Коллеги, пытаюсь работать с параметром portTrunkAllowedvlan (OID: 1.3.6.1.4.1.40418.7.100.3.2.1.20), но возникли следующие сложности:
Свич нормально отдаёт параметр по выбранному vlan (vlanid 25):
# snmpwalk -v3 -l authPriv -u private -a MD5 -A "private" -x DES -X "private" 192.168.0.1 1.3.6.1.4.1.40418.7.100.3.2.1.20.25
SNMPv2-SMI::enterprises.40418.7.100.3.2.1.20.25 = Hex-STRING: 47 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Но вот с изменением этого параметра есть сложности, команда не воспринимается пакетом snmp:
# snmpset -v3 -l authPriv -u private -a MD5 -A "private" -x DES -X "private" 192.168.0.1 1.3.6.1.4.1.40418.7.100.3.2.1.20.25 x 0x47fffffe00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Error in packet.
Reason: wrongLength (The set value has an illegal length from what the agent expects)
Failed object: SNMPv2-SMI::enterprises.40418.7.100.3.2.1.20.25
Как быть в этом случае? Система FreeBSD 10 amd64 и FreeBSD 13 amd64
@terrible Думаю, вы неправильно задаете VLAN. Попробуйте делать это согласно такому примеру:
#добавить VLAN 12 в vlan-allowed порта 14
snmpset -v2c -c private 192.168.1.1 .1.3.6.1.4.1.40418.7.100.3.2.1.20.14 string 12
#удалить VLAN 12 из vlan-allowed порта 14
snmpset -v2c -c private 192.168.1.1 .1.3.6.1.4.1.40418.7.100.3.12.1.5.14 string 12
В 01.11.2021 в 12:50, Evgeny Mirhasanov сказал:
В этом случае команда работает не как switchport trunk allowed vlan add, а как switchport trunk allowed vlan, т.е. заданные vlan-id в этом случае не добавляются, а заменяют имеющиеся значения в конфигурации порта.
В целом норм, у нас всё работает корректно с указанными OID. Спасибо за подсказку, особенно по поводу string значений, вместо hex
@terrible
Да, вы правы. Ввел в заблуждение.
