pukoid Posted July 26, 2021 Posted July 26, 2021 Есть на cat 3570x (15.2(4)E10) несколько lacp etherchannel-ов. Как бы их не нагружал LOAD на портах всегда ноль-повдоль. В интернетах пишут, что, должно показывать нагрузку на порты. c3750x-24-core#sh etherchannel 4 port-channel Port-channels in the group: --------------------------- Port-channel: Po4 (Primary Aggregator) ------------ Age of the Port-channel = 0d:03h:06m:21s Logical slot/port = 10/4 Number of ports = 2 HotStandBy port = null Port state = Port-channel Ag-Inuse Protocol = LACP Port security = Disabled Load share deferral = Disabled Ports in the Port-channel: Index Load Port EC state No of bits ------+------+------+------------------+----------- 0 00 Gi1/0/23 Active 0 0 00 Gi1/0/24 Active 0 Time since last port bundled: 0d:03h:06m:10s Gi1/0/24 Time since last port Un-bundled: 0d:03h:13m:20s Gi1/0/24 Нагрузил по гланды - до 2 гбит с помощью 3 машинок (у одной intel nic teaming драйвером под виндой). Просто на интерфейсе нагрузку пишет txload 251/255 : c3750x-24-core#sh int po4 Port-channel4 is up, line protocol is up (connected) Hardware is EtherChannel, address is 2894.0f02.3818 (bia 2894.0f02.3818) MTU 9198 bytes, BW 2000000 Kbit/sec, DLY 10 usec, reliability 255/255, txload 251/255, rxload 1/255 Включил хистори на интерфейсе - тоже : c3750x-24-core#sh int po4 history 111111111111111111111111111111111111111111111111111111111111 999999999999999999999999999999999999999999999999999999999999 666677777777777777777777777777777777777777777777766666666666 999900000000000000000000000000000000000000000000099999999999 1970 ********************************************* 1969 ********************************************************** 1968 ********************************************************** 1967 ********************************************************** 1966 ********************************************************** 1965 ********************************************************** 1964 ********************************************************** 1963 ********************************************************** 1962 ********************************************************** 1961 ********************************************************** 1960 ********************************************************** 0....5....1....1....2....2....3....3....4....4....5....5....6 0 5 0 5 0 5 0 5 0 5 0 Port-channel4 output rate(mbits/sec) (last 60 seconds) Тоже с загрузкой всё в порядке. Кто-нибудь знает, что это за load такой? Вставить ник Quote
kapydan Posted July 28, 2021 Posted July 28, 2021 SW-121#sh int po21 Port-channel21 is up, line protocol is up (connected) Hardware is EtherChannel, address is 5c5a.c777.d9b1 (bia 5c5a.c777.d9b1) MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 10Gb/s, link type is auto, media type is N/A input flow-control is on, output flow-control is unsupported Members in this channel: Te1/1/1 ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 18:54:27, output hang never Last clearing of "show interface" counters never Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 1168000 bits/sec, 231 packets/sec 5 minute output rate 285000 bits/sec, 120 packets/sec 11422197914 packets input, 7042891678809 bytes, 0 no buffer Received 1867599482 broadcasts (1206606299 multicasts) 0 runts, 0 giants, 0 throttles 6269242 input errors, 6246123 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 1206606299 multicast, 0 pause input 0 input packets with dribble condition detected 5065313643 packets output, 1777631996223 bytes, 0 underruns 0 output errors, 0 collisions, 1 interface resets 0 unknown protocol drops 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 pause output 0 output buffer failures, 0 output buffers swapped out может про это речь? Вставить ник Quote
pukoid Posted July 28, 2021 Author Posted July 28, 2021 Вот про это: c3750x-24-core#sh etherchannel 4 port-channel ... Index Load Port EC state No of bits ------+------+------+------------------+----------- 0 00 Gi1/0/23 Active 0 0 00 Gi1/0/24 Active 0 Вставить ник Quote
kapydan Posted July 28, 2021 Posted July 28, 2021 значит, что балансировка не настроена в езерченнеле https://www.cisco.com/c/en/us/support/docs/lan-switching/etherchannel/116385-technote-etherchannel-00.html Вставить ник Quote
passer Posted July 28, 2021 Posted July 28, 2021 Не знаю, как на 3570x, но на 4948e и 3750g тоже нули при идеальной почти балансировке. Вставить ник Quote
pppoetest Posted July 28, 2021 Posted July 28, 2021 2 часа назад, passer сказал: Не знаю, как на 3570x, но на 4948e и 3750g тоже нули при идеальной почти балансировке. 4500x такая же херня. Вставить ник Quote
kapydan Posted July 28, 2021 Posted July 28, 2021 9 часов назад, passer сказал: Не знаю, как на 3570x, но на 4948e и 3750g тоже нули при идеальной почти балансировке. на 9300 и 9500 тоже 00 Вставить ник Quote
guеst Posted July 29, 2021 Posted July 29, 2021 (edited) c6506-1#sh etherchannel 12 port-channel Port-channels in the group: ---------------------- Port-channel: Po12 (Primary Aggregator) ------------ Age of the Port-channel = 65d:16h:32m:41s Logical slot/port = 14/7 Number of ports = 2 HotStandBy port = null Port state = Port-channel Ag-Inuse Protocol = LACP Fast-switchover = disabled Load share deferral = disabled Ports in the Port-channel: Index Load Port EC state No of bits ------+------+------------+------------------+----------- 0 55 Te5/5 Active 4 1 AA Te6/5 Active 4 Time since last port bundled: 64d:17h:44m:50s Te6/5 Time since last port Un-bundled: 64d:17h:50m:25s Te6/5 Edited July 29, 2021 by guеst Вставить ник Quote
pukoid Posted July 29, 2021 Author Posted July 29, 2021 Видимо, это фишка исключительно шеститонников и нексусов. У нексуса тоже куча параметров для настройки балансировки - https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/6_x/nx-os/interfaces/configuration/guide/b-Cisco-Nexus-7000-Series-NX-OS-Interfaces-Configuration-Guide-6x-Book/configuring_port___channels.html Вставить ник Quote
guеst Posted July 29, 2021 Posted July 29, 2021 видимо да... nexus5548-2# sh port-channel traffic int port-channel 99 ChanId Port Rx-Ucst Tx-Ucst Rx-Mcst Tx-Mcst Rx-Bcst Tx-Bcst ------ --------- ------- ------- ------- ------- ------- ------- 99 Eth1/29 56.46% 48.94% 75.62% 24.74% 51.33% 0.00% 99 Eth1/30 43.53% 51.05% 24.37% 75.25% 48.66% 99.99% Вставить ник Quote
