Аналогичная проблема была описана в
Но решение оттуда не помогает. Повторю описание:
1) коммутатор и софт:
Software
  BIOS: version 4.1.0
  NXOS: version 7.0(3)I6(2)
  BIOS compile time:  02/02/2017
  NXOS image file is: bootflash:///nxos.7.0.3.I6.2.bin
  NXOS compile time:  10/17/2017 19:00:00 [10/18/2017 06:48:10]
Hardware
  cisco Nexus3064 Chassis
  Intel(R) Celeron(R) CPU        P4505  @ 1.87GHz with 3903096 kB of memory.
  Processor Board ID FOC1634EK8W
2. В логе ежесекундно появляются записи вида:
2021 Apr  6 11:10:53 Izhevsk20 %-SLOT1-5-BCM_L2_HASH_COLLISION: L2 ENTRY unit=0 mac=0c:80:63:b5:a5:5b vlan=3624 port=0x0c000003
2021 Apr  6 11:10:53 Izhevsk20 %-SLOT1-5-BCM_L2_HASH_COLLISION: L2 ENTRY unit=0 mac=50:ff:20:4b:75:30 vlan=3682 port=0x08000833
2021 Apr  6 11:10:53 Izhevsk20 %-SLOT1-5-BCM_L2_HASH_COLLISION: L2 ENTRY unit=0 mac=0c:b6:d2:8b:0e:a8 vlan=3585 port=0x08000821
2021 Apr  6 11:10:53 Izhevsk20 %-SLOT1-5-BCM_L2_LEARN_DISABLE: MAC Learning Disabled unit=0
2021 Apr  6 11:10:55 Izhevsk20 %-SLOT1-5-BCM_L2_LEARN_ENABLE: MAC Learning Enabled unit=0
2021 Apr  6 11:10:55 Izhevsk20 %-SLOT1-5-BCM_L2_LEARN_DISABLE: MAC Learning Disabled unit=0
2021 Apr  6 11:10:56 Izhevsk20 %-SLOT1-5-BCM_L2_LEARN_ENABLE: MAC Learning Enabled unit=0
2021 Apr  6 11:10:56 Izhevsk20 %MTM-SLOT1-2-MTM_BUFFERS_FULL: MTM buffers are full for unit 0. MAC tables might be inconsistent. Pls use l2 consistency-checker to verify.
3.  В MAC-таблице никогда не бывает реальное число записей:
# show mac address-table count
MAC Entries for all vlans :
Dynamic Address Count:                 2656
Overlay Address Count:                    0
Static Address (User-defined) Count:       0
Secure Address Count:                      0
при реальном около 40 тыс.
4. Процессор сильно загружен
# show system resources
Load average:   1 minute: 4.23   5 minutes: 4.25   15 minutes: 4.32
Processes   :   480 total, 5 running
CPU states  :   71.92% user,   14.77% kernel,   13.30% idle
        CPU0 states  :   99.00% user,   0.00% kernel,   1.00% idle
        CPU1 states  :   45.19% user,   30.76% kernel,   24.03% idle
Memory usage:   3903096K total,   2779640K used,   1123456K free
Current memory status: OK
5. Несогласованность мак-таблицы ВСЕГДА:
# sh consistency-checker l2 module 1
Consistency check: FAILED
Legend:
        * - primary entry, G - Gateway MAC, (R) - Routed MAC, O - Overlay MAC
        age - seconds since last seen, + - primary entry using vPC Peer-Link,
        (T) - True, (F) - False
Missing entries in the HW MAC Table
   VLAN     MAC Address      Type      age     Secure NTFY    Ports
* 19       0024.1db2.d141    dynamic   0          F    F  Eth1/51
* 19       0e50.bbbf.d9b1    dynamic   0          F    F  Eth1/51
* 19       848a.8d2e.b084    dynamic   0          F    F  Eth1/51
* 54       0018.ae31.bc3d    dynamic   0          F    F  Eth1/51
* 54       0018.ae3a.daaf    dynamic   0          F    F  Eth1/51
* 54       3c97.0ebe.c003    dynamic   0          F    F  Eth1/51
* 54       408d.5cfe.66c3    dynamic   0          F    F  Eth1/51
* 54       b42e.992b.ee7b    dynamic   0          F    F  Eth1/51
(сотни неверных записей).
При перезагрузке коммутатора все мгновенно начинается снова.
Согласно таблице из https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/scalability/703I71/b_Cisco_Nexus_3000_Series_NXOS_Verified_Scalability_Guide_703I71.html устройство допускает 128k mac-адресов, поскольку vPC отключен:
# show feature | inc vpc
vpc                    1          disabled
Что за напасть? Реально приводит к потере производительности и росту трафика в портах.
Самую противную часть проблемы я решил - мак-таблица теперь заполняется. Постоянные HASH_COLLISION, конечно, тоже плохо, но на производительность они не влияют.
Итак, все дело в частом изменении топологии STP. А она происходила от недобросовестного клиента, который в некоторый момент стал бомбить коммутатор пакетами PVST типа Root Change. Ну, у него Cisco 3750 стояла, он сам не понял, как это работает.
Дошло до такого:
Izhevsk20# sh spanning-tree detail | i ieee|occur|Exec|from
  Number of topology changes 3533 last change occurred 0:00:26 ago
          from Ethernet1/43
Каждый такой topology change приводил к MAC Learning Disabled, затем к MAC Learning Enabled, и не успевала таблица заполниться на половину, как приходил новый topology change, и всё сначала. А раз таблица коммутации не заполнена, то трафик дублировался во все порты. Процессор же грузился постоянным построением таблицы с нуля.
