Здравствуйте господа знатоки!
Подскажите кто знает: H3C S5500-52C-PWR-EI в 49 порт вставил китайский SFP модуль JT-COM прошитый под CISCO.
Модуль в другом оборудовании работает. А тут не хочет, хотя вроде определяется:
[Switch01]display transceiver interface GigabitEthernet 1/0/49
GigabitEthernet1/0/49 transceiver information:
  Transceiver Type              : UNKNOWN_SFP
  Connector Type                : LC
  Wavelength(nm)                : 1310
  Transfer Distance(km)         : 10(9um)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : CISCO
[Switch01]display transceiver diagnosis interface GigabitEthernet 1/0/49
GigabitEthernet1/0/49 transceiver diagnostic information:
  Current diagnostic parameters:
    Temp.(▒▒C) Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    30         3.32        11.38     -13.18         -4.50
[Switch01]display transceiver alarm interface GigabitEthernet 1/0/49
GigabitEthernet1/0/49 transceiver current alarm information:
  Transceiver type and port configuration mismatch
Что я делаю не так?
Так?
<Switch01>system-view
System View: return to User View with Ctrl+Z.
[Switch01]interface GigabitEthernet 1/0/49
[Switch01-GigabitEthernet1/0/49]port ?
  access             Specify current Access port's characteristics
  auto-power-down    Auto power down mode
  bridge             Configure port bridge
  hybrid             Specify current Hybrid port's characteristics
  isolate-user-vlan  Specify isolate-user-VLAN characteristic
  link-aggregation   Link aggregation group
  link-mode          Switch the specified interface to layer2 or layer3
                     ethernet
  link-type          Specify port link-type
  monitor-link       Specify monitor link
  multicast-vlan     Multicast VLAN
  pvid               Set port PVID
  service-loopback   Service loop back group
  smart-link         Specify smart link
  trunk              Specify current Trunk port's characteristics
Или я что-то не понял?
