Rtl8186 Firmware Всем, кто пишет под RTL8186
2 sfstudio: все так же отваливается.
вот настройки соединения:
eth1      Link encap:Ethernet  HWaddr 00:02:A5:44:6F:01
          inet addr:10.9.150.41  Bcast:10.9.159.255  Mask:255.255.224.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:9931 errors:0 dropped:0 overruns:0 frame:0
          TX packets:29 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:505831 (493.9 KiB)  TX bytes:4990 (4.8 KiB)
          Interrupt:5
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
ppp0      Link encap:Point-to-Point Protocol
          inet addr:94.143.56.238  P-t-P:79.98.95.1  Mask:255.255.255.255
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1400  Metric:1
          RX packets:6 errors:0 dropped:0 overruns:0 frame:0
          TX packets:26 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:3
          RX bytes:1444 (1.4 KiB)  TX bytes:4751 (4.6 KiB)
а вот лог:
Jan  1 06:00:19 pppd[181]: Using interface ppp0
Jan  1 06:00:19 pppd[181]: Connect: ppp0 <--> /dev/ttyp0
Jan  1 06:00:19 pptp[184]: anon log[main:pptp.c:314]: The synchronous pptp option is NOT activated
Jan  1 06:00:23 pptp[242]: anon log[ctrlp_disp:pptp_ctrl.c:752]: Received Start Control Connection Reply
Jan  1 06:00:23 pptp[242]: anon log[ctrlp_disp:pptp_ctrl.c:786]: Client connection established.
Jan  1 06:00:24 pptp[242]: anon log[ctrlp_disp:pptp_ctrl.c:871]: Received Outgoing Call Reply.
Jan  1 06:00:24 pptp[242]: anon log[ctrlp_disp:pptp_ctrl.c:910]: Outgoing call established (call ID 0, peer's call ID 26761).
Jan  1 06:00:24 pptp[184]: anon log[decaps_gre:pptp_gre.c:398]: accepting packet 1
Jan  1 06:00:24 pptp[184]: anon log[decaps_gre:pptp_gre.c:398]: accepting packet 2
Jan  1 06:00:24 pptp[184]: anon log[decaps_gre:pptp_gre.c:398]: accepting packet 3
Jan  1 06:00:24 pptp[184]: anon log[decaps_gre:pptp_gre.c:398]: accepting packet 4
Jan  1 06:00:25 pptp[184]: anon log[decaps_gre:pptp_gre.c:398]: accepting packet 5
Jan  1 06:00:25 pptp[184]: anon log[decaps_gre:pptp_gre.c:398]: accepting packet 6
Jan  1 06:00:25 pppd[181]: CHAP authentication succeeded
Jan  1 06:00:25 pptp[184]: anon log[decaps_gre:pptp_gre.c:398]: accepting packet 7
Jan  1 06:00:25 pptp[184]: anon log[decaps_gre:pptp_gre.c:398]: accepting packet 8
Jan  1 06:00:25 pptp[184]: anon log[decaps_gre:pptp_gre.c:398]: accepting packet 9
Jan  1 06:00:25 pppd[181]: local  IP address 94.143.56.238
Jan  1 06:00:25 pppd[181]: remote IP address 79.98.95.1
Jan  1 06:00:35 pptp[184]: anon log[decaps_gre:pptp_gre.c:398]: accepting packet 10
Jan  1 06:00:38 pptp[184]: anon log[decaps_gre:pptp_gre.c:398]: accepting packet 11
