Добрый день.
Часто проявляются зависания ssh сессий на snr 2995G(очень редко на 2985), особенно при запросе sh arp или sh run
При этом, если работать через telnet - все ок.
Не зависит ни от того, насколько далеко расположен, ни от версии прошивки (зоопарк от 110 до 385)
sh ver
  SNR-S2995G-24TX Device, Compiled on Sep 22 12:59:02 2021
  sysLocation Building 57/2,Predelnaya st, Ekaterinburg, Russia
  CPU Mac f8:f0:82:7c:91:27
  Vlan MAC f8:f0:82:7c:91:26
  SoftWare Package Version 7.5.3.2(R0004.0385)
  BootRom Version 7.5.21
  HardWare Version 1.0.1
  CPLD Version 2.00
  Serial No.:SW078410L316000108
  Copyright (C) 2021 NAG LLC
  All rights reserved
  Last reboot is cold reset.
  Uptime is 0 weeks, 0 days, 15 hours, 20 minutes
sh run
switch convert mode stand-alone
service password-encryption
hostname NSK-SW1-LVL3
sysContact support@nag.ru
authentication logging enable
username admin privilege 15 password 7
authentication line console login local
ssh-server enable
info-center logfile 4 config count 40960 nandflash logfile.log
info-center logfile 4 output-enable
info-center logfile 4 match level warnings
no ip http server
snmp-server enable
snmp-server securityip disable
snmp-server community ro 7
service dhcp
ip forward-protocol udp bootps
ip dhcp snooping enable
ip dhcp snooping vlan 24-26;30-31
 ip dhcp snooping binding enable
ip dhcp snooping broadcast suppress
lldp enable
Interface Ethernet0
vlan 1
vlan 24
 name NSK-Servers
vlan 25
 name NSK-Workstations
vlan 26
 name NSK-Printers
vlan 28
 name NSK-Guest-Wifi
vlan 29
 name Video-Net
vlan 30
 name NSK-MGMT
vlan 31
 name BGP-NET
vlan 100
 name IPMI
vlan 502
 name INTERNET
ip access-list extended GUEST-WIFI
  deny ip 172.16.28.0 0.0.0.255 192.168.0.0 0.0.255.255
  deny ip 172.16.28.0 0.0.0.255 10.0.0.0 0.255.255.255
  deny ip 172.16.28.0 0.0.0.255 172.16.0.0 0.15.255.255
  deny ip 192.168.0.0 0.0.255.255 172.16.28.0 0.0.0.255
  deny ip 10.0.0.0 0.255.255.255 172.16.28.0 0.0.0.255
  deny ip 172.16.0.0 0.15.255.255 172.16.28.0 0.0.0.255
  permit ip any-source any-destination
  exit
vacl ip access-group GUEST-WIFI in vlan 28
vacl ip access-group GUEST-WIFI out vlan 28
Interface Ethernet1/0/1
 description IPMI
 switchport access vlan 100
Interface Ethernet1/0/2
 description Internet_IN
 switchport access vlan 502
Interface Ethernet1/0/3
 description NSH1_Internet
Interface Ethernet1/0/4
 description NSH2_Internet
Interface Ethernet1/0/5
Interface Ethernet1/0/6
Interface Ethernet1/0/7
 description NSH1_Local_Net
 switchport mode trunk
Interface Ethernet1/0/8
 description NSH2_Local_Net
Interface Ethernet1/0/9
Interface Ethernet1/0/10
Interface Ethernet1/0/11
 description HPE_Upper_Trunk
 switchport access vlan 24
Interface Ethernet1/0/12
Interface Ethernet1/0/13
 description HPE_Switch_Users
Interface Ethernet1/0/14
Interface Ethernet1/0/15
Interface Ethernet1/0/16
Interface Ethernet1/0/17
Interface Ethernet1/0/18
 description Video-REG
 switchport access vlan 29
Interface Ethernet1/0/19
 description Wifi-Spot
 switchport mode hybrid
 switchport hybrid allowed vlan 25;28 tag
 switchport hybrid allowed vlan 30 untag
 switchport hybrid native vlan 30
Interface Ethernet1/0/20
 description NSK-APC
 switchport access vlan 30
Interface Ethernet1/0/21
 description NSBK(teaming)
Interface Ethernet1/0/22
Interface Ethernet1/0/23
 description NSK-SW4-POE(HPE2530-24)
Interface Ethernet1/0/24
 description MIKROTIK_Internet_IN
Interface Ethernet1/0/25
Interface Ethernet1/0/26
Interface Ethernet1/0/27
Interface Ethernet1/0/28
interface Vlan1
 ip address 192.168.1.70 255.255.255.0
interface Vlan24
 ip address 172.16.24.1 255.255.255.0
 ip address 172.16.24.254 255.255.255.0 secondary
  !forward protocol udp 67(active)!
