anto Posted February 6, 2006 Posted February 6, 2006 На старых сетевухах и хабах встречаю рядом с BNC разъем подписанный AUX на 15 контактов. Очень хотелось бы узнать об этом поподробнее. Вставить ник Quote
ram_scan Posted February 6, 2006 Posted February 6, 2006 Не AUX а AUI. 8.0 Universal 15-pin Connector Note that the 15-pin AUI connector on an interface is a "universal" connector that makes it possible to connect the interface to any Ethernet segment type, for the small additional cost of an outboard MAU. In the last figure we saw a 15-pin AUI connection to an outboard 10BASE-FL MAU. You can make the same sort of connection to a thin or twisted-pair segment. You can attach a 15-pin AUI connector to a thin Ethernet segment, for example, by using an external MAU equipped with a thin Ethernet BNC MDI. The MAU with its BNC MDI is attached directly to a BNC Tee on the thin Ethernet coax, and the 15-pin AUI connector on the MAU is connected to the 15-pin AUI connector on the Ethernet interface with an AUI cable. With a small enough MAU you can even eliminate the AUI cable, and connect the 15-pin connector of the MAU directly to the 15-pin connector on the Ethernet interface of the computer. Now that we've seen what the Ethernet media varieties look like, let's look at the guidelines used for building a multi-segment Ethernet system with these varieties. The next part of this guide describes one of the models provided by the IEEE for multi-segment configuration. Вставить ник Quote
Barsick Posted February 6, 2006 Posted February 6, 2006 Когда-то, давным давно, когда люди еще не придумали витую пару, на земле жили однозубые вампиры Они искали толстый коаксиал и сосали из него интернет :) Вставить ник Quote
txalex Posted February 6, 2006 Posted February 6, 2006 Когда-то, давным давно, когда люди еще не придумали витую пару, на земле жили однозубые вампиры Они искали толстый коаксиал и сосали из него интернет :) Красочное объяснение :) Вставить ник Quote
zoro Posted February 6, 2006 Posted February 6, 2006 Barsick, а также было уже тогда волокно!!! и витая пара, но трансиверы и вампиры хотели много проводов, и они получали их... через AUI разъем... Вставить ник Quote
Прохожий Posted February 7, 2006 Posted February 7, 2006 Когда-то, давным давно, когда люди еще не придумали витую пару, на земле жили однозубые вампирыОни искали толстый коаксиал и сосали из него интернет :) Правда, интернета тогда еще фактически не было... Так что сосали они ЛАН :) Вставить ник Quote
Sirco Posted February 7, 2006 Posted February 7, 2006 Попробую обьяснить другими словами ;-) Изначально езернет был построен на толстом кабеле 12 мм диаметром , так как этот кабель не удобно было подводить к компам использовали блочки отбора сигнала от этого кабеля в простонародье называемые "вампирами" так как для подключения толстый кабель протыкался "иголкой" и таким образом осуществлялся контакт с центральной жилой . Блочок был активным в нем стояла микросхема - схема была точно такая как BNC. И поключался данный блочок 15 пиновым разьемом аналогичным разьему который счас применяют в джойстиках. Растояние которое разрешал сделать толстый коаксиал 500м Для упрощения подводки после этого сделали тонкий коаксиал - который постепенно вытеснил толстый - так как был более мобильний и проще в експлуатации расстояние 180 м , в дальнейшем фирма 3СОМ сделала адаптеры на 300м уточнив номиналы некоторых деталей схемы (а именно детектора коллизий) Вставить ник Quote
boykov Posted February 7, 2006 Posted February 7, 2006 > в дальнейшем фирма 3СОМ сделала адаптеры на 300м уточнив > номиналы некоторых деталей схемы (а именно детектора коллизий) Какие? 3c509 ? Он правда может 300 метров по тонкому коаксиалу? Вставить ник Quote
Barsick Posted February 7, 2006 Posted February 7, 2006 Смотришь тип м/с, стоящей на сетевухе, в корпусе DIP14 (или 16?), точнее - цифирки Потом на www.national.com ищешь аппнот на эту м/с, там описано как перестроить детектор коллизий для работы по 300-м кабелю Вставить ник Quote
