megagrizly Posted December 4, 2010 · Report post D-Link G700AP, wive-ng 0.3.18. Хочу настоить wpa2-psk. Подключаюсь телефоном, пароль не подходит. ЧЯДНТ? В конфигах поменял вот что: /etc/network/wifi/general AUTHTYPE=SHARED WPA=yes /etc/wpa.conf #0 – disable, 1 – WEP, 2 – WPA, 4 – WPA2 only, 6 – WPA2 mixed encryption = 4 #“string_value”, 1-32 char ssid = "SOME-WiFi" #0/1 – disable/enable 1x Radius authentication enable1x = 0 #0/1 – disable/enable MAC authentication enableMacAuth = 0 #0/1 – disable/enable none WPA client support when WPA is set supportNonWpaClient = 0 #1 – WEP64, 2 – WEP128 Refer when encryption is set 1 (wep) wepKey = 0 wepGroupKey = "" #1 – Radius, 2 – PSK (pre-shared key) authentication = 2 #1 – TKIP, 2 – AES unicastCipher = 1 wpa2UnicastCipher = 1 #0 – use psk value as key in raw data, 1 – use passphrase algorithm to convert psk value usePassphrase = 1 #“string_value”, if usePassphrase=0 (raw data), it should be 64 hex digits. #If usePassphrase=1, the string length should be >=8 and <=64. psk = "123456789" #Group key re-key time groupRekeyTime = 86400 #UDP Port number of radius server rsPort = 1812 #IP address of radius server (e.g., 192.168.1.1) rsIP = 0.0.0.0 #“string_value”, password of radius server with 31 char in max rsPassword = "" #Max retry number of request packet with radius server rsMaxReq = 3 #Timeout time (in second) of waiting rsp packet of radius rsAWhile = 5 #0/1 – disable/enable accounting radius server accountRsEnabled = 0 #UDP Port number of accounting radius server accountRsPort = 1813 #IP address of accounting radius server accountRsIP = 0.0.0.0 #“string_value”, password of accounting radius server with 31 char in max accountRsPassword = "" #0/1 – disable/enable the feature of statistic update with accounting server accountRsUpdateEnabled = 0 #Update time in seconds accountRsUpdateTime = 60 #Max retry number of request packet with accounting radius server accountRsMaxReq = 3 #Timeout time (in second)of waiting rsp packet of accounting radius server accountRsAWhile = 5 Share this post Link to post Share on other sites
CoolPepper Posted December 4, 2010 (edited) · Report post D-Link G700AP, wive-ng 0.3.18. Хочу настоить wpa2-psk. Подключаюсь телефоном, пароль не подходит. ЧЯДНТ? В конфигах поменял вот что: /etc/network/wifi/general AUTHTYPE=SHARED WPA=yes /etc/wpa.conf #0 – disable, 1 – WEP, 2 – WPA, 4 – WPA2 only, 6 – WPA2 mixed encryption = 4 #”string_value”, 1-32 char ssid = "SOME-WiFi" #0/1 – disable/enable 1x Radius authentication enable1x = 0 #0/1 – disable/enable MAC authentication enableMacAuth = 0 #0/1 – disable/enable none WPA client support when WPA is set supportNonWpaClient = 0 #1 – WEP64, 2 – WEP128 Refer when encryption is set 1 (wep) wepKey = 0 wepGroupKey = "" #1 – Radius, 2 – PSK (pre-shared key) authentication = 2 #1 – TKIP, 2 – AES unicastCipher = 1 wpa2UnicastCipher = 1 #0 – use psk value as key in raw data, 1 – use passphrase algorithm to convert psk value usePassphrase = 1 #”string_value”, if usePassphrase=0 (raw data), it should be 64 hex digits. #If usePassphrase=1, the string length should be >=8 and <=64. psk = "123456789" #Group key re-key time groupRekeyTime = 86400 #UDP Port number of radius server rsPort = 1812 #IP address of radius server (e.g., 192.168.1.1) rsIP = 0.0.0.0 #”string_value”, password of radius server with 31 char in max rsPassword = "" #Max retry number of