1. Модель SNR-CPE-ME2
2. Прошивка последняя (1.8.3.3012201114)
3. лог ошибок
Что предложите?
Feb 10 22:55:45 syslogd started: BusyBox v1.30.1
Feb 10 22:56:29 nginx-wive[4066]: doSystem: (service dnsserver adrestart) > /dev/console 2>&1 (0)
Feb 10 22:56:29 nginx-wive[4066]: doSystem: (services_restart.sh misc &) > /dev/console 2>&1 (0)
Feb 10 22:56:29 services: Restart needed services and scripts. Mode misc
Feb 10 22:56:30 QoS: Stopping SHAPER
Feb 10 22:56:30 QoS: Set default rules.
Feb 10 22:56:30 Codel: QoS Add codel for all interfaces.
Feb 10 22:56:30 adblock: Get ad hosts lists from http://cdn.raletag.gq/rueasyhosts.txt
Feb 10 22:56:30 adblock: Get ad hosts lists from http://winhelp2002.mvps.org/hosts.txt
Feb 10 22:56:30 iptables: Add netfiler rules
Feb 10 22:56:30 iptables: Allow established/related in input
Feb 10 22:56:30 iptables: Drop invalid state connections
Feb 10 22:56:30 iptables: Service limit set
Feb 10 22:56:30 iptables: Set igmp input rules
Feb 10 22:56:30 iptables: DHCP server allow
Feb 10 22:56:30 iptables: Dnsproxy allow to connect
Feb 10 22:56:30 iptables: Quagga allow to connections (from all interfaces).
Feb 10 22:56:30 iptables: allow local port range 32768:61000 from LAN, need for some local service
Feb 10 22:56:30 iptables: UPNP allow to connect
Feb 10 22:56:30 iptables: Samba allow to connect
Feb 10 22:56:30 iptables: Wsdd2 allow to connect
Feb 10 22:56:30 iptables: Remote managment web limit
Feb 10 22:56:30 iptables: Remote managment ssh limit
Feb 10 22:56:30 iptables: Allow rate limited ping from all interfaces.
Feb 10 22:56:30 iptables: Set forward rules
Feb 10 22:56:30 iptables: Set igmp forward rules
Feb 10 22:56:30 iptables: Limit per user tcp sessions to 2
Feb 10 22:56:30 iptables: Set macipport filter rules
Feb 10 22:56:30 iptables: Parprouted enabled - allow forward any to any
Feb 10 22:56:30 iptables: Redirect all DNS requests to local DNS proxy.
Feb 10 22:56:30 iptables: Add SNAT from 192.168.2.1/255.255.255.0 to 10.xxx.153.236 at eth3.
Feb 10 22:56:30 iptables: Add base upnp rules
Feb 10 22:56:30 iptables: Allow established/related in forward
Feb 10 22:56:31 resolv: Generate resolv DNS1: 10.xxx.152.1 DNS2: 8.8.8.8
Feb 10 22:56:31 parprouted: Stopping parprouted
Feb 10 22:56:31 parprouted: Starting parprouted
Feb 10 22:56:31 parprouted[598]: Starting.
Feb 10 22:56:31 parprouted[598]: 'ip route add 192.168.2.3/32 metric 50 dev br0' unsuccessful, will try to remove!
Feb 10 22:56:31 parprouted[598]: 'ip route add 192.168.2.138/32 metric 50 dev br0' unsuccessful, will try to remove!
Feb 10 22:56:31 parprouted[598]: 'ip route add 192.168.2.1/32 metric 50 dev eth3' unsuccessful, will try to remove!
Feb 10 22:56:31 dynroute: Stopping ZEBRA
Feb 10 22:56:31 parprouted[598]: 'ip route add 192.168.2.24/32 metric 50 dev br0' unsuccessful, will try to remove!
Feb 10 22:56:31 zebra[31786]: IRDP: Received shutdown notification.
Feb 10 22:56:33 dynroute: Stopping RIPD
Feb 10 22:56:34 dynroute: Starting ZEBRA
Feb 10 22:56:34 zebra[663]: Zebra 1.2.4 starting: vty@2601
Feb 10 22:56:34 dynroute: Starting RIPD
Feb 10 22:56:34 ripd[666]: RIPd 1.2.4 starting: vty@2602
Feb 10 22:56:34 zebra[663]: client 24 says hello and bids fair to announce only rip routes
Feb 10 22:56:34 zebra[663]: Try to set TE Link Param
Feb 10 22:56:34 dnsserver: Generate /etc/hosts file.
Feb 10 22:56:34 dnsserver: Send HUP to dnsmasq.
