FMA0 Posted October 26, 2022 Posted October 26, 2022 Добрый день. Есть SNR-S2982G-24T-POE Device, Compiled on Oct 14 17:57:11 2022 SoftWare Version 7.0.3.5(R0241.0551) BootRom Version 7.2.55 HardWare Version 2.0.1 Подключаю в 23 порт устройство, питающееся по PoE, но получаю Interface Status Oper Power(mW) Max(mW) Current(mA) Volt(V) Priority Class --------------- ------- ------ --------- ------- ----------- ------- -------- ----- Ethernet1/0/23 enable deny 0 30000 0 0 low 3 В логах 405 %Oct 26 15:13:24:037 2022 <critical> MODULE_POE[tPoeStatus]:%LINK-3-POE: Interface Ethernet1/0/23, PD oper change to :4(deny) 404 %Oct 26 15:13:19:509 2022 <critical> MODULE_POE[tPoeStatus]:%LINK-3-POE: Interface Ethernet1/0/23, PD is not powered! Подскажите, как понять, что устройству не нравится, если на соседнем аналогичном коммутаторе оно работает? Настройки: #sh power inline Power Inline Status: On Power Available: 200 W Power Used: 0 W Power Remaining: 200 W Power Max-type: user-defined Min Voltage: 44 V Max Voltage: 57 V Police: Off Legacy: Off Disconnect: Ac Mode: Signal Pse Type: RTL HW Version: SW Version: 1.0.0.4 #sh run ! service password-encryption ! hostname 11.4a-2.2 ! username ___ privilege 15 password 7 ___ ! authentication line console login local ! ! clock timezone +5 add 5 0 ! ! ! ! ! ! spanning-tree ! ! ! ! ! ! ! vlan 1 ! vlan 86 ! vlan 125 ! vlan 999 name blackhole ! Interface Ethernet1/0/1 switchport access vlan 999 ! Interface Ethernet1/0/2 switchport access vlan 999 ! Interface Ethernet1/0/3 switchport access vlan 999 ! Interface Ethernet1/0/4 switchport access vlan 999 ! Interface Ethernet1/0/5 switchport access vlan 999 ! Interface Ethernet1/0/6 switchport access vlan 999 ! Interface Ethernet1/0/7 switchport access vlan 999 ! Interface Ethernet1/0/8 switchport access vlan 999 ! Interface Ethernet1/0/9 switchport access vlan 999 ! Interface Ethernet1/0/10 switchport access vlan 999 ! Interface Ethernet1/0/11 switchport access vlan 999 ! Interface Ethernet1/0/12 switchport access vlan 999 ! Interface Ethernet1/0/13 switchport access vlan 999 ! Interface Ethernet1/0/14 switchport access vlan 999 ! Interface Ethernet1/0/15 switchport access vlan 999 ! Interface Ethernet1/0/16 switchport access vlan 999 ! Interface Ethernet1/0/17 switchport access vlan 999 ! Interface Ethernet1/0/18 switchport access vlan 999 ! Interface Ethernet1/0/19 switchport access vlan 999 ! Interface Ethernet1/0/20 switchport access vlan 999 ! Interface Ethernet1/0/21 switchport access vlan 999 ! Interface Ethernet1/0/22 switchport access vlan 999 ! Interface Ethernet1/0/23 switchport access vlan 999 ! Interface Ethernet1/0/24 switchport access vlan 999 ! Interface Ethernet1/0/25 switchport mode trunk ! Interface Ethernet1/0/26 switchport mode trunk ! Interface Ethernet1/0/27 switchport mode trunk ! Interface Ethernet1/0/28 description uplink switchport mode trunk ! interface Vlan125 ip address 10.10.15.42 255.255.255.0 ! ip default-gateway 10.10.15.1 ! ntp enable ntp server 10.10.2.56 ! ! no login ! captive-portal ! end Вставить ник Quote
Vladimir Efimtsev Posted October 26, 2022 Posted October 26, 2022 Здравствуйте, @FMA0 Создайте, пожалуйста, обращение на support.nag.ru К обращению прикрепите информацию, указанную выше, а также выводы команд "sh ver", "sh power inline interface". Также скажите, проблему наблюдаете только с данным портом или с другими тоже? Вставить ник Quote
FMA0 Posted October 26, 2022 Author Posted October 26, 2022 Сейчас создам, спасибо. Цитата Также скажите, проблему наблюдаете только с данным портом или с другими тоже? На всех. Вставить ник Quote
Kozubsky Vladimir Posted November 17, 2022 Posted November 17, 2022 Добрый день, @FMA0. По результатам обращения на support.nag пришли в к выводу, что это аппаратная неисправность коммутатора и дали вам рекомендации по обращению в СЦ. Вставить ник Quote
