петля на порту клиента кладет транковый порт CRS125-24G-1S
добрый день, коллеги
прошу помощи в таком вопросе
есть CRS125-24G-1S, в sfp1 - аплинк.
настроено 100-mgmt_tag и 200-ppp_untag. Все юзеры по PPPoE сидят на брасе выше он в 200 влане вещает.
настроено так:
/interface ethernet
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full arp=disabled loop-protect=on
set [ find default-name=ether24 ] advertise=10M-half,10M-full,100M-half,100M-full arp=disabled disabled=yes loop-protect=on
set [ find default-name=sfp1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=disabled comment="UP_Gi1/3" loop-protect=on
/interface bridge
add name=bridge1
/interface vlan
add comment=mgmt interface=bridge1 name=vlan100 vlan-id=100
/interface ethernet switch
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports=ether1,.....,ether24 forward-unknown-vlan=no
/interface bridge port
add bridge=bridge1 interface=ether1
add bridge=bridge1 interface=ether24
add bridge=bridge1 interface=sfp1
/interface ethernet switch egress-vlan-tag
add tagged-ports=sfp1,switch1-cpu vlan-id=100
add tagged-ports=sfp1 vlan-id=200
/interface ethernet switch egress-vlan-translation
add comment=PPPOE customer-vid=200 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether1,.....,ether24 service-vlan-format=untagged-or-tagged
/interface ethernet switch ingress-vlan-translation
add comment=PPPOE customer-vid=0 new-customer-vid=200 ports=ether1,.....,ether24
/interface ethernet switch port
set 0 isolation-leakage-profile-override=1 learn-limit=1
set 23 isolation-leakage-profile-override=1 learn-limit=1
set 24 isolation-leakage-profile-override=0
set 25 isolation-leakage-profile-override=0
/interface ethernet switch port-isolation
add port-profile=1 ports=sfp1,switch1-cpu type=dst
/interface ethernet switch vlan
add ports=sfp1,switch1-cpu vlan-id=100
add ports=ether1,......,ether24,sfp1 vlan-id=200
сейчас вижу на 22 и 24 порту одноврменно падает и ложится линк, после чего срабатывает STP на уровне выше(%SPANTREE-2-BLOCK_PVID_LOCAL: Blocking GigabitEthernet1/3 on VLAN0200. Inconsistent local vlan.) и порт гасится.
я так понимаю с двух портов собрали петлю, или проблема с оборудкой клиента.
думаю нужно зафильтровать все лишнее, подскажите как можно на ROS зафильтровать все кроме pppoe... пробовал bridge filters 8863 и 8864 разрешить и остальное дропнуть на бридже, но эффекта нет, в правила по accept ничего не попадает:
/interface bridge filter
add action=accept chain=forward in-bridge=bridge1 mac-protocol=pppoe-discovery out-bridge=bridge1
add action=accept chain=forward in-bridge=bridge1 mac-protocol=pppoe out-bridge=bridge1
add action=drop chain=forward in-bridge=bridge1 out-bridge=bridge1
или может есть какие-то иные true tone решения
Edited by jone31
