Rtl8186 Firmware Всем, кто пишет под RTL8186
Я именно так и делаю, но тем не меее не работает.
Share this post
Link to post
Share on other sites
drobyshev
смотри dmesg тогда... может чего интересного там напишет...
Share this post
Link to post
Что именно смотреть?
вот что у меня выдало на эту команду:
# dmesg
Linux version 2.4.18-MIPS (root@Source-services) (gcc version 3.3.3) #702 Thu Se p 28 10:51:18 EEST 2006
early printk enabled
Determined physical RAM map:
memory: 00800000 @ 00000000 (usable)
Initial ramdisk at: 0x80239000 (22522 bytes)
On node 0 totalpages: 2048
zone(0): 2048 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/ram console=0 ramdisk_start=0
179.40 BogoMIPS
Memory: 5572k/8192k available (2059k kernel code, 2620k reserved, 164k data, 60k init, 0k highmem)
Dentry-cache hash table entries: 1024 (order: 1, 8192 bytes)
Inode-cache hash table entries: 512 (order: 0, 4096 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 2048 (order: 1, 8192 bytes)
check_wait... unavailable.
POSIX conformance testing by UNIFIX
bogomips: Initialized.
user_watchdog: Initialized.
led0: Initialized.
led1: Initialized.
sysmem: Initialized.
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
JFFS2 version 2.1. © 2001 Red Hat, Inc., designed by Axis Communications AB.
pty: 256 Unix98 ptys configured
Serial driver version 6.02 (2003-03-12) with no serial options enabled
ttyS00 at 0x00c3 (irq = 3) is a rtl_uart1
state->flags=00000000
block: 64 slots per queue, batch=16
RAMDISK driver initialized: 16 RAM disks of 512K size 1024 blocksize
NET4: Frame Diverter 0.52
divert: not allocating divert_blk for non-ethernet device teql0
loop: loaded (max 8 devices)
RTL8185 driver version 1.9 (2006-03-31)
divert: allocating divert_blk for wlan0
divert: allocating divert_blk for wlan0-wds0
divert: allocating divert_blk for wlan0-wds1
divert: allocating divert_blk for wlan0-wds2
divert: allocating divert_blk for wlan0-wds3
divert: allocating divert_blk for wlan0-wds4
divert: allocating divert_blk for wlan0-wds5
divert: allocating divert_blk for wlan0-wds6
divert: allocating divert_blk for wlan0-wds7
divert: allocating divert_blk for wlan0-vxd
RealTek E-Flash System Driver. © 2002 RealTek Corp.
Found 1 x 2M Byte AMD AM29LV160DB at 0xbe000000
=> Scan for ROOT signature in flash from pos=0x000000
Founded at pos=0x0DFFF4
Checksumm ok for 0x0E1000 bytes calced=0x808C, stored=0x808C) Checksumm OK . Use as ROOT partition (/dev/mtd2)
Reallocate pertition for root size=0x0E1000 bytes
Creating 3 MTD partitions on "DiskOnChip Millennium":
0x00000000-0x000e0000 : "boot+cfg+linux"
0x000e0000-0x001d0000 : "root fs"
0x001d0000-0x00200000 : "jffs2 fs"
8186NIC Ethernet driver v0.0.2 (Jan 30, 2004)
divert: allocating divert_blk for eth0
eth0: RTL8186-NIC at 0xbd200000, 00:01:02:03:04:05, IRQ 4
divert: allocating divert_blk for eth1
eth1: RTL8186-NIC at 0xbd300000, 04:05:06:07:08:09, IRQ 5
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 512 bind 1024)
IPv4 over IPv4 tunneling driver
divert: not allocating divert_blk for non-ethernet device tunl0
GRE over IPv4 tunneling driver
divert: not allocating divert_blk for non-ethernet device gre0
ip_conntrack version 2.1 (64 buckets, 512 max) - 360 bytes per conntrack
ip_tables: © 2000-2002 Netfilter core team
ipt_time loading
ipt_recent v0.2.3: Stephen Frost <sfrost@snowman.net>. http://snowman.net/proje cts/ipt_recent/
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NET4: Ethernet Bridge 008 for NET4.0
RAMDISK: Compressed image found at block 0
Freeing initrd memory: 21k freed
VFS: Mounted root (ext2 filesystem).
