Владимир320 Posted August 6, 2021 Posted August 6, 2021 Вечер добрый. Есть очень странное поведение портов на этих свичах, лог: I 08/06/21 07:53:25 00077 ports: port 34 is now off-line I 08/06/21 07:53:28 00076 ports: port 34 is now on-line I 08/06/21 07:53:35 00077 ports: port 24 is now off-line I 08/06/21 07:53:38 00076 ports: port 24 is now on-line I 08/06/21 07:53:40 00077 ports: port 34 is now off-line I 08/06/21 07:53:44 00076 ports: port 34 is now on-line I 08/06/21 07:53:50 00077 ports: port 24 is now off-line I 08/06/21 07:53:54 00076 ports: port 24 is now on-line I 08/06/21 07:53:55 00077 ports: port 46 is now off-line I 08/06/21 07:53:58 00076 ports: port 46 is now on-line I 08/06/21 07:54:08 00076 ports: port 44 is now on-line I 08/06/21 07:54:08 00077 ports: port 46 is now off-line I 08/06/21 07:54:12 00076 ports: port 46 is now on-line I 08/06/21 07:54:39 00077 ports: port 44 is now off-line I 08/06/21 07:54:42 00076 ports: port 44 is now on-line I 08/06/21 07:54:54 00077 ports: port 44 is now off-line I 08/06/21 07:55:09 00076 ports: port 44 is now on-line I 08/06/21 07:55:37 00077 ports: port 42 is now off-line I 08/06/21 07:55:41 00076 ports: port 42 is now on-line I 08/06/21 07:55:43 00077 ports: port 42 is now off-line I 08/06/21 07:55:49 00077 ports: port 38 is now off-line I 08/06/21 07:55:54 00076 ports: port 38 is now on-line I 08/06/21 07:55:58 00076 ports: port 42 is now on-line I 08/06/21 07:56:06 00077 ports: port 38 is now off-line I 08/06/21 07:56:08 00077 ports: port 42 is now off-line I 08/06/21 07:56:09 00076 ports: port 38 is now on-line I 08/06/21 07:56:12 00076 ports: port 42 is now on-line I 08/06/21 07:57:37 00077 ports: port 42 is now off-line I 08/06/21 07:57:40 00076 ports: port 42 is now on-line I 08/06/21 07:57:51 00077 ports: port 42 is now off-line I 08/06/21 07:57:55 00076 ports: port 42 is now on-line I 08/06/21 08:02:08 00077 ports: port 30 is now off-line I 08/06/21 08:02:11 00076 ports: port 30 is now on-line I 08/06/21 08:02:13 00077 ports: port 30 is now off-line I 08/06/21 08:03:08 00077 ports: port 42 is now off-line I 08/06/21 08:03:11 00076 ports: port 42 is now on-line I 08/06/21 08:03:22 00077 ports: port 42 is now off-line I 08/06/21 08:03:26 00076 ports: port 42 is now on-line Происходит вот такая колбасня с портами. Проверил всю физику, все норм. Что за ерунда такая с портами? Бывало такое у кого? Происходит это 2-3 раза в сутки и не всегда с теме же портами. Конфиг на свиче минимальный: trunk 47-48 trk1 lacp ip default-gateway 172.17.209.254 vlan 1 name "DEFAULT_VLAN" no untagged 1-46,Trk1 untagged 49-52 no ip address exit vlan 166 name "LAN" untagged 1-46 tagged Trk1 no ip address exit vlan 709 name "MGMT" tagged Trk1 ip address 172.17.209.251 255.255.255.0 exit Кто сталкивался с таким просьба помочь, а то превращается все в головную боль с этими свичами Вставить ник Quote
jffulcrum Posted August 6, 2021 Posted August 6, 2021 А что на другой стороне проблемных портов? Вставить ник Quote
Владимир320 Posted August 6, 2021 Author Posted August 6, 2021 58 минут назад, jffulcrum сказал: А что на другой стороне проблемных портов? Просто компы Вставить ник Quote
witch Posted August 7, 2021 Posted August 7, 2021 Попробуйте зажать на обоих сторонах скорость и дуплекс Вставить ник Quote
