настроили по конфигу внизу
ONU видит но мак адреса в таблице не появляются
что не так настроено ?
Current configuration:
!version 10.3.0D build 80339
service timestamps log date
service timestamps debug date
service password-encryption
port-protected 1
spanning-tree mode rstp
ip access-list standard MANAGEMENT
 permit  192.168.10.254 255.255.255.0
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
username admin password 7 045b037b0d07096b157f
enable password 7 045b037b0d07096b157f level 15
gpon profile onu-rate-limit ratelimit-default id 1
 gpon-profile pir 1244160 cir 1244160
gpon profile onu-tcont tcont-default id 1
 gpon-profile tcont-type 3 pir 1024000 cir 512
gpon profile onu-virtual-port virtual-port-default id 1
 gpon-profile encryption disable
 gpon-profile upstream queue 8
 gpon-profile downstream queue 8
gpon profile onu-tcont-virtual-port-bind tvbind-default id 1
 gpon-profile virtual-port 1 profile virtual-port-default tcont 1 profile tcont-
default
gpon profile onu-flow-mapping flow-mapping-default id 1
 gpon-profile entry 1 uni type eth-uni all
 gpon-profile entry 1 vlan 10
 gpon-profile entry 1 virtual-port 1
gpon profile onu-flow-mapping flow-mapping-default-hgu id 2
 gpon-profile entry 1 uni type veip all
gpon profile onu-flow-mapping flow-mapping-defaultid id 3
gpon profile onu-vlan ONU-VLAN-10 id 3
 gpon-profile vlan mode tag
 gpon-profile vlan pvid 10 0
gpon onutype-template onutype-default-hgu
 gpon-onutype match ctc-onu-type HGU
 gpon-onutype config tcont-virtual-port-bind-profile tvbind-default
 gpon-onutype config flow-mapping-profile flow-mapping-default-hgu
gpon onu-config-template internet
 cmd-sequence 001 gpon onu tcont-virtual-port-bind-profile tvbind-default
 cmd-sequence 002 gpon onu flow-mapping-profile flow-mapping-default
 cmd-sequence 003 gpon onu uni 1 vlan-profile ONU-VLAN-10
interface Null0
interface GigaEthernet0/0
 no ip address
!!slot 0 1 GP3600-08B mother card
interface GigaEthernet0/1
 description UPLINK
 switchport trunk vlan-allowed 208,226
 switchport trunk vlan-untagged none
 switchport mode dot1q-tunnel-uplink
  dhcp snooping trust
 storm-control broadcast threshold 5
 storm-control multicast threshold 5
 storm-control unicast threshold 5
interface GigaEthernet0/2
 description internet
 switchport trunk vlan-allowed 10
 switchport pvid 226
 loopback-detection enable
 loopback-detection control shutdown
interface GigaEthernet0/3
 shutdown
interface GigaEthernet0/4
 shutdown
interface GigaEthernet0/5
 shutdown
interface GigaEthernet0/6
 shutdown
interface GigaEthernet0/7
 shutdown
interface GigaEthernet0/8
 shutdown
interface TGigaEthernet0/1
 shutdown
interface TGigaEthernet0/2
 shutdown
interface TGigaEthernet0/3
 shutdown
interface TGigaEthernet0/4
 shutdown
interface GPON0/1
 gpon pre-config-template internet bind-onuid 1-128
 gpon bind-onutype onutype-default-hgu precedence 127
 gpon bind-onutype onutype-default precedence 128
 gpon bind-onu sn 48575443E6CB5A2F 1
 switchport mode trunk
 switchport protected 1
interface GPON0/1:1
 gpon onu equipment-id FD511G-X
 gpon onu virtual-port 1 gem-port 256
 gpon onu tcont 1 alloc-id 256
interface GPON0/2
 gpon bind-onu sn 48575443E6CB5A11 1
interface GPON0/2:1
interface GPON0/3
 shutdown
interface GPON0/4
 shutdown
interface GPON0/5
 shutdown
interface GPON0/6
 shutdown
interface GPON0/7
 shutdown
interface GPON0/8
 shutdown
!!slot end
interface VLAN208
 description management
 ip address 192.168.10.2 255.255.255.0
 no ip directed-broadcast
vlan 10
 name internet_trafic
vlan 1,10,226
 loopback-detection
ip route default 192.168.10.1
ip exf
ipv6 exf
ip telnet access-class MANAGEMENT
ip telnet attack-defense
!Pending configurations for absent linecards:
!No configurations pending global
