Интересует программа для разработки Wi-Fi сети.
Единственный вариант который был пока найден - Ekahau Site Survey, то она требует 700 долларов за регистрацию.
Есть ли еще аналоги?
Есть такие решения у производителей:
WLAN Management Software 2300
http://products.nortel.com/go/product_assoc.jsp?segId=0&parId=0&catId=-9283&rend_id=3525&contOid=100176701&prod_id=52422&locale=en-US
Features' target='_blank'>http://products.nortel.com/go/product_asso...S[CODE]Features</a> & Benefits
Planning and Design:
Imports existing floor plans in AutoCAD DXF™, AutoCAD DWG, JPEG or GIF file types.
Includes a library of RF attenuation characteristics for doors, pillars, walls, ceilings, and other physical obstructions.
Calculates the ideal number, placement and configuration of access points based on capacity requirements and 3-Dimensional RF characteristics of physical environment.
Generates a detailed RF map showing calculated RF coverage on floor plan.
Creates a bill of materials including access points, switches and even cable runs.
Can be used as a standalone tool for analyzing the effects of hypothetical scenarios.
Can import RF data and maps from Ekahau™ site survey tool for improved RF pattern accuracy.
Configuration:
Calculates WLAN topology, access point placement and configurations including power level and channel settings.
Provides system-wide configuration and updates in a single-step.
Verifies system changes using rules engine and archives past configurations.
Alerts administrators of conflicting change requests.
Full fault and event management capabilities.
Supports SNMP v3 and HP OpenView plug-in.
Monitoring and Reporting:
Instructs access points to perform scheduled, on-demand or continuous RF sweeps.
Detects and maps location of rogue APs, users and coverage holes.
Verifies RF mapping and coverage zones.
Tracks user location, bandwidth rate, roaming history and usage statistics.
All system statistics can be exported in tables and graphs.
Но стоит это дело ~ 3000$
Найти - не сложно. Такие решения есть и много.
GloMoSim, QualNet, cnet ...
Но это професиональные разработки, стоящие весьма и весьма дорого. А есть ли более простая программа?
Ну или в крайнем случае - есть ли крэки к одной из этих навороченных.