Jan  1 06:00:38 pptp[184]: anon log[decaps_gre:pptp_gre.c:398]: accepting packet 12
Jan  1 06:00:38 pptp[242]: anon log[callmgr_main:pptp_callmgr.c:237]: Closing connection (unhandled)
Jan  1 06:00:38 pptp[242]: anon log[call_callback:pptp_callmgr.c:82]: Closing connection (call state)
Jan  1 06:00:38 kernel: Unhandled kernel unaligned access in unaligned.c:emulate_load_store_insn, line 370:
Jan  1 06:00:38 kernel: $0 : 00000000 1000f400 00000000 fffffffe 80bb1980 00000001 00000001 00000003
Jan  1 06:00:38 kernel: $8 : 00000000 0000000a 00000000 80bf1860 2e7d307d 00000000 0000000d 00000000
Jan  1 06:00:38 kernel: $16: 2c7d2c7d 00000001 80bb1980 1000f401 00000001 0000084d 80bb1170 80bb1150
Jan  1 06:00:38 kernel: $24: 00000002 2ab759d0                   80b1c000 80b1ddb0 80b1ddb0 800c0d54
Jan  1 06:00:38 kernel: Hi : 000015f4
Jan  1 06:00:38 kernel: Lo : 00073899
Jan  1 06:00:38 kernel: epc  : 8000af80    Not tainted
Jan  1 06:00:38 kernel: Status: 1000f400
Jan  1 06:00:38 kernel: Cause : 10000010
Jan  1 06:00:38 kernel: Process pptp (pid: 184, stackpage=80b1c000)
Jan  1 06:00:38 kernel: Stack: fffffff8 80134064 00000001 8020d838 80bb1000 80bb0000 80bb1170 00000000
Jan  1 06:00:38 kernel:        0000084d 00000004 800c0d54 80022ed8 802abe00 80bb0000 802abe00 80bb0000
Jan  1 06:00:38 kernel:        802abe00 80bb0000 800d82c8 800d8208 7fff1000 80f66490 80022f78 8013e938
Jan  1 06:00:38 kernel:        0000084d 80bb0000 00000000 7fff1375 80bb1000 800c0f64 80f66490 00000001
Jan  1 06:00:38 kernel:        80d74f90 7fff1000 7fff0b28 0000084d 80bb1000 7fff0b28 00000000 80cb96d0
Jan  1 06:00:38 kernel:        80bb1980 ...
Jan  1 06:00:38 kernel: Call Trace: [<80134064>] [<800c0d54>] [<80022ed8>] [<800d82c8>] [<800d8208>] [<80022f78>]
Jan  1 06:00:38 kernel:  [<8013e938>] [<800c0f64>] [<800bdcac>] [<800bda98>] [<800baf08>] [<8001b844>]
Jan  1 06:00:38 kernel:  [<801290c0>] [<800b80a4>] [<80039e88>] [<8000706c>] [<8000a310>]
Jan  1 06:00:38 kernel: Code: 00000000  12040018  00c08821 <8e04fffc> 00002821  8c820000  00000000  00541024  1040000d
Да, и попробуйте отключить RX_DELAY и BR_SHORTCUT (echo 3 /proc/ethX/eth_flag где X - номер интерфейса), не могу нащупать почему у вас происходят такие чудеса.
поподробнее можно, я пытался записать эти значения в файл типа RX_DELAY=0 но
/proc/ethX/eth_flag имеет свойства только чтение для рута. как менять ?
что на той стороне не знаю , подозреваю линукс , результат от nmap :
PORT     STATE    SERVICE     VERSION
79/tcp   open     tcpwrapped
1720/tcp filtered H.323/Q.931
1723/tcp open     pptp        Cisco Systems, Inc. (Firmware: 4608)
No exact OS matches for host (If you know what OS is running on it, see http://nmap.org/submit/ ).
