Здравствуйте!
Уже сломал голову и не могу найти проблему в максимально простой конфигурации с поднятием vpls на двух устройствах.
Для начала пытался поднять связь между циской и экстримом по схеме Client(1031 untag)--Extreme(3303 vlan)--Cisco(3303 vlan)--Client(1031 untag). Все отлично поднимается, состояние канала up. Но трафик ходит только в одну сторону:
l2 vfi VLAN_1031 manual
 vpn id 1031
 neighbor 10.200.1.2 encapsulation mpls
 xconnect vfi VLAN_1031
interface Vlan3303
 mtu 9192
 ip address 10.200.200.18 255.255.255.252
 mpls ip
end
interface Vlan1031
 mtu 2000
 no ip address
end
interface GigabitEthernet5/28
 switchport
 switchport access vlan 1031
 switchport mode access
 mtu 9216
end
show mpls forwarding-table 10.200.1.2
Local      Outgoing   Prefix           Bytes Label   Outgoing   Next Hop
Label      Label      or Tunnel Id     Switched      interface
128        1076       10.200.1.2/32    0             Vl3303     10.200.200.17
show mpls l2transport vc 1031 detail
Local interface: VFI VLAN_1031 VFI up
  Interworking type is Ethernet
  Destination address: 10.200.1.2, VC ID: 1031, VC status: up
    Output interface: Vl3303, imposed label stack {1076 1087}
    Preferred path: not configured
    Default path: active
    Next hop: 10.200.200.17
  Load Balance: none
  Flow Label: Disabled
  Create time: 00:10:33, last status change time: 00:00:03
  Signaling protocol: LDP, peer 10.200.1.2:0 up
    Targeted Hello: 10.200.1.16(LDP Id) -> 10.200.1.2
    Status TLV support (local/remote)   : enabled/supported
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: no fault
      Last local SSS circuit status rcvd: no fault
      Last local SSS circuit status sent: no fault
      Last local  LDP TLV    status sent: no fault
      Last remote LDP TLV    status rcvd: no fault
    MPLS VC labels: local 182, remote 1087
    Group ID: local 0, remote 0
    MTU: local 2000, remote 2000
    Remote interface description:
  Sequencing: receive disabled, send disabled
  VC statistics:
    packet totals: receive 6, send 0
    byte totals:   receive 336, send 0
    packet drops:  receive 0, seq error 0, send 0
На экстриме:
create l2vpn vpls VLAN_1031 fec-id-type pseudo-wire 1031
configure l2vpn vpls VLAN_1031 add service vlan vlan1031
configure l2vpn vpls VLAN_1031 mtu 2000
configure l2vpn vpls VLAN_1031 add peer 10.200.1.16 core full-mesh
show l2vpn vpls "VLAN_1031" detail
L2VPN Name: VLAN_1031
   VPN ID                : 1031                  Admin State   : Enabled
   Source Address        : 10.200.1.2            Oper State    : Enabled
   VCCV Status           : Disabled              MTU           : 2000
   VCCV Interval Time    : 5 sec.                Ethertype     : 0x8100
   VCCV Fault Multiplier : 4                     .1q tag       : exclude
   L2VPN Type            : VPLS                  Redundancy    : None
   Service Interface     : vlan1031
   Created By            : CLI
   Peer IP: 10.200.1.16
      PW State           : Up
      PW Index           : 10018
      PW Signaling       : LDP
      PW Uptime          : 0d:0h:0m:4s
      PW Installed       : True
      Local PW Status    : No Faults
      Remote PW Status   : No Faults
      Remote I/F MTU     : 2000
      PW Mode            : Core-to-Core
      Transport LSP      : LDP LSP (Not Configured)
         Next Hop I/F    : vlan3303
         Next Hop Addr   : 10.200.200.18             Tx Label  : 0x00003
         Tx Pkts         : 2250                      Tx Bytes  : 193500
      PW Rx Label        : 0x0043f                PW Tx Label  : 0x000b6
      PW Rx Pkts         : 0                      PW Tx Pkts   : 2250
      PW Rx Bytes        : 0                      PW Tx Bytes  : 193500
      MAC Limit          : No Limit
      VCCV HC Status     : Not Sending (VCCV Not Enabled For This L2VPN)
         CC Type         : Rtr Alert           Total Pkts Sent : 0
         CV Type         : LSP Ping            Total Pkts Rcvd : 0
         Send Next Pkt   : --
         Total Failures  : 0          Pkts During Last Failure : 0
         Last Failure Tm : --
Что меня очень смущает, так это то, что сессия постоянно падает и встает... Хотя может это нормально поведение.... В дебаге следующее:
debug mpls l2transport vc status event
Dec 22 15:36:42: AToM MGR [10.200.1.2, 1031]: .. Send SSS STATUS(UP)
Dec 22 15:36:42: AToM MGR [10.200.1.2, 1031]: ..  [filtered]
Dec 22 15:36:42: AToM MGR [10.200.1.2, 1031]: Receive SSS STATUS(UP)
И так по кругу.