Freeing unused kernel memory: 60k freed
mount /proc file system ok!
mount /dev/mtdblock1 file system ok!
divert: allocating divert_blk for br0
device eth0 entered promiscuous mode
eth0:phy is 8201
device wlan0 entered promiscuous mode
wlan0: A wireless client is associated - 00:0F:3D:61:6A:31
br0: port 2(wlan0) entering listening state
br0: port 1(eth0) entering listening state
wlan0: A wireless client is associated - 00:14:2A:AB:73:3E
wlan0: A wireless client is associated - 00:18:F3:A6:CD:3C
wlan0: A expired STA is resumed - 00:14:2A:AB:73:3E
br0: received tcn bpdu on port 2(wlan0)
br0: topology change detected, propagating
br0: port 2(wlan0) entering learning state
br0: port 1(eth0) entering learning state
br0: port 2(wlan0) entering forwarding state
br0: port 1(eth0) entering forwarding state
eth0: rx work limit reached
wlan0: A STA is expired - 00:18:F3:A6:CD:3C
wlan0: A STA is expired - 00:0F:3D:61:6A:31
wlan0: A STA is expired - 00:14:2A:AB:73:3E
wlan0: A wireless client is associated - 00:0D:88:8B:90:12
wlan0: A wireless client is disassociated - 00:0D:88:8B:90:12
wlan0: A expired STA is resumed - 00:0F:3D:61:6A:31
wlan0: A wireless client is associated - 00:11:95:E9:3A:98
wlan0: A wireless client is deauthenticated - 00:11:95:E9:3A:98
wlan0: A wireless client is associated - 00:19:5B:54:24:37
wlan0: A STA is expired - 00:19:5B:54:24:37
Share this post
Link to post
Вот эти строки нас интересуют. Скорее всего это и есть Д-линк 700, который не цепляется за точку :) его мак есть в мак-фильтре. В общем его не может приассоциировать, точнее идентифицировать по списку. Обычно такое сообщение выводится при отказе в соединении по мак-списку или по 802.1х, последний в прошивке не поддерживается... в основной ветке, по-крайней мере.
ЗЫ. неплохо было бы еще посмотреть эту команду на самом клиенте, когда он пытается приконнектится с включенной мак-фильтрацией.
Edited by N.leiten
Share this post
Link to post
Эту команду я запускал с отключенной мак фильтрацией.
Этот клиент 00:11:95:E9:3A:98 чужой и я не знаю с чем он подключился. Именно против таких клиентов и хочу включить фильтрацию.
Вобщем я понял что надо запустить # dmesg на точке доступа, когда включена мак фильтрация, а потом его же запустить на клиенте который не может подключиться.
Вот только непонятно почему клиент использующий точку 1000АР+ с родной д-линковской прошивкой, тоже не может подключиться.
Share this post
Link to post
Возникла следующая проблема... Есть 5460АР. У неё вылетел контроллер Lan1 порта. При включении сильно грелся и точка через минут 5 вырубалась(может какая защита). Я его выпаял. Заработала... Но както странно... работает гдето часов 10 и виснет но уже не вырубается. Думаю мож поставить на неё Wive. Но как ? Ведь Lan1 ушёл :(( Можно както обойти ?
Share this post
Link to post
Здраствуйте!
Подскажите, всетаки шъется чем нибудь Planet WAP-4035 кроме заводской прошивки? А то девайс вроде не плохой, а функционала прошивки не хватает...
Share this post
Link to post
sn355
Можно залить последнюю Wive. Но не рекомендую, там сейчас всплыли старые проблемы при работе с флешью, на днях выложу исправленную версию.
XNeo
Скорее всего никак... надо перепаять контроллер со второго на первый порт.
drobyshev
Эта проблема не у тебя одного, просто мне не удавалось ее изучить лично.
Edited by N.leiten
Share this post
Link to post
sn355
пробовал уже - ревижн а не выходит из виса как я понимаю после прошивки, а ревижн б похоже вообще не принимается - консоли нет, сужу по диоду WLAN ...
кстати, киньте плиз ссылкой, куда в 4035 прицепить консоль, желательно с фоткой...
Edited by sn355
Share this post
Link to post
sn355
Если не сложно - глянь сколько там памяти... Есть проблема с 16 метровыми платами. То есть в ревизии Аесли 16 метров, то прошивка не может загрузится.