request packet with radius server rsMaxReq = 3 #Timeout time (in second) of waiting rsp packet of radius rsAWhile = 5 #0/1 – disable/enable accounting radius server accountRsEnabled = 0 #UDP Port number of accounting radius server accountRsPort = 1813 #IP address of accounting radius server accountRsIP = 0.0.0.0 #”string_value”, password of accounting radius server with 31 char in max accountRsPassword = "" #0/1 – disable/enable the feature of statistic update with accounting server accountRsUpdateEnabled = 0 #Update time in seconds accountRsUpdateTime = 60 #Max retry number of request packet with accounting radius server accountRsMaxReq = 3 #Timeout time (in second)of waiting rsp packet of accounting radius server accountRsAWhile = 5 Загрузил Putty зашел в menu\3 и ищешь эти обозначения и меняешь, походу из-за этого! #---------------------------------GENERAL WIRELESS INTERFACE CONFIG-------- #Set Mode: AP/CLIENT/ADHOC RMODE=AP #Set ESSID of wirelless Infrastructure Network ESSID=Non_Hacking --------------------------------------------------------------------------- #---------------------------------------ACCESS OPTIONS--------------------- #802.11 Authentication type OPEN-open system, SHAREDБ-?shared key, AUTO-aut AUTHTYPE=AUTO #Enable/disable access list ACL=no #Allowed macs of client (on one through a blank) ALLOWMACS="001D92C7B5AB 0015AF8BD700 004F6A010719 003005DF2049 0019CB7515A2 #Enable/disable wep WEP=no #WepKey 26 digits for 128bit WEPKEY=11223344556677889910111213 #Enable/disable wpa/wpa2 WPA=yes SSID ssid = "Non_Hacking" Password psk = "77777777" Ну я вообщем не спец в этом деле, но вроде на первый взгляд из-за этого;) P.S. Кто бы мне чутка помог узнать по чему у меня PPPoE когда торрент загружаю или же при многопоточности (вкладок 15 в лисе обновишь и повис)! Edited December 4, 2010 by CoolPepper Share this post Link to post Share on other sites
asdus Posted December 9, 2010 · Report post Есть 2 точки, расстояние 610м, прямая видимость, оптику копануть возможности нет.Стоят 2 точки G700AP. До сего момента на них стояла старенькая wive-ng, один из первых релизов, и две маленьких Яги антенны, спаянных на коленке из медной проволоки. Все работало, хоть и не очень быстро, пара МБит всего. Захотелось бОльшей скорости, было куплено 2 параболических антенны на 27Дб. Поставлено, заодно обновил прошивку на точках до последней (0.3.18 бинарные образы с sf.net). Настроил. Не работает :( Вот основные настройки: /etc/boot /etc/network/interfaces /etc/network/wifi/general /etc/wpa.conf В поиске то есть то нет противоположной точки, чаще всего нет. Могут они друг друга слепить, или дело в настройках? Заранее ОГРОМНО благодарен за Ваши ответы. Спасибо. Можно ссылку на антенны, которые стоят? Конечно, Антенна сегменто-параболическая 27дбОбе стоят в горизонтальной поляризации, расстояние 610м, высоты 20м и 8м, прямая видимость, телескопические облучатели "выдвинуты" на максимум. Когда стоишь у одной антенны рядом, ноутбук видит обе точки. скорее всего не попадают в луч одна другой из-за разницы в высотах. у ноута антенна по сути всенаправленная - он хоть боковой лепесток ловит.можно попробовать немного расфокусировать антенны (вдвинуть облучатели) - луч станет шире. или поюстировать по возвышению. ну и сигнал на передатчике уменьшить понятное дело, так чтобы уровни были примерно -50...-55dBm уровни можно запостить? При указанных в конфигах выше настройках мощности - потери стандартных пингов 83-90%%, rssi вот прямо сейчас 11% -92dBm, при кручении антенн получалось поймать до 46% -70dBm (примерно, точно не помню сколько 46% в децибелах по wive-ng-шному). Связь лучше при этом не становилась.Замечено, что при увеличении мощности передатчиков качество связи улучшается, но недостаточно, чтобы этим можно было решить проблему. Share this post Link to post Share on other sites