МихаилМ Posted June 19, 2023 Posted June 19, 2023 Добрый день, есть коммутатор SNR-S2982G-24T-POE мониториться zabbix 6.0.17 используется шаблон отсюда https://data.nag.ru/SNR Switches/Templates/Zabbix/S2962%2C S2965%2C S2982G%2C S2985G/SNR S2962|65%2C S2982G|85G Templates Zabbix.zip SoftWare Version 7.0.3.5(R0241.0594) BootRom Version 7.2.55 HardWare Version 2.0.1 Периодически срабатывает триггер High bandwidth usage >90%, интерфейсы на которых срабатывает триггер разные, загрузка на них не превышает 1-10% ошибок на интерфейсах нет, ошибок в шаблоне тоже не нашел. Куда смотреть не подскажите? Вставить ник Quote
Vladimir Efimtsev Posted June 20, 2023 Posted June 20, 2023 @МихаилМ, добрый день. Подскажите, у вас такая проблема только с одним коммутатором данной модели с данной версией ПО или где-то еще похожую проблему наблюдаете? Как вы определили, что реальная загрузка интерфейсов не превышает 1-10%? Вставить ник Quote
МихаилМ Posted June 20, 2023 Posted June 20, 2023 Таких коммутаторов два, в боевом режиме 5 дней, на первом триггер срабатывал 5 раз, на втором коммутаторе триггер срабатывал 1 раз. Нагрузку смотрел по ssh командой show interface ethernet 1/0/X и на этих коммутаторах висят видеокамеры в количестве 13 штук на первом и 12 штук на втором. Поток с каждой камеры 4 мегабита среднее, интерфейсы у камер 100 мегабитные. Аплинк на коммутаторе 1 гигабит. Триггеры на высокую загрузку срабатывал на на аплинке и на портах с камерами. Вот какой трафик на аплинке: floor12-video-sw#show interface ethernet 1/0/24 Interface brief: MTU 1500 bytes, BW 1000000 Kbit Time since last status change:0w-5d-0h-43m-13s (434593 seconds) Encapsulation ARPA, Loopback not set Auto-duplex: Negotiation full-duplex, Auto-speed: Negotiation 1G bits FlowControl is off, MDI type is auto Statistics: 5 minute input rate 344453 bits/sec, 624 packets/sec 5 minute output rate 12486046 bits/sec, 1213 packets/sec The last 5 second input rate 355029 bits/sec, 627 packets/sec The last 5 second output rate 13058642 bits/sec, 1216 packets/sec Input packets statistics: 226609887 input packets, 15646025031 bytes, 0 no buffer 224673860 unicast packets, 124199 multicast packets, 1811828 broadcast packets 0 input errors, 0 CRC, 0 frame alignment, 0 overrun, 0 ignored, 0 abort, 0 length error, 0 undersize 0 jabber, 0 fragments, 0 pause frame Output packets statistics: 441324959 output packets, 563218101677 bytes, 0 underruns 439755387 unicast packets, 664 multicast packets, 1568908 broadcast packets 0 output errors, 0 collisions, 0 late collisions, 0 pause frame Вот трафик с камеры: floor12-video-sw#show interface ethernet 1/0/9 Interface brief: Ethernet1/0/9 is up, line protocol is up Ethernet1/0/9 is layer 2 port, alias name is (null), index is 9 Hardware is Gigabit-TX, address is f8-f0-82-d3-99-80 PVID is 12 MTU 1500 bytes, BW 100000 Kbit Time since last status change:0w-4d-2h-3m-12s (352992 seconds) Encapsulation ARPA, Loopback not set Auto-duplex: Negotiation full-duplex, Auto-speed: Negotiation 100M bits FlowControl is off, MDI type is auto Statistics: 5 minute input rate 493883 bits/sec, 55 packets/sec 5 minute output rate 17721 bits/sec, 34 packets/sec The last 5 second input rate 453011 bits/sec, 59 packets/sec The last 5 second output rate 16977 bits/sec, 38 packets/sec Input packets statistics: 19428788 input packets, 21784146992 bytes, 15 no buffer 19305273 unicast packets, 32 multicast packets, 123468 broadcast packets 15 input errors, 0 CRC, 0 frame alignment, 0 overrun, 0 ignored, 0 abort, 0 length error, 0 undersize 0 jabber, 15 fragments, 0 pause frame Output packets statistics: 12189750 output packets, 788480490 bytes, 0 underruns 10348541 unicast packets, 433 multicast packets, 1840776 broadcast packets 0 output errors, 0 collisions, 0 late collisions, 0 pause frame Вставить ник Quote