TCP/IP fingerprint:
OS:SCAN(V=4.75%D=1/13%OT=79%CT=1%CU=35793%PV=N%DS=3%G=Y%TM=496CB173%P=x86_6
OS:4-suse-linux-gnu)SEQ(SP=106%GCD=1%ISR=10D%TI=RD%II=RI%TS=U)SEQ(SP=FF%GCD
OS:=1%ISR=10D%TI=RD%II=RI%TS=U)SEQ(SP=102%GCD=1%ISR=10C%TI=RD%II=RI%TS=U)SE
OS:Q(SP=106%GCD=1%ISR=108%TI=RD%II=RI%TS=U)SEQ(SP=FC%GCD=1%ISR=10D%TI=RD%II
OS:=RI%TS=U)OPS(O1=M5B4%O2=M578%O3=M280%O4=M5B4%O5=M218%O6=M109)WIN(W1=1020
OS:%W2=1020%W3=1020%W4=1020%W5=1020%W6=1020)ECN(R=Y%DF=Y%T=100%W=1020%O=M5B
OS:4%CC=N%Q=)T1(R=Y%DF=Y%T=100%S=O%A=S+%F=AS%RD=0%Q=)T2(R=N)T3(R=Y%DF=Y%T=1
OS:00%W=1020%S=O%A=S+%F=AS%O=M109%RD=0%Q=)T4(R=Y%DF=N%T=100%W=0%S=A%A=Z%F=R
OS:%O=%RD=0%Q=)T5(R=Y%DF=N%T=100%W=0%S=A%A=S+%F=AR%O=%RD=0%Q=)T6(R=Y%DF=N%T
OS:=100%W=0%S=A%A=Z%F=R%O=%RD=0%Q=)T7(R=Y%DF=N%T=100%W=0%S=A%A=S%F=AR%O=%RD
OS:=0%Q=)U1(R=Y%DF=N%T=100%TOS=0%IPL=38%UN=0%RIPL=G%RID=G%RIPCK=G%RUCK=G%RU
OS:L=G%RUD=G)IE(R=Y%DFI=S%T=100%TOSI=Z%CD=S%SI=S%DLI=S)
Network Distance: 3 hops
Service Info: Host: vpn2_7206VXR
Да фирмваревская прошивка 1.4.16 работала стабильно, без сбоев. Огорчало лишь то что управление ограничено WEB, по другому не настроить.
Да часто следует самопроизвольная перезагрузка роутера.
так что все логи поймать не удается.
Изменено пользователем vmn_fs
Поделиться сообщением
Ссылка на сообщение
Поделиться на других сайтах
У меня более нет идей, пока не повторю поправить не выйдет.
echo 3 /proc/eth0/eth_flag и всёёё!!! Написал же специально в виде примера. Не нужно ничего менять и писать, просто выполните echo 3 /proc/eth0/eth_flag и echo 3 /proc/eth1/eth_flag
Написано русским языком что сиська.
Ну вот пока и откатитесь тогда на неё, по крайней мере пока не смогу отловить баг. Он у меня упорно не проявляется.
После такого краша и должен быть ребут.
Ссылка на сообщение
Уважаемые, прошу сильно не пинать, но где можно прочитать про настройку WDS? 138 страниц, к сожалению, не осилил ))
В коментариях menu->general , более для этого ничего не требуется, если этого будет мало, то и тему читать смысла не имеет.
Благодарю за отклик, не без труда, но разобрался и настроил. Расстроило отсутствие каких-либо диагностических сообщений(про WDS) при попытках настройки. Кстати, вот тут есть неплохая статья о настройке WDS, правда, под wive.
Тему почитать стоит в любом случае, ибо тема весьма интересная и нужная ;) Кстати, большой респект всем участвующим в разработке проекта, в особенности тов. sfstudio :-).
И, напоследок, 2 маленьких вопросика:
1) Знаю, WDS канал может работать без шифрования и с WEP. А с WPA?
2) Точка D-Link DWL G700AP. После ввода команды reboot точка зависает, не пингуется лан, не работает беспроводная сеть. Вылечивается после передергивания точки по питанию. Кто-нибудь сталкивался?