trumpy Posted December 11, 2010 · Report post Привет! Может кто-то пожалуйста, компиляции последнего снимка wive-NG (http://wive-ng.git.sourceforge.net/git/gitweb.cgi?p=wive-ng/wive-ng;a=shortlog)? Независимо от того, что я пытаюсь я всегда получаю ошибку во время процесса компиляции. Мне это нужно из-за исправить PPTP плагин автодозвон в сети вниз. Share this post Link to post Share on other sites
KpacaB4uk_6o6 Posted January 9, 2011 · Report post есть вопрос! вобщем сделали с другом сеть..У него инет.точка доступа zyxel p330 w ee, антенна на крыше 7дби. у меня карта длинк dwa 520 и комнатная антенна в окне тоже 7 дби. видимось как бы прямая, т.е. из окна видно крышу его дома(он в пятиэтажке, я в частном доме.). получается что сигнал идет под углом примерно 45градусов.. Что интересно сигнал на приеме у меня 40% у него до 20%..Скорость должна быть 6мегабит. но у меня всего 1!!!! в точке доступа прошивка линуксовая wive ng. Может какие настройки по этому поводу можно перебрать? ps. Антенну на крышу вынести нет возможности. Share this post Link to post Share on other sites
VLADTIMOSHENKO Posted January 10, 2011 · Report post О каком решении идет речь? Я ваабще не понимаю в чем разница ? Share this post Link to post Share on other sites
alecs-art Posted February 1, 2011 · Report post Прошил G700AP 0.3.18, после весьма безобидных настроек при включении перестал поднматься eth0. В логах чисто, в чем может быть проблема? Если сбросить настройки, то поднимается на ура...ищи мои посты с аналогичной проблемой на предыдущих страницах Share this post Link to post Share on other sites
alecs-art Posted February 1, 2011 · Report post P.S.Кто бы мне чутка помог узнать по чему у меня PPPoE когда торрент загружаю или же при многопоточности (вкладок 15 в лисе обновишь и повис)! ты сумбурно написал . как именно отваливается - в логе то не видно - внешние симптомы какие и как лечишь ?(глянь мои посты 2 страницы назад) - попробуй у торрента поставить глобальный максимум соединений типа 10 , на один торрент файл - 2 соединения, Share this post Link to post Share on other sites
w422g Posted February 28, 2011 (edited) · Report post Вот возникла необходимость вкомпилить очень полезную утилитку iftop в wive-ng.Я собрал себе iftop (правда довольно неряшливо), но он работает. Edited May 15, 2011 by w422g Share this post Link to post Share on other sites
w422g Posted March 1, 2011 (edited) · Report post А где лежат конфигурации W422G_v3 / W530G / W532G? Вытащил git://wive-ng.git.sourceforge.net/gitroot/wive-ng/wive-ng-dsl но там только LAN110v2 / LAN410v2 / USBv3. Прошивку таким образом пересобрать довольно затруднительно, т.к. нет нужных настроек. ... Нашел цитату sfstudio "Никаких других wive-ng в природе не существует. Все кроме wive-ng-dsl-2.6 доступны в исходниках в git. dsl-2.6 исходники будут опубликованы когда избавлюсь от проприретарных кусков кода от риалтэка." Теперь всё понятно. Очень жалко, что прошивку не собрать. Edited March 1, 2011 by w422g Share this post Link to post Share on other sites