Share this post
Link to post
2 корпуса A2V64S40DTP 5059LAOC - не знаю что за жуки, но по ходу все же 8 метровые...
Share this post
Link to post
to N.leiten
Есть пожелание, а может это фича такая - поправить в wive busybox чтобы у него ls -l стандартный вывод делал, а то winscp в него зайти не может - не нравится ему такой вид, когда символические ссылки сразу рядом раскрываются...
Share this post
Link to post
Здравствуйте.
Я недавно наткнулся на этот форум, очень много полезной инфы.
Появился такой вопрос. У меня есть вот такой зверь DI-524 от длинка.
Можно его тоже как клиента запустить? Сильно надо. Или никак?
Share this post
Link to post
drobyshev
Потому вопрос для всех кто использует Ж700 с прошивкой Wive в качестве точки доступа. Кто как решает проблему защиты сети от нелегалов ? Я так понимаю нужна или Мак фильтрация (у меня она работает коряво), или шифрование, или думаю может сменить SSID и настроить точку так чтоб он не транслировался в эфир (насколько я понимаю это защити только от ламеров и не более). Как всетаки защитить сеть?
Edited by drobyshev
Share this post
Link to post
drobyshev
На мой взгляд кроме как использование шифрования WPA2 с мак-фильтрацией в комбинации с IPtables.
Либо опять же шифрование WPA2 и внутри VPN тунель.
На данный момент вроде другой эффективной альтернативы нет.
Share this post
Link to post
Можно по виланам растасовать точки/клиенты... Это след. этап работы :)
Share this post
Link to post
Здравствуйте. Подскажите пожалуйта такой момент, есть wap 4033 прошитая wive 0.5.9 пытаюсь
настроить в режим client infrastructure так это называлось в стандартной прошивке planet.
Я перешил wap 4033 в wive настройки wive можно посмотреть ниже. С этоми конфигами связь есть и не плохая. Но проблема в том, что когда запускаешь в проводной части сети програмку NetLook, она повидимому рассылает достаточно много широковещательных пакетов, что приводит к зависанию точьки с прошивкой wive 0.5.9. Причем зависание происходит в разные моменты. Что конкретно виснет я понять пока не могу, она просто становится не доступна по SSH и не пингуется.
Вопрос: может я что-то не правильно настроил?
может надо добавить wds, но зачем?
подскажите кто знает. Спасибо.
конфиги вот такие
network
BRIDGE_START=yes
#When auto_bridge is "yes" then init.script makes bridge itself
# when aut_bridge is "no" then init.script start /etc/network/bridge
AUTO_BRIDGE=no
# Just to make faster load, when not needed.
STP_ENABLE=yes
FD_TIMER=0
GCINT_TIMER=0
BR0_IPADDR=10.10.3.26/24
IPV4_FORWARD_ENABLE=yes
START_IPTABLES=yes
VLAN_START=yes
ETH0_ENABLED=yes
ETH0_FORCEIP=no
ETH0_IN_BR0=yes
ETH0_IPADDR=10.10.3.26/24
ETH0_MACADDR=00106c576976
ETH1_ENABLED=no
ETH1_FORCEIP=no
ETH1_IN_BR0=no
ETH1_IPADDR=192.168.1.50/24
ETH1_MACADDR=00006c576977
WLAN_ENABLED=yes
WLAN_FORCEIP=no
WLAN_IN_BR0=yes
WLAN_IPADDR=10.10.3.26/24
WLAN_MACADDR=00106c576976
#Be carefull. There're many Hardware-specific mibs
WLAN_USE_UNCHECKED_MIBS=no
general
#!/bin/sh
#Set ESSID of wirelless Infrastructure Network
iwpriv wlan0 set_mib ssid="souther_WIFI"
#Uncomment and Set prior bssid to connect
# iwpriv wlan0 set_mib bssid2join=0016b6526bd7
iwpriv wlan0 set_mib hiddenAP=0
#Set Mode: 8 - Client;16 - AP; 32 - AdHoc
iwpriv wlan0 set_mib opmode=8
#Set Regulatory Domain:
