Достался POE коммутатор 3com 3CRDSF9PWR в полурабочем состоянии
Стартует, сразу начинает мигать почти всеми лампочками duplex и link activity,
через некоторое время power начинает гореть постоянно, остальные продолжают мигать.
спаял к нему консольный кабель, вот что показывает:
Image Loader 0.0.0.1
Loading Diagnostic Image File : ES3509B-FLF-32_Di_V0.0.0.3.BIX
Diagnostics 0.0.0.3
Normal Mode
--- Performing Power-On Self Tests (POST) ---
DUMMY Test 1 ................. PASS
UART Loopback Test ........... PASS
POE UART Loopback Test ....... PASS
DRAM Test .................... PASS
Timer Test ................... PASS
PCI Device 1 Test ............ PASS
Switch Int Loopback Test .....
DEV_AMTRDRV_SetAgeingTime( 10) Error!!DEV_SWDRV_SetPortSTAState(): Line = 5935 , error_id=-3
Set Port 1 STA ErrorDEV_SWDRV_SetPortSTAState(): Line = 5935 , error_id=-3
AutoNego Enable FALSE!!DEV_SWDRV_EnablePortAutoNeg(): Line = 2503 , error_id=-3
Port 1 Lost Packet
Port 2 Lost Packet
Port 3 Lost Packet
Port 4 Lost Packet
Port 5 Lost Packet
Port 6 Lost Packet
Port 7 Lost Packet
Port 8 Lost Packet
Port 9 Lost Packet
Total 9 Port(s) Lost Packet
Internal Loopback from POST Error!FAIL
------------------ DONE ---------------------
Loading Runtime Image File : op1.bix
Runtime 1.1.0.12
Press Ctrl+C within 5 seconds to get into FailSafe mode
CPU: 200000000 MHz, MEM: 200000000 MHz, SB: 100 MHz, PCI: 33 MHz
PCI unit 0: Dev 0x4713, Rev 0x06, Chip BCM4713_A0, Driver BCM4713_A0
Broadcom BCM47xx 10/100 Mbps Ethernet Controller 2002.9.27.0
root init done
1.Backdoor functions
Enter your choice:
Set Transition mode ...
[get stackingMac done ret_val] = 1
Assigned Unit ID:[1]
Finish Set Transition mode ...
Enter Transition mode ...
PoE Image Loading...
Finish Transition mode ...
Enter Master mode ...DEV_SWDRVL4_SetPortIngressRateLimit(): Line = 577 , error_id=-3
DEV_SWDRVL4_DisablePortIngressRateLimit(): Line = 520 , error_id=-3
current PoE Image version: Ver 3.5
Finish Master mode ...
Performing startup provision ...
CLI provision has been completed
Notify provision complete
Provision Complete ...
Can not get related board information.: errno = 0x3d0002
Assertion failed: 0, file N:/Src/Core/Mgmt/stkmgmt/stktplg/stktplg_om.c, line 554
Tlb Load Exception
Exception Program Counter: 0x809d0b78
Status Register: 0x1000fc01
Cause Register: 0x00000008
Access Address : 0x00000078
Task: 0x81c5e770 "TASK_MON"
Finish Provision Complete ...
auto sync file name startup1.cfg
XFER: End of config sync.
Погуглил, как его можно прошить через XMODEM, может кому пригодится:
это можно сделать если после SELFTEST несколько раз нажать CTRL+U, пока в терминале не появится Password:,
дальше быстро ввести пароль mercury
(для некоторых версий загрузчиков подходит sosupdate)
Если все правильно сделать, сразу выведет список файлов, если неправильно - продолжит загрузку в обычный режим.
Прошить его получилось, но, кажется, единственная прошивка 3CRDSFP9PWR_01_00_12, которую удалось добыть содержит только
op1.bix
Прошу помочь с прошивкой (отличной от 3CRDSFP9PWR_01_00_12), на сайте HP только мануалы находятся.
Edited by viktora79
