sirmax Posted February 14, 2023 Posted February 14, 2023 Доброго дня! Наконец дошли руки поиграть в лабе с ASR100 и вот что странно - насколько я могу судить процессу iosd достался гиг памяти из четырех (что маловато) 1065623K/6147K bytes of memory. 4194304K bytes of physical memory. Ожидаемо - что достанется 2 гига (https://www.cisco.com/c/en/us/support/docs/routers/asr-1000-series-aggregation-services-routers/110739-asr-memory.html) Цитата Upon startup, IOSd is granted access to a fixed amount of physical memory on the RP typically 50 percent or 1 GB on 2 GB systems and 2 GB on 4 GB systems. Dual IOS operation with 2/4RU chassis with 4GB of Main Memory for software redundancy each consume 1 GB. redundancy отключен (насколько я могу судить) redundancy mode none ASR1001#show redundancy Redundant System Information : ------------------------------ Available system uptime = 55 minutes Switchovers system experienced = 0 Standby failures = 0 Last switchover reason = none Hardware Mode = Simplex Configured Redundancy Mode = Non-redundant Operating Redundancy Mode = rpr Reason: Unknown Maintenance Mode = Disabled Communications = Down Reason: Failure Current Processor Information : ------------------------------- Active Location = slot 6 Current Software state = ACTIVE Uptime in current state = 55 minutes Image Version = Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S8, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2018 by Cisco Systems, Inc. Compiled Wed 08-Aug-18 10:42 by mcpre BOOT = bootflash:asr1001-universalk9.03.16.08.S.155-3.S8-ext.bin,12; Configuration register = 0x2102 Peer (slot: 7) information is not available because it is in 'DISABLED' state Версия IOS: ROM: IOS-XE ROMMON ASR1001 uptime is 50 minutes Uptime for this control processor is 51 minutes System returned to ROM by reload System image file is "bootflash:asr1001-universalk9.03.16.08.S.155-3.S8-ext.bin" Last reload reason: Reload Command License Level: adventerprise License Type: Permanent Next reload license Level: adventerprise cisco ASR1001 (1RU) processor (revision 1RU) with 1065623K/6147K bytes of memory. Processor board ID SSI17080BW7 4 Gigabit Ethernet interfaces 2 Packet over SONET interfaces 32768K bytes of non-volatile configuration memory. 4194304K bytes of physical memory. 7741439K bytes of eUSB flash at bootflash:. Configuration register is 0x2102 Что я сделал не так? 😃 (если кто-то поделится иосом в личку будет здорово, может быть это баг иоса?) Вставить ник Quote
jffulcrum Posted February 14, 2023 Posted February 14, 2023 Старый мануал, 2009 года. Смотрите новее, в конце: ASR1000 Series Memory Allocation Between Linux and IOSd - Cisco Вставить ник Quote
sirmax Posted February 14, 2023 Author Posted February 14, 2023 47 минут назад, jffulcrum сказал: Старый мануал, 2009 года. Смотрите новее, в конце: ASR1000 Series Memory Allocation Between Linux and IOSd - Cisco Ага значит только в магазин за памятью а сколько в него запихнуть можно? 8 гиг вроде лезет но найти где прочитал не могу Вставить ник Quote
jffulcrum Posted February 14, 2023 Posted February 14, 2023 Cisco ASR 1000 Series Router Hardware Installation Guide - Removing and Replacing FRUs from the Cisco ASR 1000 Series Routers [Cisco ASR 1000 Series Aggregation Services Routers] - Cisco Там листайте до секции "Removing and Replacing the Cisco ASR 1001 Router DIMM Memory Modules" Вставить ник Quote
sirmax Posted February 16, 2023 Author Posted February 16, 2023 Ну, 16 гиг ( 4 планки по 4 гига) стало без вопросов, память брал на барахолке старых серверов. На ebay нашел описание у продавца, и купил такую же цена 15 баксов с доставкой сутки. DDR2 Memory Features: "THIS MEMORY IS NOT FOR DESKTOPS", ECC Memory, Registered Bus Speed: PC2-5300 (DDR2-667) cisco ASR1001 (1RU) processor (revision 1RU) with 6800019K/6147K bytes of memory. Processor board ID SSI17080BW7 4 Gigabit Ethernet interfaces 2 Packet over SONET interfaces 32768K bytes of non-volatile configuration memory. 16777216K bytes of physical memory. 7741439K bytes of eUSB flash at bootflash:. FW заехало Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd 172.31.100.193 4 12345 142096 29 945716 0 0 00:23:08 935997 Вставить ник Quote
