Приветствую!
Имеем Linux Router с:
$ lspci | grep Ethernet
01:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
01:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
02:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
03:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
04:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
05:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
I350 - дискретная, I210 - встроенная
$ ip li sh
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 10000
    link/ether **:**:**:**:**:f6 brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 10000
    link/ether **:**:**:**:**:f7 brd ff:ff:ff:ff:ff:ff
4: eth2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether **:**:**:**:**:81 brd ff:ff:ff:ff:ff:ff
5: eth3: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether **:**:**:**:**:82 brd ff:ff:ff:ff:ff:ff
6: eth4: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether **:**:**:**:**:83 brd ff:ff:ff:ff:ff:ff
7: eth5: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether **:**:**:**:**:84 brd ff:ff:ff:ff:ff:ff
8: v3@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
где eth0 - uplink, eth1 - local (I350); eth2-5 (I210), причем eth5 - IPMI
$ tc qdisc show
qdisc noqueue 0: dev lo root refcnt 2
qdisc mq 0: dev eth0 root
qdisc fq_codel 0: dev eth0 parent :4 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 32Mb ecn
qdisc fq_codel 0: dev eth0 parent :3 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 32Mb ecn
qdisc fq_codel 0: dev eth0 parent :2 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 32Mb ecn
qdisc fq_codel 0: dev eth0 parent :1 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 32Mb ecn
qdisc mq 0: dev eth1 root
qdisc fq_codel 0: dev eth1 parent :4 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 32Mb ecn
qdisc fq_codel 0: dev eth1 parent :3 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 32Mb ecn
qdisc fq_codel 0: dev eth1 parent :2 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 32Mb ecn
qdisc fq_codel 0: dev eth1 parent :1 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 32Mb ecn
qdisc noqueue 0: dev v3 root refcnt 2
$ tc class show dev eth0
class mq :1 root
class mq :2 root
class mq :3 root
class mq :4 root
class mq :5 root
class mq :6 root
class mq :7 root
class mq :8 root
$ tc class show dev eth1
class mq :1 root
class mq :2 root
class mq :3 root
class mq :4 root
class mq :5 root
class mq :6 root
class mq :7 root
class mq :8 root
Нагрузка на каждый порт I350 порядка 900 Мбит/с.
Требуется: зеркало трафика из eth1, причем Tx/Rx -> eth2, Tx -> eth3.
Вопросы:
  1. Насколько вообще возможно сделать зеркало средствами tc с порта дискретной сетевой карты на встроенную?
  2. Насколько "точное" зеркало будет?
P.S. С tc знаком поверхностно. Пробовал на виртуальной машине настроить зеркало - получилось, но не при такой нагрузке, не на таких сетевых, без уже имеющихся очередях... Как вы понимаете, при такой нагрузке на боевой машине тестировать не хочется... Поэтому решил спросить совета у более опытных пользователей.
Заранее спасибо!
 Да и в общем-то ни к чему вызывать лишние-ненужные вопросы у сормовцев.  Есть проект, есть список рекомендованных железяк в проекте. Проект обязателен и он почти типовой.
Вдаваться в вопрос с $0Rm я не буду.
Вопрос про зеркало. У меня есть опасения, что I210 оFигеет от такой наглости. Да и грамотно прописать qdisc и filter надо...
Особо не вдавался в datasheet, но на первый взгляд I210 более энергоэффективнее, более "домашний". Что-то критичное не заметил.
К тому же, как я узнал, I210 уже используется в другом "зеркале". Правда, только на прием "части" трафика. Без проблем и уже очень давно...
