Mikrotik глючит Wifi 2.4 протокол в тексте начинают идти сообщения reassociating пропадает или очень замедляется wifi на устройствах
При этом Lan работает нормально.
Радиообстановка много роутеров 2.4 , днем появляется сигнал в 2 раза большей мощности чем нас и два раза шире, как всплеск на несколько секунд
feb/12 10:48:41 wireless,info 18:E3:BC:DA:06:D8@wlan1: disconnected, extensive data loss, signal strength -83
feb/12 10:51:19 dhcp,info defconf deassigned 192.168.88.205 from 18:E3:BC:DA:06:D8
feb/12 11:00:34 wireless,info 74:D2:1D:8D:6E:85@wlan1: disconnected, group key exchange timeout, signal strength -90
feb/12 11:16:12 dhcp,info defconf deassigned 192.168.88.251 from 74:D2:1D:8D:6E:85
feb/12 11:34:57 interface,info ether3 link down
feb/12 11:34:59 interface,info ether3 link up (speed 100M, full duplex)
feb/12 11:35:06 dhcp,info defconf assigned 192.168.88.207 to 30:24:A9:ED:EC:76
feb/12 11:37:48 wireless,info 74:D2:1D:8D:6E:85@wlan1: connected, signal strength -59
feb/12 11:37:48 dhcp,info defconf assigned 192.168.88.251 to 74:D2:1D:8D:6E:85
feb/12 11:47:39 wireless,info 18:E3:BC:DA:06:D8@wlan1: connected, signal strength -66
feb/12 11:47:40 dhcp,info defconf assigned 192.168.88.205 to 18:E3:BC:DA:06:D8
feb/12 12:05:42 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -68
feb/12 12:05:43 dhcp,info defconf assigned 192.168.88.244 to 94:39:E5:BC:36:87
feb/12 12:40:51 wireless,info 18:E3:BC:DA:06:D8@wlan1: reassociating
feb/12 12:40:51 wireless,info 18:E3:BC:DA:06:D8@wlan1: disconnected, ok, signal strength -64
feb/12 12:40:51 wireless,info 18:E3:BC:DA:06:D8@wlan1: connected, signal strength -70
feb/12 12:44:10 script,info =Speed internet average=  68 Mbps,current= 102 Mbps,cpu-load=2%
feb/12 12:50:52 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
feb/12 12:50:52 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, ok, signal strength -65
feb/12 12:50:52 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -65
feb/12 12:51:15 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
feb/12 12:51:15 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, ok, signal strength -69
feb/12 12:51:15 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -66
feb/12 12:51:41 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
feb/12 12:51:41 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, ok, signal strength -66
feb/12 12:51:41 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -64
feb/12 12:52:12 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
feb/12 12:52:12 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, ok, signal strength -65
feb/12 12:52:12 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -66
feb/12 12:53:12 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
feb/12 12:53:12 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, ok, signal strength -65
feb/12 12:53:12 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -66
feb/12 12:54:06 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
feb/12 12:54:06 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, ok, signal strength -67
feb/12 12:54:06 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -65
feb/12 12:57:12 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
feb/12 12:57:12 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, ok, signal strength -66
feb/12 12:57:12 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -68
feb/12 12:58:57 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
feb/12 12:58:57 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, ok, signal strength -67
feb/12 12:58:57 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -68
feb/12 12:59:07 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
feb/12 12:59:07 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, ok, signal strength -67
feb/12 12:59:07 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -68
feb/12 12:59:22 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
устройство ...36:87 Ноут Sony .
..06:D8 сотовый
..6E:85 сотовый
время аренды ключа 1 час.
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode \
    band=2ghz-onlyn country=no_country_set disabled=no disconnect-timeout=14s \
    distance=indoors frame-lifetime=20 frequency=auto frequency-mode=\
    superchannel hw-retries=15 installation=indoor max-station-count=20 mode=\
    ap-bridge on-fail-retry-time=200ms ssid=MikroTik tx-power=19 \
    tx-power-mode=all-rates-fixed update-stats-interval=10s \
    wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
не могу понять в чем проблема (квартира 3 ком. микронтик RB952Ui-5ac2nD в центре )
???? Гуру помогите .