Ссылка на сообщение
Что-то конец... Такого ещё не было
login as: root
root@192.168.0.1's password:
::Wive-NG-0.2.9::RTL8186-REALTIME::
Base station firmware version
Mon, 12 Jan 2009 02:43:12 +0600
BusyBox v1.12.1.-wive-ng.sf.net (2009-01-12 02:39:42 OMST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
[Wive-NG@/]# grep pp /var/log/messages
Jan  1 06:00:19 pppd[188]: pppd 2.4.5 started by root, uid 0
Jan  1 06:00:19 pppd[188]: Using interface ppp0
Jan  1 06:00:19 pppd[188]: Connect: ppp0 <--> /dev/ttyp0
Jan  1 06:00:20 pptp[190]: anon log[main:pptp.c:314]: The synchronous pptp option is NOT activated
Jan  1 06:00:33 pptp[217]: anon log[ctrlp_disp:pptp_ctrl.c:752]: Received Start Control Connection Reply
Jan  1 06:00:33 pptp[217]: anon log[ctrlp_disp:pptp_ctrl.c:786]: Client connection established.
Jan  1 06:00:44 pptp[217]: anon log[ctrlp_disp:pptp_ctrl.c:871]: Received Outgoing Call Reply.
Jan  1 06:00:44 pptp[217]: anon log[ctrlp_disp:pptp_ctrl.c:910]: Outgoing call established (call ID 0, peer's call ID 24082).
Jan  1 06:00:45 pppd[188]: CHAP authentication succeeded
Jan  1 06:00:45 pppd[188]: local  IP address 78.106.221.226
Jan  1 06:00:45 pppd[188]: remote IP address 85.21.0.85
Jan  1 06:01:45 pptp[217]: anon log[ctrlp_disp:pptp_ctrl.c:942]: Call disconnect notification received (call id 24082)
Jan  1 06:01:45 pptp[217]: anon log[ctrlp_disp:pptp_ctrl.c:801]: Received Stop Control Connection Request.
Jan  1 06:01:45 pptp[217]: anon log[callmgr_main:pptp_callmgr.c:261]: Closing connection (shutdown)
Jan  1 06:01:45 pptp[217]: anon log[call_callback:pptp_callmgr.c:82]: Closing connection (call state)
Jan  1 06:01:45 pppd[188]: Modem hangup
Jan  1 06:01:45 pppd[188]: Connect time 1.0 minutes.
Jan  1 06:01:45 pppd[188]: Sent 19727088 bytes, received 96 bytes.
Jan  1 06:01:45 pppd[188]: Connection terminated.
[Wive-NG@/]#
Чё это такое? о_О
Я так понял, это входящий приказ... Только почему, не пойму...
Ссылка на сообщение
А что по поводу L2TP? Могу ли я его сам добавить? Или можно найти в SDK?
Ссылка на сообщение
Только что протестировал на старых версиях, при mtu 580 mru 580 и обязательно включенном TCPMSS бегает и не отваливается. Нужно смотреть в эту сторону.
ЗЫ. Буду тестировать на время, когда ж отвалится.
ЗЫЫ. Практическим путем получил значение mtu/mru 1037, при котором pptp себя чувствует относительно нормально (не отваливалось сразу же при нагрузке).
Изменено пользователем N.leiten
Ссылка на сообщение
Толку тестировать на старых версиях?
В SDK уже есть l2tp, нужно отредактировать config в корне SDK отключив напрпимер OLSR и включив l2tpd. Примеров конфигов l2tpd как таковых нет, т.е. придётся писать самим. У меня так и не дошли руки написать стартовые скрипты и проучее для l2tp. Сделаете - вам скажут спасибо .
Да, сверху прилетел LCP пакет в котором "сказано" в принудительном порядке завершить сессию.
Никаких сообщений не предусмотрено в модуле радиоинтерфейса и повлиять на это увы пока никак.
Опять костыли.
Не за что. А читать нужно внимательно то что в каментах написано, и если не помогло читать документацию из SDK.
Легко и непринуждённо.
Бывает иногда, причину отследить пока не удалось. Благо болеют этим только Г700.
Ссылка на сообщение
Попробуйте reboot -f и результат в студию пожалуйста.
Увы, то же самое (( Видно, придется с этим смириться ((
Ссылка на сообщение
народ, подскажите как в wiveng сохранять и загружать на точку конфиги ?
