neperpbl3 Posted September 26, 2022 Posted September 26, 2022 Настройка DHCP relay на Cisco Nexus N3K-C3064PQ Для работы DHCP relay должен быть выставлен приемлемый порог политики class copp-s-dhcpreq, иначе DHCP запросы не будут обрабатываться CPU. policy-map type control-plane copp-system-policy class copp-s-dhcpreq police pps 90 sh running-config dhcp !Command: show running-config dhcp !Running configuration last done at: Wed Aug 17 11:55:18 2022 !Time: Wed Aug 17 11:55:33 2022 version 9.3(7) Bios:version 5.0.0 feature dhcp service dhcp ip dhcp relay ip dhcp relay information option ipv6 dhcp relay interface VlanX ip dhcp relay address 1.2.3.4 ip dhcp relay address 5.6.7.8 interface VlanY ip dhcp relay address 1.2.3.4 ip dhcp relay address 5.6.7.8 interface VlanZ ip dhcp relay address 1.2.3.4 ip dhcp relay address 5.6.7.8 Настройка DHCP relay на Элтекс MES 2324 ip dhcp relay address 1.2.3.4 ip dhcp relay address 5.6.7.8 ip dhcp relay enable ip dhcp relay information option suboption-type custom ! interface vlan X ip dhcp relay enable ! ... ... interface vlan Y ip dhcp relay enable ... ... interface vlan Z ip dhcp relay enable ! Устанавливать ip dhcp information option [нельзя] При просмотре Option 82 будет неактивно, но так и должно быть. MES2324#sh ip dhcp relay DHCP relay is Enabled Option 82 is Disabled [нормально] Maximum number of supported VLANs without IP Address is 256 Number of DHCP Relays enabled on VLANs without IP Address is 1 DHCP relay is not configured on any port. DHCP relay is enabled on Vlans: X Active: X Inactive: Servers: 1.2.3.4 5.6.7.8 Настройка DHCP relay на D-link серии 3200 rev. C1. # DHCP_LOCAL_RELAY disable dhcp_local_relay config dhcp_local_relay option_82 remote_id default config dhcp_local_relay option_82 circuit_id default config dhcp_local_relay option_82 ports 1-28 policy keep # DHCP_RELAY enable dhcp_relay config dhcp_relay hops 4 time 0 config dhcp_relay option_82 state enable config dhcp_relay option_82 check disable config dhcp_relay option_82 policy keep config dhcp_relay option_82 remote_id default config dhcp_relay option_82 circuit_id default config dhcp_relay option_60 state disable config dhcp_relay option_61 state disable config dhcp_relay option_82 mac_format case uppercase config dhcp_relay option_82 mac_format delimiter number 5 config dhcp_relay option_82 mac_format delimiter none config dhcp_relay option_60 default mode drop config dhcp_relay option_61 default drop config dhcp_relay add vlanid X,Y,Z,... 1.2.3.4 config dhcp_relay add vlanid X,Y,Z,... 5.6.7.8 config dhcp_relay ports 1-28 state enable Command: show dhcp_relay DHCP/BOOTP Relay Status : Disabled DHCP/BOOTP Hops Count Limit : 4 DHCP/BOOTP Relay Time Threshold : 0 DHCP Vendor Class Identifier Option 60 State: Disabled DHCP Client Identifier Option 61 State: Disabled DHCP Relay Agent Information Option 82 State : Enabled DHCP Relay Agent Information Option 82 Check : Disabled DHCP Relay Agent Information Option 82 Policy : Keep DHCP Relay Agent Information Option 82 Circuit ID : Default DHCP Relay Agent Information Option 82 Remote ID : Default DHCP Relay Ignore QinQ Setting Enabled Ports : Interface Server 1 Server 2 Server 3 Server 4 ------------ --------------- --------------- --------------- --------------- Server VLAN ID List --------------- ----------------------------------------------------------- 1.2.3.4 X,Y,Z,... 5.6.7.8 X,Y,Z,... Вставить ник Quote