Feb 10 22:56:34 dnsmasq[1128]: read /etc/hosts - 5 addresses
Feb 10 22:56:34 dnsmasq[1128]: using nameserver 10.xxx.152.1#53
Feb 10 22:56:34 dnsmasq[1128]: using nameserver 8.8.8.8#53
Feb 10 22:56:34 ntp: Stopping NTPD
Feb 10 22:56:35 ntp: Starting NTPD
Feb 10 22:56:35 upnpd: Starting UPNP at 10.xxx.153.236
Feb 10 22:56:35 igmpproxy: Stopping IGMPPROXY
Feb 10 22:56:35 igmpproxy: Replace route to multicast subnet via eth3.
Feb 10 22:56:35 igmpproxy: Starting IGMPPROXY
Feb 10 22:56:36 kext: Nat mode Linux Hybrid
Feb 10 22:56:36 kext: NAT Offload mode complex, enable hw_nat and selected software fastpaths.
Feb 10 22:56:36 kext: NAT fastpath enabled.
Feb 10 22:56:36 kext: Route fastpath enabled.
Feb 10 22:56:36 kext: Netfilter fastpath enabled.
Feb 10 22:56:36 kernel: Ralink HW NAT v2.52.0 Module Disabled
Feb 10 22:56:36 kext: hw_nat: load driver with options wifi_offload=1 udp_offload=1 ipv6_offload=0 ttl_regen=1
Feb 10 22:56:36 kernel: Ralink HW NAT v2.52.0 Module Enabled, FoE Size: 16384
Feb 10 22:56:36 kext: hw_nat: set binding threshold to 50.
Feb 10 22:56:36 kext: PPPOE Pass Through enable for br0 and eth3 interfaces.
Feb 10 22:56:36 kext: Enable multicast to unicast conversion for ra0 rai0
Feb 10 22:56:36 lld2d: Stopping LLD2D
Feb 10 22:56:37 lld2d: Starting LLD2D
Feb 10 22:56:37 inetd: Stopping inetd
Feb 10 22:56:37 inetd: Starting inetd
Feb 10 22:56:38 transmission: Not any disk connected.
Feb 10 22:56:38 dhcpd: Stop dhcpserver
Feb 10 22:56:39 dhcpd: Configure dhcpserver
Feb 10 22:56:39 dhcpd: Start dhcpserver
Feb 10 22:56:39 udhcpd[1247]: started, v1.30.1
Feb 10 22:56:40 irqbalance: Stopping irqbalance
Feb 10 22:56:41 irqbalance: Start irqbalance routing/wifi optimize mode
Feb 10 22:56:41 irqbalance: Start irqbalance auto mode
Feb 10 22:56:42 adblock: Get ad hosts lists from http://cdn.raletag.gq/rueasyhosts.txt
Feb 10 22:56:42 adblock: Get ad hosts lists from http://winhelp2002.mvps.org/hosts.txt
Feb 10 22:58:46 adblock: Get ad hosts lists from https://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&showintro=0&mimetype=plaintext
Feb 10 22:58:47 adblock: Get ad hosts lists from http://www.malwaredomainlist.com/hostslist/hosts.txt
Feb 10 22:58:47 adblock: Filter records.
Feb 10 22:58:47 adblock: Remove duplicated records.
Feb 10 22:58:47 adblock: Create list error, exit
Edited by fedotov_a_a
выжимка из скрипта /etc/scripts/config-adblock.sh
    # RUSSIAN BLOCK LIST
    blocklists="http://cdn.raletag.gq/rueasyhosts.txt"
    # GLOBAL BLOCK LISTS
    blocklists="$blocklists http://winhelp2002.mvps.org/hosts.txt"
    blocklists="$blocklists https://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&showintro=0&mimetype=plaintext"
    blocklists="$blocklists http://www.malwaredomainlist.com/hostslist/hosts.txt"
    # skip some counters - prevent break sites view and allow small analitycs
    unblocklist="liveinternet.ru|counter.yadro.ru|^yadro.ru|top100.ru|mc.yandex.ru|metrika|openstat.net"
    unblocklist="$unblocklist|google-analytics.com|googletagmanager.com|^stats.g.doubleclick.net|clustrmaps.com"
Первая ссылка http://cdn.raletag.gq/rueasyhosts.txt - не доступна - закоментировал
Вторая ссылка https://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&showintro=0&mimetype=plaintext" - доступна
Третья ссылка http://www.malwaredomainlist.com/hostslist/hosts.txt - внутри текста пустота, можно просто закомментировать.
При обращении скрипта по второй ссылке выскакивает ошибка, говорящая о неправильных TLS-сертификатах (сори, ели порю горячку, я в этом "деле" не рублю). Сам сервис стартует - появляется файл /tmp/adblock_runnig, и появляется файл /tmp/list.tmp, но внутри /tmp/list.tmp - пустота, так как сервис не может считать инфу с сайтов. Проблема с сертификатами.
