SNR#sh interface ethernet 1/0/27
Interface brief:
  Ethernet1/0/27 is up, line protocol is up
  Ethernet1/0/27 is layer 2 port, alias name is V-5, index is 27
  Hardware is SFP+,  address is f8-f0-82-78-7b-8f
  PVID is 105
  MTU 1500 bytes, BW 10000000 Kbit
  Time since last status change:0w-0d-0h-52m-26s  (3146 seconds)
  Encapsulation ARPA, Loopback not set
  Auto-duplex: Negotiation full-duplex, Auto-speed: Negotiation 10G bits
  FlowControl is off, MDI type is auto
Statistics:
  5 minute input rate 34881390 bits/sec, 20672 packets/sec
  5 minute output rate 518807293 bits/sec, 49166 packets/sec
  The last 5 second input rate 25095106 bits/sec, 18127 packets/sec
  The last 5 second output rate 490181909 bits/sec, 46260 packets/sec
  Input packets statistics:
    55095425 input packets, 9284376185 bytes, 0 no buffer
    55059758 unicast packets, 27518 multicast packets, 7892 broadcast packets
    257 input errors, 0 CRC, 0 frame alignment, 0 overrun, 0 ignored,
    257 abort, 0 length error, 0 undersize 0 jabber, 0 fragments, 0 pause frame
  Output packets statistics:
    132481909 output packets, 175629042977 bytes, 0 underruns
    132478648 unicast packets, 2106 multicast packets, 1155 broadcast packets
    0 output errors, 0 collisions, 0 late collisions, 0 pause frame
SNR#show version
  SNR-S2995G-24FX Device, Compiled on Apr 09 15:12:27 2021
  sysLocation SNR
  CPU Mac f8:f0:82:78:7b:8f
  Vlan MAC f8:f0:82:78:7b:8e
  SoftWare Package Version 7.5.3.2(R0004.0332)
  BootRom Version 7.5.25
  HardWare Version 1.0.1
  CPLD Version 1.03
  Serial No.:SW075010I325000933
  Copyright (C) 2021 NAG LLC
  All rights reserved
  Last reboot is cold reset.
  Uptime is 0 weeks, 0 days, 0 hours, 54 minutes
Обновили прошивку, но ничего не помогло. Из-за этих ошибок начинает ругаться система мониторинга
Подобная тема уже встречалась
