По wi-fi, если у меня 3-5 БС, клиент перемещается между ними с wi-fi терминалом, будет ли рватся сессия при переходе с 1й БС на другую? Какое ограничение по скорости перемещения?
Нужен непрерывный доступ к файл серверу и SIP voip (RTP голос).
Как, на чем это посоветуете это сделать если возможно?
У бриз акцесс2 заявляется точно знаю.До 100 км/час
Правда это не совсем ВиФи.
The Nature of Roaming in 802.11
802.11 roaming is known as "break before make," referring to the requirement that a station serves its association with one AP before creating an association with a new one. This process might seem unintuitive because it introduces the possibility for data loss during roaming, but it facilitates a simpler MAC protocol and radio.
If 802.11 were "make before break," meaning a station could associate to a new AP before disassociating from the old AP, you would need safeguards in the MAC to ensure a loop-free topology. A station connected to the same Layer 2 broadcast domain via simultaneous network connections has the potential to trigger broadcast storms. A "make before break" architecture would necessitate an algorithm such as 802.1D spanning tree to resolve any potential loops, adding overhead to the MAC protocol. In addition, the client radio would have to be capable of listening and communicating on more than one channel at a time, increasing the complexity of the radio (and adding to the overall cost of the devices).
Operation of the Application
The way the application operates directly correlates to its resilience during the roaming process. Connection-oriented applications, such as those that are TCP-based, are more tolerant to packet loss incurred during roams because TCP is a reliable and connection-oriented protocol. TCP requires positive acknowledgments, just as the 802.11 MAC does. This requirement allows any 802.11 data lost during the roaming process to be retransmitted by TCP, as the upper-layer protocol.
Although TCP provides a tidy solution for applications running on 802.11 WLANs, some applications rely on User Datagram Protocol (UDP) as the Layer 4 transport protocol of choice. UDP is a low-overhead, connectionless protocol. Applications such as Voice over IP (VoIP) and video use UDP packets. The retransmission capability that TCP offers does little to enhance packet loss for VoIP applications. Retransmitting VoIP packets proves more annoying to the user than useful. As a result, the data-loss roaming might cause a noticeable impact to UDP-based applications.
©Cisco Press - 802.11 Wireless LAN Fundamentals
Ссесия рваться не будет, но будет кратковременное прерывание на 0,5-1,5 сек.
А на любом железе "make before break"? Если какойнибудь DWL AP2100+ будет к свичу L2 включен, или L3 надо?
А как в WiMax вон буржуи планируют VoWLAN, и даже в 802,11 тоже...
