Есть такая настройка маршрутизации:
"provider1-inet" - l2tp-интерфейс
"provider2-inet" - lte-интерфейс
/ip route add gateway="provider1-inet" distance=1   type=unicast comment="provider1"
/ip route add gateway="provider2-inet" distance=2   type=unicast comment="provider2"
/ip route add gateway="provider1-inet" distance=1   routing-mark="provider1" type=unicast
/ip route add                          distance=254 routing-mark="provider1" type=unreachable
/ip route add gateway="provider2-inet" distance=1   routing-mark="provider2" type=unicast
/ip route add                          distance=254 routing-mark="provider2" type=unreachable
/ip route rule add routing-mark="provider1" action=lookup-only-in-table table="provider1"
/ip route rule add routing-mark="provider2" action=lookup-only-in-table table="provider2"
когда:
не работает:
/ping 8.8.8.8 count=1 routing-table=provider2
когда:
/ip route add gateway="provider1-inet" distance=2   type=unicast comment="provider1"
/ip route add gateway="provider2-inet" distance=1   type=unicast comment="provider2"
не работает:
/ping 8.8.8.8 count=1 routing-table=provider1
Подскажите пожалуйста, возможно сделать, чтобы все пинги ходили нормально?
Edited by cehth
21 час назад, cehth сказал:
Да. Объяснять лень, см. MUM Multiwan (mikrotik.com). Дальше просто кусок кода:
/ip firewall mangle
add action=mark-connection chain=forward new-connection-mark=first \
    out-interface=ISP1 packet-mark=no-mark passthrough=yes
add action=mark-connection chain=forward connection-mark=no-mark \
    new-connection-mark=second out-interface=ISP2 passthrough=yes
add action=mark-connection chain=prerouting connection-state=new dst-address=\
    IP1 in-interface=ISP1 new-connection-mark=prerouting-isp1 \
    passthrough=no
    IP2 in-interface=ISP2 new-connection-mark=prerouting-isp2 \
    passthrough=no
add action=mark-routing chain=output connection-mark=prerouting-isp1 \
    new-routing-mark=netxhop-isp1 passthrough=no
add action=mark-routing chain=output connection-mark=prerouting-isp2 \
    new-routing-mark=netxhop-isp2 passthrough=no
/ip route
add distance=1 gateway=GW1 routing-mark=netxhop-isp1
add distance=1 gateway=GW2 routing-mark=netxhop-isp2
add distance=30 gateway=GW1
add distance=40 gateway=GW2
/ip route rule
add action=lookup-only-in-table routing-mark=netxhop-isp1 table=\
    netxhop-isp1
add action=lookup-only-in-table routing-mark=netxhop-isp2 table=\
    netxhop-isp2
1) А он разве не тоже самое делает, маркирует пакеты приходящие на интерфейс VRFа? Откуда у вас такая информация что дороже по ресурсам? (Я не спорю с вами, просто интересно откуда такая инфа)
2) Я бы сказал, что слегка это мягко сказано. Но ИМХО все эти пляски с маркировками быстрее приведут к глюкам.