# "3" - 13 channels available, "6" - 14 channels available.
# FCC=1;IC=2;ETSI=3;SPAIN=4;FRANCE=5;MKK=6
iwpriv wlan0 set_mib regdomain=6
#Set Channel here
iwpriv wlan0 set_mib channel=6
#Set Initial Gain: in range 0-7
# It seems to be sens but maybe not. Just test
iwpriv wlan0 set_mib initialGain=4
#Set TransmitPower for CCK(802.11b) modulation
# Please Change it in variable
CCKPOWER=12
iwpriv wlan0 set_mib TxPowerCCK=`ader $CCKPOWER 14`
#iwpriv wlan0 set_mib TxPowerCCK=1010101010101010101010101010
#Set TransmitPower for OFDM(802.11g) modulation
OFDMPOWER=12
iwpriv wlan0 set_mib TxPowerOFDM=`ader $OFDMPOWER 162`
#iwpriv wlan0 set_mib TxPowerOFDM=10101010101010101010101010101010101010101010101010101010101010101010
101010101010101010101010101010101010101010101010101010101010101010101010101010101
010101010101010101010101010101010101010101010101010101010101010101010101010101010
0101010101010
iwpriv wlan0 set_mib basicrates=4095
iwpriv wlan0 set_mib oprates=4095
iwpriv wlan0 set_mib fixrate=4095
iwpriv wlan0 set_mib autorate=1
iwpriv wlan0 set_mib band=3
iwpriv wlan0 set_mib bcnint=50
#RTS/CTS Threshold
iwpriv wlan0 set_mib rtsthres=2346
iwpriv wlan0 set_mib fragthres=2346
iwpriv wlan0 set_mib expired_time=50
iwpriv wlan0 set_mib dtimperiod=1
iwpriv wlan0 set_mib show_hidden_bss=1
iwpriv wlan0 set_mib preamble=0
iwpriv wlan0 set_mib shortretry=6
iwpriv wlan0 set_mib longretry=6
iwpriv wlan0 set_mib Diversity=0
iwpriv wlan0 set_mib DefaultAnt=0
iwpriv wlan0 set_mib RFChipID=7
iwpriv wlan0 set_mib led_type=0
#G protection
iwpriv wlan0 set_mib disable_protection=0
#For bridged mode set this parameters
# Nat2.5 is technology to change the source MAC to MAC of Wlan-interface
# be carefull it says disabled, so make inverse in your decision
iwpriv wlan0 set_mib nat25_disable=0
# Macclone says all about itself. It just takes MAC of ETHERNET device on other end of line
# and take it for Wlan-interface. be carefull if this enabled it must be one device on a line.
iwpriv wlan0 set_mib macclone_enable=0
iwpriv wlan0 set_mib dhcp_bcst_disable=1
#Block packets between clients connected
# 0 - disable; 1 - block relay;2 - block relay but passup
iwpriv wlan0 set_mib block_relay=0
iwpriv wlan0 set_mib wifi_specific=0
Share this post
Link to post
al_k
Проблема скорее всего неизлечима, т.к. нехватает мощности процессора на пересылку большого количества пакетов, вот она и залипает. Я попробую что-то сотворить, но пока ничего не могу обещать конкретного.
Попробуйте зажать скорость на беспроводном интерфейсе до 18-24мбит, может полегчает.
И не по теме - у вас ошибка в конфигурации:
тут нужно не список, а одно значение указывать... Т.к. здесь указывается четко скорость на которой работать, списки указываются при автовыборе. Но т.к. этот параметр отключен (у вас авторейт включен), то это нестрашно.
Share this post
Link to post
дело в том что на автомате у меня уже точка работает на скорости 18-24,
то есть если я правильно понимаю что ограничев скорость (допустим до 9-12)в без проводном сегменте,
я тем самым объясню ядру, что надо убивать часть пакетов из проводного сегмента? или я что то не понимаю. тоеть в моем случае виснет ядро а не мост?
а по поводу
я уже просто экспериментировал
но в документации не совсем ясно написано что у этого параметра может быть только одна "1"
и теперь вопрос про память sdram, ее получается и добавлять то как-то без смысленно
а за ответ спасибо!