Jumboman Posted April 6, 2011 (edited) · Report post Доброго времени суток, пытаюсь подключить 64 Мб ММС карточку. Версия прошивки wive-ng 0.3.8. Включил поддержку ММС в конфиге. Подключил так: MMC --- JTAG --- GPIO CLK 5 <---> 1 --> 8 RTL8186 pin 146 DO 7 <---> 3 --> 6 RTL8186 pin 33 DI 2 <---> 5 --> 9 RTL8186 pin 116 CS 1 <---> 7 --> 7 RTL8186 pin 8 GND и VCC перепаял с UART разъёма, на фото ешё не видно. Так как у меня JTAG порт не разведён, то пришлось паять на ноги проца: При загрузке столкнулся с проблемой, в dmesg вижу: mmc: GPIO init mmc: initialising MMC GPIO_SD_CS dir: 1 GPIO_SD_DI dir: 1 GPIO_SD_DO dir: 0 GPIO_SD_CLK dir: 1 mmc: card init 1/2 mmc: card init 2/2 mmc: card init 3/3 Size = 62720, hardsectsize = 512, sectors = 125440 Partition check: mmca:end_request: I/O error, dev 79:00 (mmc), sector 0 end_request: I/O error, dev 79:00 (mmc), sector 2 end_request: I/O error, dev 79:00 (mmc), sector 4 end_request: I/O error, dev 79:00 (mmc), sector 6 end_request: I/O error, dev 79:00 (mmc), sector 0 end_request: I/O error, dev 79:00 (mmc), sector 2 end_request: I/O error, dev 79:00 (mmc), sector 4 end_request: I/O error, dev 79:00 (mmc), sector 6 unable to read partition table Значит размер карточки wive видит, а партицию почему-то не читает. Карточку форматировал в ext2 так: cfdisk /dev/mmcblk0, создал партицию, пометил как тип 83 (Linux), записал изменения. fdisk -l /dev/mmcblk0 выдаёт: /dev/mmcblk0p1 Потом пробовал: mke2fs /dev/mmcblk0 и пробовал: mke2fs /dev/mmcblk0p1 В обоих случаях ошибка таже самая, пробовал на своём лаптопе. Может кард ридер у меня немного глючный так как пробуя в Gparted подготовить карточку лаптоп виснет намертво. Может кто нибуть таки удачно подключал MMC к RTL8186, поделитесь опытoм или пните в нужном направлении, где я накосячил непойму Edited April 6, 2011 by Jumboman Share this post Link to post Share on other sites
dendj Posted May 9, 2011 · Report post у ка во нибудь остались прошивки rtl8186.dgreen.v2.zip ни где ни магу найти их ..веб серверы все по умерли.. ? Share this post Link to post Share on other sites
dennis714 Posted July 6, 2011 · Report post Возможно ли прошить Planet WRT-416? Он тоже на чипе RTL8186. На плате 2 нераспаянных 4х-контактных разъема - это ком-порты или...? Share this post Link to post Share on other sites
g7001 Posted July 6, 2011 · Report post Народ дайте простую вайву.а то все умерло,не отрыть в просторах сети.А винт с ней утонул. Заранее благодарен. Share this post Link to post Share on other sites
ivanmfan Posted July 22, 2011 · Report post Подскажите плиз на wive-ng 3.18 точка G700 постоянно отпадает pppoe [Wive-NG@/]# cat /var/log/ppp-connect-errors Killed Killed pppoe: read (asyncReadFromPPP): Session 5163: Input/output error pppoe: read (asyncReadFromPPP): Session 5375: Input/output error pppoe: read (asyncReadFromPPP): Session 5115: Input/output error pppoe: read (asyncReadFromPPP): Session 5392: Input/output error pppoe: read (asyncReadFromPPP): Session 5348: Input/output error pppoe: read (asyncReadFromPPP): Session 5496: Input/output error Killed Такие сообщения собираются... что может быть? Share this post Link to post Share on other sites
