Всем привет.
Что имеем в наличии:
Arista DCS-7050QX-32S-R
Сетевая карта LR-Link 2 порта 40GBase-X LREC9902BF-2QSFP+
QSFP+ 40GBASE-SR4, разъем MPO, дальность до 100м, два из них прошиты под Arista
Патчкорд оптический MPO/UPC FF MM (50/125 OM4), 8 волокон, 5 метра (Cross)
Карта успешно имплантирована в сервер и с помошью патчей подклен на прямую в коммутатор, линка нет.
Не большой знаток Arista, но хотелось бы понять в чем может быть причина и возможен ли в принципе такой сценарий использования?
#sh interfaces status
Port       Name   Status       Vlan     Duplex Speed  Type         Flags Encapsulation
Et29              notconnect   trunk    full   40G    40GBASE-SR4
Et30              notconnect   1        full   40G    40GBASE-SR4
 show transceiver status
                                Current State        Changes       Last Change
Port 29
  Transceiver                   40GBASE-SR4                2       1:07:47 ago
  Transceiver SN                QH41651214
  Presence                      present
  Adapters                      None
  Bad EEPROM checksums                                     0       never
  Resets                                                   0       never
  Interrupts                                               6       0:09:17 ago
  Smbus failures                                           0       never
  Temperature high alarm        False                      0       never
  Temperature high warn         False                      0       never
  Temperature low alarm         False                      0       never
  Temperature low warn          False                      0       never
  Voltage high alarm            False                      0       never
  Voltage high warn             False                      0       never
  Voltage low alarm             False                      0       never
  Voltage low warn              False                      0       never
Ethernet29
  Operational speed             40Gb/s
  RX LOS
    Channel 1                   True                       1       1:07:44 ago
    Channel 2                   True                       1       1:07:44 ago
    Channel 3                   True                       1       1:07:44 ago
    Channel 4                   True                       1       1:07:44 ago
  TX LOS
    Channel 1                   False                      0       never
    Channel 2                   False                      0       never
    Channel 3                   False                      0       never
    Channel 4                   False                      0       never
  TX fault
    Channel 1                   False                      4       0:09:17 ago
    Channel 2                   False                      4       0:09:17 ago
    Channel 3                   False                      4       0:09:17 ago
    Channel 4                   False                      4       0:09:17 ago
  RX CDR LOL
  TX CDR LOL
  TX adaptive input EQ fault
  TX power high alarm
  TX power high warn
  TX power low alarm
    Channel 1                   False                      4       0:09:16 ago
    Channel 2                   False                      4       0:09:16 ago
    Channel 3                   False                      4       0:09:16 ago
    Channel 4                   False                      4       0:09:16 ago
  TX power low warn
  TX bias high alarm
  TX bias high warn
  TX bias low alarm
  TX bias low warn
  RX power high alarm
  RX power high warn
  RX power low alarm
    Channel 1                   True                       1       1:07:43 ago
    Channel 2                   True                       1       1:07:43 ago
    Channel 3                   True                       1       1:07:43 ago
    Channel 4                   True                       1       1:07:43 ago
  RX power low warn
Port 30
  Transceiver                   40GBASE-SR4                2       1:07:35 ago
  Transceiver SN                QH41651215
  Presence                      present
  Adapters                      None
  Resets                                                   0       never
  Interrupts                                               8       0:09:17 ago
Ethernet30
  RX LOS
    Channel 1                   True                       1       1:07:33 ago
    Channel 2                   True                       1       1:07:33 ago
    Channel 3                   True                       1       1:07:33 ago
    Channel 4                   True                       1       1:07:33 ago
  TX LOS
  TX fault
  RX CDR LOL
  TX CDR LOL
  TX power high alarm
  TX power high warn
  TX power low alarm
  TX power low warn
  TX bias high alarm
  TX bias high warn
  TX bias low alarm
  TX bias low warn
  RX power high alarm
  RX power high warn
  RX power low alarm
    Channel 1                   True                       1       1:07:31 ago
    Channel 2                   True                       1       1:07:31 ago
    Channel 3                   True                       1       1:07:31 ago
    Channel 4                   True                       1       1:07:31 ago
  RX power low warn
 sh ver
Hardware version:    11.34
А карта как модули видит?
ethtool -m eth0
что показывает?
А банально проверить модули можно путем замыкания двух портов этим патчем с модулями, предварительно сделав оба порта аксесными в разных вланах.
Edited by passer
6 часов назад, passer сказал:
ethtool -m eth0
что показывает?
Благодарю, мысль отличная насчет подключения.  Карта в гипервизоре определяется корректно:
Цитата
Adapter Intel(R) Ethernet Controller XL710 for 40GbE QSFP+
Name vmnic2
Location PCI 0000:06:00.0
Driver i40en
Status
Status Disconnected
Actual speed, Duplex Down
Configured speed, Duplex Auto negotiate
Networks No networks
9 часов назад, passer сказал:
ethtool -m eth0
что показывает?
Name vmnic2
Driver i40en
Status
Status Disconnected
Опытным путем установлено, замыкание модулей прошитых под Arista и нет, в различных комбинациях приводит к поднятию линка, линк с сетевой картой "мертв".
25 минут назад, Pinkbyte сказал:
У вас auto negotiate выставлен на сетевухах, попробуйте задать скорость вручную, иногда с 10G модулями такое помогает, насчет 40G не знаю...
Благодарю, проверял. Линка нет, с 40Гэ не сталкивался до этого, но предполагал как и на 10 линк должен быть независимо от загруженной ОС.  Сегодня наступив на горло и совесть установили сетевую карту в ПК Windows 10(поддержка заявлена у производителя), результат аналогичный - линка нет. Включаю уже подозреваку на карту, другой к сожалению нет(брал на пробу 1 шт.).
32 минуты назад, Vitaliyc сказал:
Нет, комлект  в сетевой не "шился". Замыкал - нет линка.
Берете любой livecd или liveusb линух, грузитесь и смотрите, как сетевушка опознала модули и какой rx/tx power (ethtool -m в помощь) на модулях она видит. Пока же информации для гипотез нет. Разве что грешить на вендор-лок сетевухи.
Edited by passer
Коллеги, всем благодарность за участие и помощь.
По факту прошивать модули необходимо для сетевой карты, что и подтвердила ТП продавца.