jffulcrum Posted August 7, 2021 Posted August 7, 2021 Проблемы с кабельным хозяйством исключены (к примеру, поменять патч-корды на проблемных линках)? Фирмварь последняя? Вставить ник Quote
VolanD666 Posted August 7, 2021 Posted August 7, 2021 Может дело в свиче? Такое ощущения что конкретная порт-группа отваливается. Хз как там у арубы это сделано архитектурно. Вставить ник Quote
jffulcrum Posted August 7, 2021 Posted August 7, 2021 Ну, я бы сперва show interfaces all посмотрел, что со счетчиками. Может там качество сети в хламину. Вставить ник Quote
Владимир320 Posted August 8, 2021 Author Posted August 8, 2021 16 часов назад, witch сказал: Попробуйте зажать на обоих сторонах скорость и дуплекс Не помогло Никаких ошибок нет, просто в логах такая ерунда. Пока решил поменять эти непонятные хп на циски Вставить ник Quote
Владимир320 Posted August 8, 2021 Author Posted August 8, 2021 (edited) 11 часов назад, jffulcrum сказал: Проблемы с кабельным хозяйством исключены (к примеру, поменять патч-корды на проблемных линках)? Фирмварь последняя? Пока неизвестно, поеду проверять. Фирмварь последняя. Надеюсь все решится заменой hp, их кстати две штуки и на обоих одинаковое поведение. Вообще согласен, что проблема идиотская просто ехать 400км) и была надежда на прошивку, какие нить crc на портах, обжимка, да и больше хз на что еще там смотреть при такой проблеме Edited August 8, 2021 by Владимир320 Вставить ник Quote
zhenya` Posted August 8, 2021 Posted August 8, 2021 Поди какой-то energy saving на стороне компа Вставить ник Quote
jffulcrum Posted August 8, 2021 Posted August 8, 2021 @Владимир320 show interfaces all сделайте и изучите статистику по ошибкам. Чаще всего такое у HP когда с другой стороны или по LACP пытаются что-то строить - но вроде не ваш случай, у вас компы, либо когда есть объективные проблемы с кабельным хозяйством. Вставить ник Quote
Владимир320 Posted August 9, 2021 Author Posted August 9, 2021 21 час назад, jffulcrum сказал: @Владимир320 show interfaces all сделайте и изучите статистику по ошибкам. Чаще всего такое у HP когда с другой стороны или по LACP пытаются что-то строить - но вроде не ваш случай, у вас компы, либо когда есть объективные проблемы с кабельным хозяйством. Drops Tx в небольших количествах тока и се Вставить ник Quote
SUrov_IBM Posted August 9, 2021 Posted August 9, 2021 14 часов назад, Владимир320 сказал: Drops Tx в небольших количествах тока и се Владимир320, здравствуйте. Возможно, скажу глупость – у Вас компьютеры, подключённые к данным портам коммутатора, выключаются в конце рабочего дня или в течение дня переходят в «спящий режим»? Просто при выключении (и возможно в «спящий режим»), карточка переходит в 10 Мб/Сек. для ожидания «волшебного пакета» включения ПК. Вставить ник Quote
kapydan Posted August 11, 2021 Posted August 11, 2021 В 07.08.2021 в 16:31, VolanD666 сказал: Может дело в свиче? Aruba 2530 48 PoE+ Switch было такое, но не с пк - а с поешными камерами. несколько раз в сутки все порты с конечными устройствами отваливались. открыл кейс в хп - заменили по гарантии в итоге. Вставить ник Quote
Владимир320 Posted August 13, 2021 Author Posted August 13, 2021 В общем снял арубы, поставил хуавейки. И СКС была в ужасном состоянии, чуть тронешь линки пляшут, щас все норм Вставить ник Quote