 ip helper-address 172.16.24.240
interface Vlan25
 ip address 172.16.25.1 255.255.255.0
interface Vlan26
 ip address 172.16.26.1 255.255.255.0
interface Vlan28
 description NSK-Guest-Wifi
 ip address 172.16.28.1 255.255.255.0
interface Vlan29
 description Video-Net
 ip address 172.16.29.1 255.255.255.0
interface Vlan30
 ip address 172.16.30.1 255.255.255.0
interface Vlan31
 ip address 172.16.31.1 255.255.255.0
interface Vlan100
 ip address 172.17.104.28 255.255.255.248
router bgp 64520
 bgp router-id 172.16.31.1
 redistribute connected
 neighbor 172.16.31.2 remote-as 64520
 neighbor 172.16.31.2 next-hop-self
 neighbor 172.16.31.2 soft-reconfiguration inbound
 neighbor 172.16.31.3 remote-as 64520
 neighbor 172.16.31.3 next-hop-self
 neighbor 172.16.31.3 soft-reconfiguration inbound
no login
captive-portal
end
sh cpu-rx protocol all
--------------------------Slot : 1----------------------
Type                Rate-limit    TotPkts        DropPkts       DelayCount     CurState
ALL_ARP             400           0              0              0              allowed
ARP                 400           81072          0              0              allowed
BFD                 200           0              0              0              allowed
BFD6                200           0              0              0              allowed
BGP                 200           3984           0              0              allowed
BGP4+               200           0              0              0              allowed
BPDU_TUNNEL         80            0              0              0              allowed
CFM_OAM             300           0              0              0              allowed
CFM_OTHER           200           0              0              0              allowed
CLUSTER-DP          300           0              0              0              allowed
CLUSTER-DR          300           0              0              0              allowed
DHCP                200           11021          0              0              allowed
DHCP-SNOOPING       200           11026          0              0              allowed
DHCP_SUPPRESS       200           0              0              0              allowed
DHCPv6              200           0              0              0              allowed
DHCPv6-SNOOPING     200           0              0              0              allowed
DMAC-CPU            300           0              0              0              allowed
DNS                 100           39             0              0              allowed
DOT1x               200           0              0              0              allowed
Dot1x-pass          200           0              0              0              allowed
EAPOU               100           0              0              0              allowed
EFMOAM              40            0              0              0              allowed
ERPS                20            0              0              0              allowed
FTP                 500           0              0              0              allowed
FTP6                500           0              0              0              allowed
GMRP                20            0              0              0              allowed
GVRP                20            0              0              0              allowed
HSRP                100           0              0              0              allowed
HTTP                200           0              0              0              allowed
HTTP6               200           0              0              0              allowed
HTTPS/SSL           200           0              0              0              allowed
HTTPS6/SSL6         200           0              0              0              allowed
ICMP                100           5717           0              0              allowed
ICMP-REDIRECT       50            0              0              0              allowed
ICMP_TRAP_FAIL      100           0              0              0              allowed
IGMP                200           0              0              0              allowed
IPV6-HOPLIMIT       100           0              0              0              allowed
IPv6-NTP            50            0              0              0              allowed
LACP                20            0              0              0              allowed
LDP                 200           0              0              0              allowed
LLDP                20            9084           0              0              allowed
LOOPBACK            20            0              0              0              allowed
MLD                 200           0              0              0              allowed
MRPP                20            0              0              0              allowed
MULTICAST           20            0              0              0              allowed
MULTICAST6          20            0              0              0              allowed
NDP-SNOOPING        500           0              0              0              allowed
NORMAL              500           596            0              0              allowed
NS-NA               500           379            0              0              allowed
NTP                 50            1576           0              0              allowed
OFP-CONTROL         100           0              0              0              allowed
OFP-NOTMATCH        100           0              0              0              allowed
OSPF                100           0              0              0              allowed
OSPF6               100           0              0              0              allowed
PIM                 200           0              0              0              allowed
PIM6                200           0              0              0              allowed
PPPoE               100           0              0              0              allowed
PROTECT_ARP         50            0              0              0              allowed
PROTECT_ICMP        60            0              0              0              allowed
RA-SNOOPING         100           0              0              0              allowed
RADIUS              200           0              0              0              allowed
RADIUS6             200           0              0              0              allowed
RIP                 100           0              0              0              allowed
RIP6                100           0              0              0              allowed
RS-RA               100           39             0              0              allowed
SFLOW               50            0              0              0              allowed
SNMP                500           1432479        0              0              allowed
SNMP6               500           0              0              0              allowed
SSH                 100           100            0              0              allowed
SSH6                100           0              0              0              allowed
STP                 80            0              0              0              allowed
Stacking_C2C_Pro    200           0              0              0              allowed
TACAS               100           0              0              0              allowed
TACAS6              100           0              0              0              allowed
TELNET              100           83             0              0              allowed
TELNET6             100           0              0              0              allowed
TFTP                500           0              0              0              allowed
TFTP6               500           0              0              0              allowed
TYPE-TTL0           100           0              0              0              allowed
ULDP                20            0              0              0              allowed
ULPP                300           0              0              0              allowed
UNKNOWN_SMAC        100           0              0              0              allowed
VRRP                100           0              0              0              allowed
VRRP6               100           0              0              0              allowed
TOTAL-LIMIT         1200                                                       allowed
Добрый день. Нет, в большинстве spf устройства вообще не используются, только медь.
Я думаю стоит уточнить вот еще что. Связь с ними идет в большинстве через gre - может быть нужен какой то тюнинг mtu\mss?
13 минут назад, Evgeny Mirhasanov сказал:
sh cpu utilization
В пределах 15%
Возникает с завидной регулярностью, я бы сказал через раз-два.
Цитата
Это какое-то стороннее оборудование запаковывает SSH трафик и распаковывает его между вами и SNR?
Маршрутизаторы, между которыми есть цепочка mgre туннелей.
т.е. схема такая: ssh_client<медь>R1<gre>R2<медь>SNR с проблемами ssh (роутеры на линуксах, без NAT\PAT)
Edited by sorokin.a
26 минут назад, Evgeny Mirhasanov сказал:
@sorokin.a Есть ли возможность проверить SHH подключение минуя GRE туннели? Загрузка CPU столько мала и счетчики в cpu-rx без единого дропа, что вызывает недоумение почему SSH сеанс тормозит.
Осознал, что ищу проблему не там.
Спасибо.
Edited by sorokin.a
