub ppp[198]: tun0: Warning: deflink: Device (PPPoE:) must> Apr 1 10:53:35 alfaclub ppp[198]: tun0: Warning: deflink: Device (de0) must be> Apr 1 10:53:35 alfaclub ppp[198]: tun0: Phase: deflink: Enter pause (30) for r> Apr 1 10:54:05 alfaclub ppp[198]: tun0: Warning: : Cannot send a netgraph mess> Apr 1 10:54:05 alfaclub ppp[198]: tun0: Warning: deflink: Device (PPPoE:) must> Apr 1 10:54:05 alfaclub ppp[198]: tun0: Warning: deflink: Device (de0) must be> Apr 1 10:54:05 alfaclub ppp[198]: tun0: Phase: deflink: Enter pause (30) for r> Apr 1 10:54:35 alfaclub ppp[198]: tun0: Warning: : Cannot send a netgraph mess> Apr 1 10:54:35 alfaclub ppp[198]: tun0: Warning: deflink: Device (PPPoE:) must> Apr 1 10:54:35 alfaclub ppp[198]: tun0: Warning: deflink: Device (de0) must be> Apr 1 10:54:35 alfaclub ppp[198]: tun0: Phase: deflink: Enter pause (30) for r> Apr 1 10:55:05 alfaclub ppp[198]: tun0: Warning: : Cannot send a netgraph mess> Apr 1 10:55:05 alfaclub ppp[198]: tun0: Warning: deflink: Device (PPPoE:) must> Apr 1 10:55:05 alfaclub ppp[198]: tun0: Warning: deflink: Device (de0) must be> Apr 1 10:55:05 alfaclub ppp[198]: tun0: Phase: deflink: Enter pause (30) for r> Device (PPPoE:) must begin with a '/', a '!' or contain at l> Warning: deflink: Device (de0) must begin with a '/', a '!' or contain at leas> Phase: deflink: Enter pause (30) for redialing. Warning: : Cannot send a netgraph message: Invalid argument Warning: deflink: Device (PPPoE:) must begin with a '/', a '!' or contain at l> Warning: deflink: Device (de0) must begin with a '/', a '!' or contain at leas> Phase: deflink: Enter pause (30) for redialing. Warning: : Cannot send a netgraph message: Invalid argument Warning: deflink: Device (PPPoE:) must begin with a '/', a '!' or contain at l> Warning: deflink: Device (de0) must begin with a '/', a '!' or contain at leas> Phase: deflink: Enter pause (30) for redialing. Phase: deflink: Enter pause (30) for redialing. Warning: : Cannot send a netgraph message: Invalid argument Warning: deflink: Device (PPPoE:) must begin with a '/', a '!' or contain at least one ':' Warning: deflink: Device (de0) must begin with a '/', a '!' or contain at leas one ': Phase: deflink: Enter pause (30) for redialing. немогу понять в чем дело Вставить ник Quote
balamutang Posted April 1, 2006 Posted April 1, 2006 в ppp.conf пробелы надо поставить во всех строках (в начале строки) кроме строк "default:" и "name_of_service_provider: " Вставить ник Quote
Saenara Posted April 3, 2006 Posted April 3, 2006 set device PPPoE:de0 И убрать пробел между PPPoE: и de0 Вставить ник Quote