[SNR-CPE@/]# service dnsserver adstart
[SNR-CPE@/]# wget: note: TLS certificate validation not implemented
wget: short read, have only 0: Connection reset by peer
wget: error getting response: Connection reset by peer
wget: TLS error from peer (alert code 80): 80
Чем сможете помочь?
Добрый день, @fedotov_a_a. Исправили проблему в ПО 1.8.4, можете скачать обновление с сайта и поставить вручную или обновить из веб-интерфейса роутера по воздуху, инструкция по обновлению доступна на странице https://nag.wiki/x/N4YS
Edited by Rurmanov
Опять не работает Adblock.
Feb 15 14:35:33 kernel: ASSOC - HT support STA. Update AP OperaionMode=0 , fAnyStationIsLegacy=0, fAnyStation20Only=0, fAnyStationNonGF=1
Feb 15 14:35:34 udhcpd[26601]: sending OFFER of 192.168.2.242
Feb 15 14:35:34 udhcpd[26601]: sending ACK to 192.168.2.242
Feb 15 14:36:51 dnsserver: Stopping DNSMASQ
Feb 15 14:36:51 dnsmasq[18044]: exiting on receipt of SIGTERM
Feb 15 14:36:52 dnsserver: Generate /etc/hosts file.
Feb 15 14:36:52 dnsserver: 1 domains user blocked by DNS.
Feb 15 14:36:52 dnsserver: Starting DNSMASQ
Feb 15 14:36:52 dnsmasq[26974]: started, version 2.80 cachesize 1024
Feb 15 14:36:52 dnsmasq[26974]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN no-DHCP no-scripts no-TFTP no-conntrack no-ipset no-auth DNSSEC no-loop-detect inotify no-dumpfile
Feb 15 14:36:52 dnsmasq[26974]: read /etc/hosts - 5 addresses
Feb 15 14:36:52 dnsmasq[26974]: using nameserver 1.1.1.1#53
Feb 15 14:36:52 dnsmasq[26974]: using nameserver 77.88.8.7#53
Feb 15 14:37:27 kernel: ASSOC - Assign AID=4 to 5GHz AP 06:77:01:d1:ed:18
Feb 15 14:37:27 kernel: ASSOC - HT support STA. Update AP OperaionMode=0 , fAnyStationIsLegacy=0, fAnyStation20Only=0, fAnyStationNonGF=1
Feb 15 14:37:27 kernel: ASSOC - VHT support STA
Feb 15 14:37:28 udhcpd[26601]: sending OFFER of 192.168.2.24
Feb 15 14:37:28 udhcpd[26601]: sending ACK to 192.168.2.24
Feb 15 14:37:35 adblock: Get ad hosts lists from http://update.snr.systems/updates/ad0
Feb 15 14:37:35 adblock: Get ad hosts lists from http://update.snr.systems/updates/ad1
Feb 15 14:37:35 adblock: Get ad hosts lists from http://update.snr.systems/updates/ad2
Feb 15 14:37:35 adblock: Get ad hosts lists from http://update.snr.systems/updates/ad3
Feb 15 14:37:35 adblock: Filter records.
Feb 15 14:37:36 adblock: Remove duplicated records.
Feb 15 14:37:37 adblock: Create list error, exit
Запуск из консоли выдаёт следующее:
[SNR-CPE@/]# /etc/init.d/dnsserver restart
[SNR-CPE@/]# /etc/init.d/dnsserver adstart
[SNR-CPE@/]# wget: server returned error: HTTP/1.1 404 Not Found
[SNR-CPE@/]#
20 часов назад, fedotov_a_a сказал:
[SNR-CPE@/]#
Добрый день, после обновления рекомендуется сбросить роутер к заводским настройкам согласно инструкции: nag.wiki
Так же уточните, какие-нибудь дополнительные параметры в настройках Сервиса DNS вы используете?(Желательно пришлите скриншот сюда или в ЛС)
14 часов назад, fedotov_a_a сказал:
Добрый день. Выкладываю распечатки с роутера.
В файерволе стоит проброс транзитного трафика только с определённого IP-адреса (заменён нулями).
DNS.pdf
Firewall.pdf
Добрый день. Настройки роутера до заводских сбрасывали? В лабораторных условиях воспроизвести проблему не удалось. Для диагностики откройте, пожалуйста удалённый доступ до роутера, инструкция доступна по ссылке https://nag.wiki/pages/viewpage.action?pageId=9699470, реквизиты направьте в ЛС.
