Вопрос теоретическй : внешний блок БС у кэнопи достаточно мал, соответственно такая-же и антенна. Какие характеристики имеет эта антенна (без использования зеркала) на 2.4? И какая мощность передатчика? Хватает? Есть практический интерес.
Canopy Part Number 2400APBC
Description 2.4 GHz AP
Signaling Rate 10 Mbps
Typical LOS Range 5 Mi (8 km)
Typical Aggregate Useful Throughput 7 Mbps
Frequency range of band ISM 2400-2483.5 MHz
Non-overlapping Channels 3
Channel Width 20 MHz
Modulation Type High Index 2-level Frequency Shift Keying (FSK) optimized for interference rejection
Channel Spacing every 2.5 MHz
Encryption DES capable
Latency 15 msec
Carrier to Interference ratio (C/I) ~3dB @ 10 Mbps, ~10dB @ 20 Mbps at -65dBm
Nominal Receiver Sensitivity (dbm typical) -86 dBm
Antenna Gain (dB) 8 dB
EIRP (dB) Adjustable
Equivalent Isotropic Radiated Power (EIRP) Adjustable from 10 mW to 2.0 W
DC Power (typical) 0.3 A @ 24 VDC = 7.2 W
Antenna Beam Width 3 dB antenna beam width 60 degrees, Azimuth and Elevation
Temperature -40° C to +55° C (-40° F to +131° F)
Wind Survival 190 km/hr (118 miles/hr)
Dimensions 11.75 in H x 3.4 in W x 3.4 in D (29.9 cm H x 8.6 cm W x 8.6 cm D)
Weight .45 kg (1 lb)
Access Method Time Division Duplexing/Time Division Multiple Access (TDD/TDMA)
Interface 10/100 Base T, half/full duplex. Rate auto negotiated (802.3 compliant)
Protocols Used IPV4, UDP, TCP, ICMP, Telnet, HTTP, FTP, SNMP
Network Management HTTP, TELNET, FTP, SNMP Version 2c
FCC ID ABZ89FC5808
Industry Canada Certification Number 109W-2400