Другой день :
feb/13 18:49:32 dhcp,info defconf assigned 192.168.88.206 to B4:CD:27:53:E9:77
feb/13 19:29:00 wireless,info B4:CD:27:53:E9:77@wlan1: reassociating
feb/13 19:29:00 wireless,info B4:CD:27:53:E9:77@wlan1: disconnected, ok, signal strength -79
feb/13 19:29:00 wireless,info B4:CD:27:53:E9:77@wlan1: connected, signal strength -61
feb/13 20:44:10 script,info =Speed internet average=  80 Mbps,current=   8 Mbps,cpu-load=1%
feb/13 20:44:11 e-mail,info sent <=Speed internet < 10 Mbps,   RB952Ui-5ac2nD, 13.02.2022,20:44:10> to: tarasow306@yandex.ru
feb/13 21:19:53 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -71
feb/13 21:19:54 dhcp,info defconf assigned 192.168.88.244 to 94:39:E5:BC:36:87
feb/13 21:53:08 interface,info ether2 link up (speed 100M, full duplex)
feb/13 21:53:37 dhcp,info defconf assigned 192.168.88.204 to 0C:89:10:5D:C6:F2
feb/13 21:53:38 wireless,info 5C:A3:9D:22:FD:26@wlan1: connected, signal strength -70
feb/13 22:26:24 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
feb/13 22:26:24 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, ok, signal strength -67
feb/13 22:26:24 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -66
feb/13 22:44:10 script,info =Speed internet average=  83 Mbps,current=  34 Mbps,cpu-load=4%
feb/13 23:12:48 interface,info ether2 link down
feb/13 23:18:41 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
feb/13 23:18:41 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, ok, signal strength -66
feb/13 23:18:41 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -60
feb/13 23:21:49 wireless,info 94:39:E5:BC:36:87@wlan1: reassociating
feb/13 23:21:49 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, ok, signal strength -70
feb/13 23:21:49 wireless,info 94:39:E5:BC:36:87@wlan1: connected, signal strength -69
feb/13 23:38:38 dhcp,info defconf deassigned 192.168.88.204 from 0C:89:10:5D:C6:F2
00:00:34 wireless,info 5C:A3:9D:22:FD:26@wlan1: disconnected, group key exchange timeout, signal strength -72
00:23:33 wireless,info 94:39:E5:BC:36:87@wlan1: disconnected, received disassoc: sending station leaving (8), signal strength -73
00:29:39 interface,info ether3 link down
00:29:41 interface,info ether3 link up (speed 10M, full duplex)
00:44:10 script,info =Speed internet average=  93 Mbps,current= 103 Mbps,cpu-load=3%
00:48:53 dhcp,info defconf deassigned 192.168.88.207 from 30:24:A9:ED:EC:76
00:51:49 dhcp,info defconf deassigned 192.168.88.244 from 94:39:E5:BC:36:87
02:30:22 wireless,info 38:01:46:85:91:BE@wlan1: reassociating
02:30:22 wireless,info 38:01:46:85:91:BE@wlan1: disconnected, ok, signal strength -41
02:30:22 wireless,info 38:01:46:85:91:BE@wlan1: connected, signal strength -46
02:30:23 dhcp,info defconf deassigned 192.168.88.211 from 38:01:46:85:91:BE
02:30:23 dhcp,info defconf assigned 192.168.88.211 to 38:01:46:85:91:BE
02:44:10 script,info =Speed internet average= 445 Mbps,current= 125 Mbps,cpu-load=1%
03:19:28 wireless,info 64:90:C1:1C:77:95@wlan1: reassociating
03:19:28 wireless,info 64:90:C1:1C:77:95@wlan1: disconnected, ok, signal strength -60
03:19:28 wireless,info 64:90:C1:1C:77:95@wlan1: connected, signal strength -54
..77:95 Камера
..91:BE пылесос
..FD:26 Телевизор
  • 2 years later...
Было тоже самое на RB4011 после перезагрузки. Если кратко решилось тем, что дал ему остыть на морозе перед включением :)
Если более подробно, то прочитав коммент про откат к заводской прошивке стал откатывать наблюдая по консольному кабелю (USB-A RJ-45) через putty за процессом.
Перепробовал и заводскую прошивку и промежуточную и бекапы своих настроек и полные ресет настроек - хрен там плавал.
В какой то момент перестал загружаться ethernet, т е мигнет рядами диодов по очереди и тишина. Стандартный ip 192.168.88.1 не пингуется.
Подключенный к ноуту eth порт на роутере изредка мигнет, после чего сеть как бы появилась и через пару сек опять пропадает.
Когда уже решил подзабить на эксперименты и с мыслями что продам на запчасти выключил и оставил лежать на столе.
Вечерком включил - сеть завелась и eth и wifi клиенты перестали отваливаться. Перед отправкой на место постоянной работы дал отдохнуть на балконе.
Трудится и по сей день. Толковая инструкция как мониторить по консольному порту если даже eth отвалился
https://net.ekzorchik.ru/2024/06/20/interacting-with-mikrotik-via-console-port/
