a10 3030s выдает ошибку и перезагружает все сервисы.
Последний лог:
Apr 18 2023 14:44:05 Info        [VCS]:aVCS daemon start running
Apr 18 2023 14:44:03 Info        [CFGMGR]:Server thread is running.
Apr 18 2023 14:44:02 Info        [CFGMGR]:a10cfgmgr daemon start running ...
Apr 18 2023 14:44:02 Notice      [AUTH]: Auth Worker Thread initialized successfully
Apr 18 2023 14:44:02 Info        [VCS]:aVCS daemon start running
Apr 18 2023 14:44:01 Warning     [AUTOUPDATE]:a10swupdated: Interrupted system call
Apr 18 2023 14:43:59 Notice      [Router]:Interface(s)  ethernet 9,  removed from aggregator po2
Apr 18 2023 14:43:59 Notice      [Router]:Interface(s)  ethernet 10,  removed from aggregator po2
Apr 18 2023 14:43:59 Notice      [Router]:Interface(s)  ethernet 11,  removed from aggregator po1
Apr 18 2023 14:43:59 Notice      [Router]:Interface(s)  ethernet 12,  removed from aggregator po1
Apr 18 2023 14:43:59 Error       [Fail Safe]:Failed in thread LWP 15957
Apr 18 2023 14:43:59 Error       [Fail Safe]:Failed in thread LWP 15936
Apr 18 2023 14:43:59 Error       [Fail Safe]:Failed in thread LWP 15938
Apr 18 2023 14:43:59 Error       [Fail Safe]:Failed in thread 0x6f09149
Apr 18 2023 14:43:59 Error       [Fail Safe]:FailSafe timestamp 6170378856, last update time 1875411560
Apr 18 2023 14:43:59 Error       [Fail Safe]:FailSafe detected problem in ALB threads.
Apr 18 2023 14:43:59 Warning     [AXMON]:Detected problem in Health Monitor DataCPU2 (LWP 15914). (Last counter was 1348613918 at time 6170378856 bit 7).
Apr 18 2023 14:43:59 Warning     [AXMON]:Detected problem in Health Monitor DataCPU4 (LWP 15917). (Last counter was 783265030 at time 6170378856 bit 6).
Apr 18 2023 14:43:59 Warning     [AXMON]:Detected problem in Health Monitor DataCPU1 (LWP 15913). (Last counter was -774669732 at time 6170378855 bit 5).
Apr 18 2023 14:43:59 Warning     [AXMON]:Detected problem in Health Monitor DataCPU0 (LWP 15912). (Last counter was 651148766 at time 6170378855 bit 4).
Apr 18 2023 14:43:59 Warning     [AXMON]:Detected problem in Health Monitor DataCPU3 (LWP 15916). (Last counter was -1722519606 at time 6170378855 bit 3).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU2 (LWP 15914). (Last counter was 1348613918 at time 6170378779 bit 7).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU4 (LWP 15917). (Last counter was 783265030 at time 6170378779 bit 6).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU1 (LWP 15913). (Last counter was -774669732 at time 6170378779 bit 5).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU0 (LWP 15912). (Last counter was 651148766 at time 6170378779 bit 4).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU3 (LWP 15916). (Last counter was -1722519606 at time 6170378779 bit 3).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU2 (LWP 15914). (Last counter was 1348613918 at time 6170378703 bit 7).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU4 (LWP 15917). (Last counter was 783265030 at time 6170378703 bit 6).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU1 (LWP 15913). (Last counter was -774669732 at time 6170378703 bit 5).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU0 (LWP 15912). (Last counter was 651148766 at time 6170378702 bit 4).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU3 (LWP 15916). (Last counter was -1722519606 at time 6170378702 bit 3).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU2 (LWP 15914). (Last counter was 1348613918 at time 6170378626 bit 7).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU4 (LWP 15917). (Last counter was 783265030 at time 6170378626 bit 6).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU1 (LWP 15913). (Last counter was -774669732 at time 6170378626 bit 5).
Apr 18 2023 14:43:58 Warning     [AXMON]:Detected problem in Health Monitor DataCPU0 (LWP 15912). (Last counter was 651148766 at time 6170378626 bit 4).
Apr 18 2023 14:43:57 Warning     [AXMON]:Detected problem in Health Monitor DataCPU4 (LWP 15917). (Last counter was 783265030 at time 6170378545 bit 6).
#sh vers:
64-bit Advanced Core OS (ACOS) version 4.1.4-GR1-P5, build 81 (Sep-08-2020,09:32)
Проц не в полку.
Где-то читал что возможно проблема в прошивке, если кто сталкивался то посоветуйте прошивку(по возможности скиньте).
Заранее благодарен.