Ссылка на сообщение
Я, наверное, неправильно сформулировал вопрос:
Шифрование самого WDS канала может осуществляться с помощью WPA? В настройках ничего по этому повод не видел :-)
Ссылка на сообщение
Да, без проблем, всё там есть в примерах. В некоторых случаях возможно придётся поправить вызов демона auth
Ссылка на сообщение
Уважаемые,
впаял я в DWL-G700 другой RAM, тоже 16-бит только 256 мбит в надежде заапгрейдить его на 16 мбайт; к сожалению видит по-прежнему всего-лишь 8 мбайт; нужно ли какие-то байтики поменять в bootloaderе?
dmesg
Workaround for:Linux version 2.4.18.5-wive-ng.sf.net (wive-ng.sf.net@sfstudio.sadnet.lo) (gcc version 3.3.3) #1565 Mon, 12 Jan 2009 02:42:29 +0600
early printk enabled
DetectRAMsequence
  REG returned:16[16]
  RAM after check region:8
  FullviewRAM:8388608
Determined physical RAM map:
memory: 00800000 @ 00000000 (usable)
Initial ramdisk at: 0x80202000 (37259 bytes)
On node 0 totalpages: 2048
zone(0): 2048 pages.
zone(1): 0 pages.
zone(2): 0 pages.
----------------solved---------------------------
залил bootloader с http://approsoftware.com/download/rtl8186/bootloader/, определились 16 мбайт:
---RealTek(RTL8186)at 2006.02.13-13:32+0800 version 1.4 [16bit](180MHz)
Jump to image start=0x80300000...
DetectRAMsequence
  REG returned:32[32]
  RAM after check region:16
  FullviewRAM:16777216
memory: 01000000 @ 00000000 (usable)
On node 0 totalpages: 4096
zone(0): 4096 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Изменено пользователем Lau
Ссылка на сообщение
Угу, старые буты какого-то хрена всегда возвращают 8 метров или вообще мусор. Тут без смены бута не обойтись.
Ссылка на сообщение
Небольшой анонс http://sfstudio.livejournal.com/10047.html
wive-ng-0.2.10
1) Множественный правки в toolchain благодаря чему удалось несколько уменьшить размер библиотек,
снизить требования к памяти и поправить старые ошибки.
2) Исправлены 2 ошибки в boot всвязи с чем не монтировались CIFS и MMCCARD (спасибо Кузьменко Денису)
3) В исправлен скрипт вызывающий pppoe на предмет pid файла
4) Исправлены mkimg, теперь не используется /dev/ram вместо этого используем loop режим
5) Strip теперь корректно обрабатывет все модули и библиотеки
6) Вычищены хидеры используемые при сборке тулчена
7) Бинарники теперь обрабатываются также и sstrip, что позволило ещё уменьшить объём занимаемый
на флэше.
8) l2tp клиент теперь включен в прошивку по умлочанию, требуется написание стартового скрипта или
пример настройки вручную на точке, для дальнейшего включения в SDK.
Пару дней на тесты и выложу обновлённый SDK и бинари.
У кого есть l2tp сервер в сети? Кто решиться потестить и настроить ручками дабы я потом оформил в виде скриптов и включил в основную ветку?
Ссылка на сообщение
Добавил примеры конфигов, пакетики от l2tp летают, собсно всё должно работать. Кто будет тестить, кто там на корбине был? Вышлю на мыло бинарь, дорисуем скрипты для l2tpd до редиза. Есть желающие? Жду в Jabber в крайнем случае ICQ.
Ссылка на сообщение
Не могу... Дома инет не оплачен... Сегодня оплачу - буду faq рехтовать...