semo163 Posted August 2, 2011 · Report post Подскажите пож. люди добрые... Жил был девайс DAP-1150 (h/w ver A1 f/w ver 1.00, RTL8186)работал в режиме AP долго и счастливо. Но вдруг в один прекрасный (а точнее ужасный) момент перестало работать радио (погас индикатор WI-FI) попытался ресетить кнопкой ресет в итоге девайс потерялся вовсе... Теперь нет возможности даже по ethernet подключиться. При нажатии и удержании кнопки "reset" индикатор питания не риагирует вообще. Есть ли возможность его оживить? Спасибо. https://lh3.googleusercontent.com/-Jlex_FRSSgg/Tjg9tO06SuI/AAAAAAAAAOk/HrAiFlyDcjI/s144/IMG_20110802_220427.jpg Share this post Link to post Share on other sites
AlexeyKL Posted January 12, 2012 · Report post Люди добрые помогите. http://forum.justlan.net/viewtopic.php?f=88&t=1322&p=15201#p15201 Тупанул с моделью роутера ( оказалось, что у меня Acorp WR-G(2.0)- хотел прошить в Zuxel, дошёл до пункта 12 по интрукции (ссылка выше) и нашь роутер "пал смертью храбрых", точнее он жив (он работает- горит POWER и LAN или WAN, смотря через какой порт подключать), но tftp по адресу 192.168.1.6 перестал работать. В ходе выполнения той инструкции получил следующее: Удалил прошивку Acorp, залил установщик Zuxel - теперь мой роут пустой. Помогите пожалуйста с JTAG если можно подробнее как и что распаивать и как шить. (прошу прощения если такой вопрос уже был, просто поймите- не вариант перечитывать 211 страниц данного форума дабы найти нужную информацию). Помогите пожалуйста!!! Share this post Link to post Share on other sites
nik.sh Posted February 2, 2012 · Report post Добрый день.Прошу помощи в востановлении mac адреса точки доступа dap 1150. Была прошита в Conceptronic C54APM.bin. После прошивки заработал всего один режим раздачи интернета от компа,в вебморду так и не зайти.Стандартная прошивка становиться режимы при преключении тумблера срабатывают но также не зайти в веб морду,ни dlinkap не 192.168.0.50. Опять зашиваеш Conceptronic и раздает интернет,mac адрес отображаеться как BSSID 001122334455 в место родного.Очень прошу вас о помощи.Руки прямые,любую схему или програматор смогу спаять. Данные с точки доступа: p/n IAP1150eeu...a1g s/n F3OU184005620 mac id 001E58E7A69B WPS PIN 60872142 H/W Ver A1 F/W Ver 1.00 FCC ID KA2AP1150A1 IC 4216A-AP1150 Данные с материнской платы. 21514P1150A11A1 Share this post Link to post Share on other sites
vadik_che Posted February 23, 2012 · Report post В общем поднял trendnet TEW-432BRP H/W:D1.1R 1 присвоил в комп адрес 192.168.1.151 2 ping 192.168.1.1 - тишина 3 arp -a увидел mac, сравнил его с написаанным на пузе коробочки - совпадает. 4 скачал прошивку по принципу чем свежее тем кузявее. 5 tftp -i 192.168.1.1 PUT TEW432BRP_D1.2R_FW3.10B15_nml.bin Огромное спасибо! Сей девайс успешно оживлен багодаря Вам! Share this post Link to post Share on other sites
Lorence Posted May 25, 2012 (edited) · Report post Доброго всем времени суток! Впервые на вашем форуме, да и вообще ищу альтернативную прошивку на свой роутер впервые.. Вопросы такие: Данные прошивки можно залить на роутер Trendnet TEW432BRP/C H/W D2.1R? на нем так-же стоит чипсет RTL-8186. Есть ли в этих прошивках возможность настройки роутера через Веб-интерфейс или все в терминале делать? И как все это дело заливат ьи ставить? =) Заранее спасибо! Edited May 25, 2012 by Lorence Share this post Link to post Share on other sites