Vladimir Efimtsev Posted June 21, 2023 Posted June 21, 2023 @МихаилМ, а вы эти выводы с портов коммутатора снимали непосредственно, когда у вас срабатывал триггер? Или просто сейчас сняли в случайный момент времени? И с каким интервалом заббикс опрашивает коммутатор? Просто, возможно, имеют место быть берсты трафика, которые периодически совпадают с моментом опроса коммутатора, поэтому и срабатывает триггер периодически. Вставить ник Quote
МихаилМ Posted June 21, 2023 Posted June 21, 2023 (edited) В посте состояние портов в случайный момент времени. Заббикс опрашивает состояние портов каждые 30 секунд, триггер высокая загрузка заббикс считает по среднему значению за 15 минут. Внимательно посмотрел заббикс и увидел что триггер срабатывает из-за того что Item входящего трафика на интерфейсе получает нереально высокие. (на 100 мегабитном интерфейсе получает значение в 60 гигабит) https://disk.yandex.ru/i/Q82L3KuO0h_4Tg https://disk.yandex.ru/i/hFZhmOXcnvr8xg Edited June 21, 2023 by МихаилМ Вставить ник Quote
kuzma73 Posted June 22, 2023 Posted June 22, 2023 Прочитал тему. Братан, встрял ты с этим SNR конкретно. Я такие себе брал себе в контору для тестов. Тоже думал на них видео сделать. Месяц трахался с ними. Всё кривые, косые. Нихрена не работают. Плюнул, взял Длинки. Сижу, горя не знаю. Вставить ник Quote
Vladimir Efimtsev Posted June 23, 2023 Posted June 23, 2023 @МихаилМ, добрый день. Не совсем понимаю, что вы имеете в виду под "триггер высокая загрузка заббикс считает по среднему значению за 15 минут.", судя по графикам, которые вы предоставили, вижу, что опрос происходит где-то раз в минуту. Есть ли у вас возможность снять дамп трафика, чтобы посмотреть, какие SNMP-request прилетают на коммутатор, и что именно он отвечает в SNMP ответе, имею в виду, просто хотя бы для начала определить, отправляет ли коммутатор верное значение на Zabbix, и это Zabbix его по какой-то причине не так интерпретирует, или что это уже коммутатор по какой-то причине в какие-то промежутки времени сам отправляет такие значения на Zabbix. Для этого можно снять мониторинговую сессию, с порта, куда подключен Zabbix (где от него прилетают запросы), а в другой порт (в порт назначения) подключить ноутбук/ПК с запущенным сниффером, например, Wireshark. После того, как снимете дамп, напишите нам на nag.support, и прикрепите все данные к обращению, предлагаю разбираться дальше там. Вставить ник Quote
Aleksey Sonkin Posted July 7, 2023 Posted July 7, 2023 @kuzma73 Здравствуйте, тысячи клиентов России и СНГ с вами бы поспорили. Мы не скрываем, что проблемы периодически возникают, также как и на любом вендоре, включая D-Link. Но мы эти проблемы оперативно устраняем. Если у вас что-то не заработало во время тестов - вы могли создать чат тестирования с нашими инженерами с помощью вашего менеджера или просто обратиться на support.nag.ru. Уверен, ваша проблема была бы решена. Вставить ник Quote
ALEX_SE Posted August 12, 2023 Posted August 12, 2023 Vladimir Efimtsev Вот что имеется в виду видимо. (avg(/Template SNR Interfaces Statistic/net.if.in[ifHCInOctets.{#SNMPINDEX}],15m)>({$IF_UTIL_MAX:"{#IFNAME}"}/100)*last(/Template SNR Interfaces Statistic/net.if.speed[ifHighSpeed.{#SNMPINDEX}]) or avg(/Template SNR Interfaces Statistic/net.if.out[ifHCOutOctets.{#SNMPINDEX}],15m)>({$IF_UTIL_MAX:"{#IFNAME}"}/100)*last(/Template SNR Interfaces Statistic/net.if.speed[ifHighSpeed.{#SNMPINDEX}])) and last(/Template SNR Interfaces Statistic/net.if.speed[ifHighSpeed.{#SNMPINDEX}])>0 И если там прилетает несколько терабит в сек то среднее будет высоким. Бывает такое факт. kuzma73 Сколько людей столько и мнений. Я наоборот ровно по той же причине в сети камер и безопасности с длинка ушел на снр и то же практически не знаю горя. Бывают проблемы не без этого, как и везде, но они хотя бы решаются и их не так много. ИТ-служба в своей сети сидит на длинках и плюется. И потихоньку смотрю закупается чем-то другим в т.ч. и снр :) Вставить ник Quote
