Добрый день, задача настроить Tp-link DS-P7001-08 для работы onu в 500 влане.
Влан 500- услуги.
Влан 700 - управление.
В порт interface gpon 1/0/2 подключена бриджовая onu  в неё подключен ПК.
DS-P7001-08_6290F6#show running-config
running-config
!DS-P7001-08
vlan 500
          name "500"
vlan 700
          name "700"
serial_port baud_rate 38400
system-time ntp UTC 133.100.9.2 139.78.100.163 12
no system-time dst
no service reset-disable
ip route 0.0.0.0 0.0.0.0 10.10.10.1
dba-profile profile-id 0 profile-name default type4 max 102400
ont-srvprofile gpon profile-id 0 profile-name default
  mac-learning
  native-vlan unconcern
  multicast-mode unconcern
  multicast-forward unconcern
  ont-port eth adaptive 4
  port priority-policy eth 1 unconcern
  port igmp-forward eth 1 unconcern
  port q-in-q eth 1 unconcern
  port eth 1 max-mac-count unlimited
  port priority-policy eth 2 unconcern
  port igmp-forward eth 2 unconcern
  port q-in-q eth 2 unconcern
  port eth 2 max-mac-count unlimited
  port priority-policy eth 3 unconcern
  port igmp-forward eth 3 unconcern
  port q-in-q eth 3 unconcern
  port eth 3 max-mac-count unlimited
  port priority-policy eth 4 unconcern
  port igmp-forward eth 4 unconcern
  port q-in-q eth 4 unconcern
  port eth 4 max-mac-count unlimited
  ont-port pots adaptive 2
ont-srvprofile gpon profile-id 10 profile-name srv_profile_10
  mac-learning
  ont-port eth adaptive 1
ont-lineprofile gpon profile-id 0 profile-name default
  no fec-upstream
  mapping-mode vlan
  omcc encrypt
  tcont 1 dba-profile-id 0
  gem add 1 tcont 1 encrypt enable
  gem mapping 1 1 vlan-untag
ont-lineprofile gpon profile-id 10 profile-name line_profile_10
  no fec-upstream
  mapping-mode vlan
  no omcc encrypt
  gem add 11 tcont 1 encrypt disable
  gem mapping 11 1 vlan 500
service-port 3 config gpon 1/0/1 ont 1 gem-id 1 svlan 500 user-vlan 500 tag-action transparent
interface gpon 1/0/1
  ont auto-auth authmode sn-auth
  ont add 1 sn-auth HWTC-82101753 ont-lineprofile-id 10 ont-srvprofile-id 0
  ont auto-auth rule 1 ont-lineprofile-id 0 ont-srvprofile-id 0
  ont port attribute 1 eth 1 admin-status enable
  ont port native-vlan 1 eth 1 vlan 500 prival 0
interface gpon 1/0/3
interface gpon 1/0/4
interface gpon 1/0/5
interface gpon 1/0/6
interface gpon 1/0/7
interface gpon 1/0/8
interface management 1
  ip address 192.168.1.1 255.255.255.0
  ipv6 enable
interface vlan 1
  ip address 192.168.0.1 255.255.255.0
  ipv6 enable
  dpms interface-id 1
interface vlan 700
  ip address 10.10.10.5 255.255.252.0
  no ipv6 enable
interface ten-gigabitEthernet 1/0/1
  duplex full
interface ten-gigabitEthernet 1/0/2
  duplex full
interface gigabitEthernet 1/0/3
  switchport general allowed vlan 500,700 tagged
end
При такой конфигурации mac адреса пк включенного в onu в выводе show mac address-table vlan 500 не вижу. Просьба помочь с конфигурацией/указать на ошибки/показать примеры конфига.
  • 2 years later...
