Добрый день,
Коммутатор S300X-24FQ
  SoftWare Package Version 7.5.3.2(R0010.0106)
  BootRom Version 7.5.6
  HardWare Version 1.0.1
Втыкаю SFPиху, коммутатор ее видит но порт не поднимает. в соседнем старом длинке все работает, куда рыть?
#>show transceiver int e1/0/13 detail
Ethernet1/0/13 transceiver detail information:
Base information:
  SFP found in this port, manufactured by OEM, on Sep 04 2012.
  Type is unknown.  Serial number is PC91740290.
  Link length is 10000 m for Single Mode Fiber.
  Nominal bit rate is 1300 Mb/s.
  Laser wavelength is 1550 nm.
Brief alarm information: N/A
Detail diagnostic and threshold information: N/A
#>show transceiver int e1/0/15 detail
Ethernet1/0/15 transceiver detail information:
Base information:
  SFP found in this port, manufactured by CISCO-FINISAR, on Mar 01 2004.
  Type is 1000BASE-LX.  Serial number is H11L346.
  Link length is 550 m for 50um Multi-Mode OM2 Fiber.
  Link length is 550 m for 62.5um Multi-Mode OM1 Fiber.
  Laser wavelength is 1310 nm.
порт в 1g переводили?
sh run int eth 1/0/13
speed-duplex force1g-full
sh interface ethernet 1/0/13
Interface brief:
  Ethernet1/0/13 is up, line protocol is up
  Ethernet1/0/13 is layer 2 port, alias name is (null), index is 13
  Hardware is SFP+,  address is xx-xx-xx-xx-xx-xx
  PVID is 1
  MTU 2000 bytes, BW 1000000 Kbit
  Time since last status change:1w-1d-13h-53m-11s  (741191 seconds)
  Encapsulation ARPA, Loopback not set
  Force full-duplex, Force 1G
  FlowControl is off, MDI type is auto
sh transceiver interface ethernet 1/0/13 detail
Base information:
  SFP found in this port, manufactured by OEM, on Jun 16 2009.
  Type is 1000BASE-LX.  Serial number is FA9616LX543.
C другой стороны случаем не 10G порт?
Edited by ShumBor
