Доброго времени суток. Наблюдается проблема с DHCP Snooping(ом) на свитче 2962-24Т и 2965-24T. В рандомный момент люди перестают получать IP адрес, причём это происходит в хаотичном порядке. Возникает вопрос, может я что-то не так настроил?
service password-encryption
hostname SNR-S2962-24T
sysContact support@nag.ru
authentication line console login local
logging *.*.*.*
ssh-server enable
snmp-server enable
snmp-server securityip *.*.*.*
snmp-server community ro 7 *.*.*.*
snmp-server user initial initial
snmp-server group *.*.*.*  noauthnopriv read Community
snmp-server view CommunityView 1. include
snmp-server view CommunityView 1.3.6.1.6.3. exclude
snmp-server enable traps
ip forward-protocol udp bootps
ip dhcp snooping enable
loopback-detection interval-time 10 3
loopback-detection control-recovery timeout 30
loopback-detection trap enable
storm-control pps
vlan 1
vlan 250
 name manager
access-list 110 deny tcp any-source any-destination d-port 135
access-list 110 deny tcp any-source any-destination d-port 136
access-list 110 deny tcp any-source any-destination d-port 137
access-list 110 deny tcp any-source any-destination d-port 138
access-list 110 deny tcp any-source any-destination d-port 139
access-list 110 deny tcp any-source any-destination d-port 445
access-list 110 deny tcp any-source any-destination d-port 1900
access-list 110 deny tcp any-source any-destination d-port 2869
access-list 110 deny udp any-source any-destination d-port 135
access-list 110 deny udp any-source any-destination d-port 136
access-list 110 deny udp any-source any-destination d-port 137
access-list 110 deny udp any-source any-destination d-port 138
access-list 110 deny udp any-source any-destination d-port 139
access-list 110 deny udp any-source any-destination d-port 445
access-list 110 deny udp any-source any-destination d-port 1900
access-list 110 deny udp any-source any-destination d-port 2869
access-list 110 permit ip any-source any-destination
access-list 110 deny tcp any-source s-port 135 any-destination
access-list 110 deny udp any-source s-port 135 any-destination
access-list 110 deny tcp any-source s-port 136 any-destination
access-list 110 deny udp any-source s-port 136 any-destination
access-list 110 deny tcp any-source s-port 137 any-destination
access-list 110 deny udp any-source s-port 137 any-destination
access-list 110 deny tcp any-source s-port 138 any-destination
access-list 110 deny udp any-source s-port 138 any-destination
access-list 110 deny tcp any-source s-port 139 any-destination
access-list 110 deny udp any-source s-port 139 any-destination
access-list 110 deny tcp any-source s-port 445 any-destination
access-list 110 deny udp any-source s-port 445 any-destination
access-list 110 deny tcp any-source s-port 1900 any-destination
access-list 110 deny udp any-source s-port 1900 any-destination
access-list 110 deny tcp any-source s-port 2869 any-destination
access-list 110 deny udp any-source s-port 2869 any-destination
userdefined-access-list standard offset window1 l4start 0 window2 l4start 2
ip multicast source-control
Interface Ethernet1/0/1                     //Абоненский порт
 storm-control broadcast 16
 storm-control multicast 16
 ip access-group 110 in traffic-statistic
 loopback-detection specified-vlan 1
 loopback-detection control shutdown
 ip dhcp snooping action blackhole recovery 3600
Interface Ethernet1/0/24                    //Uplink порт
 switchport mode trunk
 switchport trunk allowed vlan 250
 ip dhcp snooping trust
interface Vlan250
 ip address *.*.*.*  255.0.0.0
sntp server *.*.*.*  version 2
no login
captive-portal
end
В логах пусто, не на что не ругается.
Заметил что, помогает ребут свитча либо отключение dhcp snooping - "no ip dhcp snooping" . Пока ответа не нашёл на данный вопрос...Заранее благодарю за ответ.
9 минут назад, Aleksey Sonkin сказал:
@Kroys
Добрый день!
Покажите 'sh ver'.
CPU Mac f8:f0:82:7b:9a:8c
  Vlan MAC f8:f0:82:7b:9a:8b
  SoftWare Version 7.0.3.5(R0241.0465)
  BootRom Version 7.2.40
  HardWare Version 1.0.1
  CPLD Version N/A
  Serial No.:SW077510KA14000539
  Copyright (C) 2021 NAG LLC
  All rights reserved
  Last reboot is warm reset.
  Uptime is 1 weeks, 4 days, 17 hours, 34 minutes