fpopic Posted July 29, 2012 · Report post hello to all Russians & Co. from CROATIA :D I have my AIRLIVE/OVISLINK WL-5470AP RTL8186 Flash: MX 29LV160DBTI-70G (2MB) SDRAM : 2x ISSI IC42S16400F-6TL XA658500W 0923 IC SDRAM 64MBIT 166MHZ 54TSOP (LINK) There says it is 64mb but i think this router has only 16MB RAM ? Board Pic (1600x1200) : http://i45.tinypic.com/2z6uqgh.jpg Can i maybe replace FLASH or SDRAM to incrase some memory and which linux firmware can i put on to it. Share this post Link to post Share on other sites
kuzyara Posted October 1, 2012 · Report post печально что тему никто из спецов не поддерживает :( Share this post Link to post Share on other sites
xorkrus Posted January 18, 2013 · Report post Прошил точку DAP-1160 прошивкой Wive-NG. Настроил сеть между eth1 (PC) и wlan0 (Tablet wifi). Дело за малым - получить интернет на eth0. Собственно если ETH0_USE_DHCP=yes, то роутер не получает ни IP-адреса, ни маршрутов, ни DNS. Прописываю IP, DNS вручную. Вот такой вид настроек сейчас: ETH0_ENABLED=yes ETH0_FORCEIP=yes ETH0_IN_BR0=no ETH0_USE_DHCP=yes ETH0_IPADDR=37.235.176.177 DNS: 192.168.50.50 8.8.8.8 8.8.4.4 Затем маршрут ip ro add default via 37.235.176.0 dev eth0 Маршруты получаются такие: Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.2.0 * 255.255.255.0 U 0 0 0 wlan0 192.168.1.0 * 255.255.255.0 U 0 0 0 eth1 37.235.176.0 * 255.255.248.0 U 0 0 0 eth0 И вроде как все хорошо, но ничего не пингуется. Даже сам шлюз. В логах ничего. Что посоветуете? Share this post Link to post Share on other sites
NewUse Posted January 18, 2013 (edited) · Report post А порты слуайно местами не поменялись? ifconfig что говорит, особенно статус? А сорри, в линуксе нет этой фичи, она бсд-шная, Для линукса: cat /sys/class/net/eth0/carrier cat /sys/class/net/eth1/carrier Edited January 18, 2013 by NewUse Share this post Link to post Share on other sites
xorkrus Posted January 20, 2013 · Report post Какие порты? Каталога /sys/ в прошивке нет вообще. [GATE@/]# ifconfig eth0 Link encap:Ethernet HWaddr 00:1D:7D:A1:6E:2E inet addr:37.235.179.177 Bcast:37.235.183.255 Mask:255.255.248.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:109174 errors:0 dropped:0 overruns:0 frame:0 TX packets:122256 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:55957502 (53.3 MiB) TX bytes:109024623 (103.9 MiB) Interrupt:4 eth1 Link encap:Ethernet HWaddr 04:05:06:07:08:09 inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:179337 errors:0 dropped:0 overruns:0 frame:0 TX packets:59393 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:111274930 (106.1 MiB) TX bytes:11392571 (10.8 MiB) Interrupt:5 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:3692 errors:0 dropped:0 overruns:0 frame:0 TX packets:3692 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:334637 (326.7 KiB) TX bytes:334637 (326.7 KiB) wlan0 Link encap:Ethernet HWaddr 00:E0:4C:81:86:86 inet addr:192.168.2.1 Bcast:192.168.2.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:15843 errors:0 dropped:0 overruns:0 frame:0 TX packets:30474 errors:758 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:200 RX bytes:1688189 (1.6 MiB) TX bytes:43389540 (41.3 MiB) Interrupt:2 [GATE@/]# route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.2.0 * 255.255.255.0 U 0 0 0 wlan0 192.168.1.0 * 255.255.255.0 U 0 0 0 eth1 37.235.176.0 * 255.255.248.0 U 0 0 0 eth0 default 37.235.176.1 0.0.0.0 UG 0 0 0 eth0 Собственно теперь проблема изменилась. Интернет пропадает через 5-7 минут. Т.е. Тупо всё перестает пинговаться. Где теперь искать проблему?) Share this post Link to post Share on other sites