В случае когда делаю между цисками схема выглядит так : Client(1031 untag)--(1031 untag)Extreme(1031 tag)--(1031 tag)Cisco(1031 untag)--Client(1031 untag). Только другая циска подключена в экстрим по аналогичной схеме.
В таком случае счетчики пакетов вообще не изменяются и состояние канала так же меняется.
Помогите понять, что я делаю неправильно? Возможно даже все:) Но впал в ступор с этой задачи...
 vpn id 1031
Опечатка? Что тут делает xconnect в описании vfi?
0. Что за sup?
1. Найдите из-за чего флапает.
2. Убедитесь что тип ecnapsulation совпадает. Не знаю какие там варианты на экстриме. Обычно с этим проблемы.
3. Очень странно что нет send со стороны циски. Сделайте чтобы было)
В 22.12.2021 в 22:59, vurd сказал:
 vpn id 1031
0. Что за sup?
Ага, опечатка, из sh run | sec подтянулось
0. Supervisor Engine 720 10GE (Active)    VS-S720-10G
1. Вот еще бы понять из-за чего)
3. Сделал чтобы было, перенес xconnect на физический интерфейс - все отлично работает. Теперь вопрос, почему не работает с логическим интерфейсом на влане?
В 23.12.2021 в 16:46, dr Tr0jan сказал:
На SUP2T умеет. На S720 - нет, только MagicCable.
А есть пример на sup2t? Есть пару цисок с ним, но там нет, к примеру, l2 vfi. А обычный xconnect на svi интерфейсе дает:
sup2t(config-if)#xconnect 10.200.1.2 1031 encapsulation mpls
%EoMPLS configuration not allowed on SVIs
Если делать через pseudowire-class с interworking, все однотипно, и та же ошибка. Хотя все доки показывают, что можно делать так Вот, например
Модуль стоит - VS-SUP2T-10G и иос s2t54-advipservicesk9-mz.SPA.155-1.SY3.bin
В 23.12.2021 в 13:09, Avensis сказал:
На суп-2т настраивается как у вас в первом сообщении. Мб в ip сервисах нет поддержки, воткните s2t54-adventerprisek9
l2 vfi v1212 manual
 vpn id 1212
 neighbor 172.16.0.2 encapsulation mpls
 neighbor 172.16.0.3 encapsulation mpls
interface Vlan1212
 no ip address
 xconnect vfi v1212
Оно еще и ip адрес на svi может. Очень удобно.
В 24.12.2021 в 19:49, vurd сказал:
l2 vfi v1212 manual
 vpn id 1212
interface Vlan1212
 no ip address
 xconnect vfi v1212
Попробую обновить до s2t54-adventerprisek9-mz.SPA.155-1.SY4.bin
Edited by Avensis
