Кто-нибудь может подсказать. Купили пару 4500x и поставили одну на узел.
Нагрузка на CPU не маленькая
Core 0: CPU utilization for five seconds: 30%; one minute: 35%; five minutes: 32%
Core 1: CPU utilization for five seconds: 23%; one minute: 25%; five minutes: 23%
show platform health
K5CpuMan Review       30.00  17.24     30     22  100  500   23  19   14  3647:39
show platform cpu packet statistics
Скрытый текст
#show platform cpu packet statistics
RkGenericPacketMan:
Packet allocation failures: 0
Packet Buffer(SW Common) allocation failures: 0
Packet Buffer(SW ESMP) allocation failures: 0
Packet Buffer(SW EOBC) allocation failures: 0
Packet Buffer(SW SupToSup) allocation failures: 0
Packets Dropped In Processing Overall
Total                5 sec avg 1 min avg 5 min avg 1 hour avg
             6215650         1         0         1          1
Packets Dropped In Processing by CPU event
Event             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Sa Miss                        1960027         0         0         0          0
Input ACl Copy                 4254607         0         0         0          1
Output Acl Copy                   1016         0         0         0          0
Packets Dropped In Processing by Priority
Priority          Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Normal                         4255623         0         0         0          1
Medium                         1960027         0         0         0          0
Packets Dropped In Processing by Reason
Reason             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
STPDrop                              23         0         0         0          0
NoDstPorts                         1016         0         0         0          0
Tx Mode Drop                    6214611         1         0         1          1
Total packet queues 64
Packets Received by Packet Queue
Queue                  Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Host Learning                  1960026         0         0         0          0
L2 Control                   643651486       460       421       322        301
Input ACL log, unreach         4261363         0         0         0          1
L3 Glean                      19394889        25        18        16         12
L3 Receive                    34002245       123        94        70         61
Ttl Expired                      42604         0         0         0          0
Output ACL log, unreach            1016         0         0         0          0
Bfd                                103         0         0         0          0
L2 router to CPU, 7           16227361        32        22        17         11
Packets Dropped by Packet Queue
Input ACL log, unreach            1028         0         0         0          0
L3 Glean                          8522         0         0         0          0
По debug видно что много пакетов STP но в VLAN'ах для которых stp отключено
Пример:
Index 141:
May 12 21:31:18.490 MSK - RxVlan: 771, RxPort: Te1/2
Priority: Crucial, Tag: Dot1Q Tag, Event: L2 Control, Flags: 0x44, Size: 68
Eth: Src 00:09:7C:48:41:71 Dst 01:00:0C:CC:CC:CD Type/Len 0x0032
show spanning-tree vlan 771
Spanning tree instance(s) for vlan 771 does not exist.
Т.е. на CPU попадают BPDU из VLAN'ов для которых обработка STP выключена.
Почему так?
Кто-нибудь сталкивался ?
То, что у вас нет инстанса STP на VLAN, не означает прекращения обработки входящих BPDU. Их отсеять можно только через BPDU Filter для access портов (для trunk портов он включен автоматически, но стоит это проверить в spanning-tree interface ХХХХ detail).
Если же вам их пересылает нижестоящее железо, фильтры нужно настраивать на нём.
1 час назад, jffulcrum сказал:
Так коммутатор на агрегации, соотв. все порты в trunk'е
#show spanning-tree vlan 771 detail
Такой проблемы на Cisco ME3600 как-то не было чтобы из-за STP процессор был нагружен до 35%, а конфиг переносится с неё.
Транзитных вланов очень много
Скрытый текст
ME3600#show spanning-tree summary
Switch is in rapid-pvst mode
Extended system ID           is enabled
Portfast Default             is disabled
PortFast BPDU Guard Default  is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default            is disabled
EtherChannel misconfig guard is enabled
Configured Pathcost method used is short
4500X#show spanning-tree summary
Portfast Edge BPDU Guard Default        is disabled
Portfast Edge BPDU Filter Default       is disabled
PVST Simulation Default                 is enabled but inactive in rapid-pvst mode
Bridge Assurance                        is enabled
UplinkFast                              is disabled
BackboneFast                            is disabled
Мне кажется что такое поведение не нормально (возможно я не прав) - если нет интсанса, то не должно до CPU доходить. Может если перезагрузить, то проблема уйдёт, но пока это нельзя делать.
cat4500e-universalk9.SPA.03.11.01.E.152-7.E1.bin