Share this post
Link to post
al_k
Проблема в драйверах от риалтека, которые в бинарном виде поставляются. Т.к. я в ассемблере полный новичек (чтоб не сказать грубо :) ), то с драйвером приходится играться на уровне предоставленных возможностей. Так вот проблема в том, что при указании в списке всех скоростей для автоподбора драйвер пытается задрать скорость повыше. Не совсем так, конечно, насколько мне позволяет наблюдательность в дизассемблированном виде я заметил табличку соответствия rssi и скорости. так вот уважаемые китаезы поступили очень банально - привязали уровень сигнала к допустимой скорости. То есть для офисного варианта это работать будет, но для наших уссловий, когда есть еще параметры шума и еще куча физики тут приходится зажимать всё ручками. Очень редко получается повысить скорость/стабильность при зажимании выше 24Мбит. Самые стабильные варианты до 18Мбит. Поэтому вручную рекомендую установить эти скорости (поставьте в oprates, basicrates значение 255 или 511 для 18 и 24мбит соответственно, экспериментируйте)
насчет зависаний. Попробуйте зажать скорость - это может исправить ситуацию. В нашем случае это разгрузит систему от лишнего переключения по скорости, производительность возрастет и зависания удастся избежать. В общем экспериментируйте. :)
насчет памяти - легко догадаться, что без экспериментов не обойтись :) имея в руках исходники вполне спокойно можно установить значения в ядре и на 32метра памяти и на 16 :) Думаю след. прошивку буду собирать и по этому критерию.
ЗЫ. насчет зависания - сталкивался только с одним таким случаем. У клиента вирус на Висте - заражает сетевую подсистему таким образом, что там посылает около 1000 днс-запросов удп-шных за 2.5секунды, точка после 20-25 минут такой напряженки уходила в даун, причем точка на магистрали, а не раздающая...
Share this post
Link to post
В общем-то нормально оно зажимается, во всяком случае например у меня :) зажато на 48-54Mbit и скорость в общем-то ожидаемая - 2.5-2.7Мбайт
А вот висло - это да! Причем действительно, если зажать до 18-24Мбит, то не виснет... Виснет на больших скоростях... Но! Я поднял IP-IP соединение (у меня стоят с двух сторон линка серваки под линухом) и виснуть перестало. Правда нетбиос и всякие виндовые порты (виндовая сетка) у меня порезан, но висло и без них пока не было IP-IP поднято.
Я тут проводил эксперимент, линк на G700 проталкивает через себя до 4000 пакетов в секунду. Размер пакета был 100байт.
Share this post
Link to post
Такая история... была гроза. После грозы 5460 перестала работать. Загружается по индикаторам вроде норм но нету ни пинга ни ВЕБ. Пробовал сбросить, не вышло... Залил туда Wive. Залилось нормально, перезапустилась, стартанула... зашёл телнетом... всё засияло... но... пробую вводить wl scangraph (вроде так) и в списке не вижу ниодной точки (хотя они точно есть). Хотел попробовать обратно прошить оригинальную чтобы кликнуть привычный "Site Survey", удостовериться рабочий или пленый радиомодуль и не выходит... заливаю оригинальную прошивку. Заливается и всё... точка стоит и ждёт завтрашнего дня. Сама не перегружается. Есси вырубаю питание то стартует снова Wive :)
Как уверенно проверить радиомодуль?
Share this post
Link to post
rsst
Насчет скоростей - значит счастливчик :) Насчет эксперимента... Я тоже его проводил и результаты подобные были. Вот только проблема в том, что днс-запросы идут в пакетах размером от 32байт и выше. Может точка просто захлебывается на уровне преамбул. В данном случае преамбула будет превышать размер самих данных и точка не будет успечать формировать пакеты?
Надо подумать о написании ускорителей - типа объединения нескольких пакетов в один фрейм - никто не встречал патчей, чтоб хоть от чего-то отталкиваться, а то самому с нуля писать - еще полгода пройдет и так занят на работе по самые нехочу :)
Share this post
Link to post
С таким ускорителем всякие игрушки лагать будут :( На сколько я знаю есть софтовая реализация подобного ускорителя и именно проблема лагов имеет место быть...
Share this post
Link to post
rsst
ну если дать в руки управление параметрами. Из разряда объединять по времени каждые 50мс/10мс или управляемость по размеру пакета. объединять пакеты размером до 100байт... Суть в управляемости и лагать не будет. Лагает из-за возникающих задержек, а если от них уйти, то будет прикольно :)
Да и возможность включения/октлючения всегда доступна.
Ссылочку не подкинешь случайно?
Edited by N.leiten
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