Про корбину:
http://help.corbina.ru/internet/install/linux/
ВОт что нужно от конфига
Ссылка на сообщение
господа, подскажите где искать (а лучше здесь ответьте):
есть acorp wr-g. хотел перешить на wive-ng. изначально на роутере была прошивка 1.4.2q от acorp. при сбросе настроек роутер стал виден по адресу 192.168.1.254. я не линуксоид, потому делал все из под винды. скачал putty.exe. при попытке подключения по ssh (адрес 192.168.1.254, порт 22) выдавалась ошибка (дословно не записал - кажется, что-то про refuse). скачал tftp.exe. команда tftp -i 192.168.1.254 PUT black_fw.bin так же не произвела никаких изменений. было рекомендовано проверить, а есть ли сервер на том конце.
единственный способ прошивки, который остался - через вэб-интерфейс. было решено рискнуть. но сделал ошибку и попытался залить сначала black_fw.bin. после этого роутор ушел в перезагрузку, из которой не вышел. вэб-интерфейс более недоступен. ресет не помогает. по dhcp роутер ничего не раздает и не берет.
есть ли возможность его оживить?
если не известно, как это сделать из под винды - могу запустить alt linux. но знаю его плохо...
Ссылка на сообщение
что никто не подскажет ??? команда ftpput не робит ... большого опыта работы с linux нету ((
читай внимательней документацию !!!!! роутер нужно перевести в режим заливки новой прошивки ( держать reset 6 сек при включении устройства )
Ссылка на сообщение
И для виндозойдов... Для начала настраиваем сетевое подключение: IP 192.168.1.1 NETMASK 255.255.255.0, точка на данный момент отключена
Алгоритм:
1. зажимаем ресет;
2. врубаем питание;
3. ждём 5+ секунд;
4. отпускаем ресет;
5. открываем коммандную строку и переходим в каталог с прошивкой
tftp -i 192.168.1.6 PUT black_fw.bin black_fw.bin
ждём, переходим к пункту 1, после этого уже
tftp -i 192.168.1.6 PUT wive.bin wive.bin
И добро пожаловать в хардкорную-тру-убер-прошивку
Изменено пользователем Aliech
Ссылка на сообщение
И не должно бы работать, т.к. tftp пашет, вроде как, тока в креш режиме
Ссылка на сообщение
то есть и сейчас должно работать? и адрес 192.168.1.6 универсален для всех девайсов и акорпа в частности? при удержании кнопки ресет во время включения никаких дополнительных миганий лампочки не видел. просто загорается лампочка питания. через пару секунд - лампочки конекта соответствующих портов. и все... это нормально?
Ссылка на сообщение
Да, универсально... у самого врГ Укроп
ЗЫ: уже мою инструкцию исполнили? обе части прошивки залили?
тогда вперёд настраивать по ssh
Ссылка на сообщение
Про корбину:
Это херня и так всё сделано. В общем сутки pptp гоняет данные на 8Мб устройстве глюков вроде нет. До ночера я буду занят, ближе к ночи залью 0.2.10 и полностью новый SDK с новым тулчейном и т.д. Все кто решиться шить сегодня wive-ng советую дождаться 0.2.10.
P.S. Если у вас Г700 или аналогичный девайс с 1м LAN портом очень советую первым делом после прошивки отрубить несуществующий у вас eth1 порт, сделать это можно через меню или командой "arg s ETH1_ENABLED no" с дальнейшим сохранением настроек (fs save) и перезагрузкой (reboot). В прошивке конечно есть костыль на эту тему который сам отрубит мёртвый порт, но это происходит не сразу и бывают моменты когда точка успевает уйти в ребут до момента когда скрипт отработает и отключит нераспаянный интерфейс.
Ссылка на сообщение
privet esem u menya prablema svyazno s TrendNet TEW-450APB zawisaet i ne pigueca kogda na AP rejime patklucheca klient .
i mojn pere prashit blubox TrendNet TEW-450APB ?
zaranie spasiba za sawet ?
Ссылка на сообщение
Создайте аккаунт или войдите в него для комментирования
Создать аккаунт
Зарегистрируйтесь для получения аккаунта. Это просто!
Зарегистрировать аккаунт
Уже зарегистрированы? Войдите здесь.
Войти сейчас
