Mechanic Posted January 16, 2021 Posted January 16, 2021 использует ли кто на нексусе 3064 vlan mapping ? version 9.2(3) Bios:version 5.0.0 interface Ethernet1/3 description uplink switchport mode trunk switchport vlan mapping enable switchport vlan mapping 2032 110 switchport trunk allowed vlan 110,205,224,1526,2016-2020,2030-2033 # show int eth1/3 vlan mapping Interface Eth1/3: Original VLAN Translated VLAN --------------- ----------------- 2032 110 Задача заменить тег 110 на 2032, но транслирование тега не происходит Вставить ник Quote
stalker86 Posted January 16, 2021 Posted January 16, 2021 Подозреваю надо switchport vlan mapping 110 2032 Вставить ник Quote
andryas Posted January 16, 2021 Posted January 16, 2021 switchport trunk allowed vlan add 2032 switchport vlan mapping 110 2032 Вставить ник Quote
Mechanic Posted January 16, 2021 Author Posted January 16, 2021 38 минут назад, andryas сказал: switchport trunk allowed vlan add 2032 switchport vlan mapping 110 2032 поменял switchport mode trunk switchport vlan mapping enable switchport vlan mapping 110 2032 switchport trunk allowed vlan 110,205,224,1526,2016-2020,2030-2033 # show int eth1/3 vlan mapping Interface Eth1/3: Original VLAN Translated VLAN --------------- ----------------- 110 2032 show mac address-table int eth1/3 vlan 110 Legend: * - primary entry, G - Gateway MAC, (R) - Routed MAC, O - Overlay MAC age - seconds since last seen,+ - primary entry using vPC Peer-Link, (T) - True, (F) - False, C - ControlPlane MAC, ~ - vsan VLAN MAC Address Type age Secure NTFY Ports ---------+-----------------+--------+---------+------+----+------------------ мас нет. Влан для траснляции нужно добавлять в базу вланов ? Вставить ник Quote
stalker86 Posted January 16, 2021 Posted January 16, 2021 show mac address-table int eth1/3 vlan 2032 и бегом читать документацию Вставить ник Quote
Mechanic Posted January 16, 2021 Author Posted January 16, 2021 20 минут назад, stalker86 сказал: show mac address-table int eth1/3 vlan 2032 и бегом читать документацию я влан 2032 не созадвал в базе вланов, соответственно он ругается show mac address-table int eth1/3 vlan 2032 ERROR: Vlan does not exist Касательно мануала- команда есть, а описания в мануале нету. Есть для 9000 серии, все делаю по аналогии, но не пашет. Сообщения от 2017г, при прошивке 7.х говорят, что данный функционал не поддерживается, но уже 9.2, команды отрабатываются. Вставить ник Quote
alexgreat Posted January 16, 2021 Posted January 16, 2021 Не умеет 3064 vlan mapping Вставить ник Quote
andryas Posted January 17, 2021 Posted January 17, 2021 13 hours ago, Mechanic said: Влан для траснляции нужно добавлять в базу вланов ? Да, только новый (2032) vlan 13 hours ago, alexgreat said: Не умеет 3064 vlan mapping Умеет, но немного. Если нужен именно функционал трансляций - смотрите в сторону 4900M, 4948E, 4500X Вставить ник Quote
stalker86 Posted January 17, 2021 Posted January 17, 2021 14 часов назад, Mechanic сказал: я влан 2032 не созадвал в базе вланов, соответственно он ругается show mac address-table int eth1/3 vlan 2032 ERROR: Vlan does not exist Касательно мануала- команда есть, а описания в мануале нету. Есть для 9000 серии, все делаю по аналогии, но не пашет. Сообщения от 2017г, при прошивке 7.х говорят, что данный функционал не поддерживается, но уже 9.2, команды отрабатываются. влан меняется в сторону ядра циски..а не в сторону доступа. То есть если к Вам летит влан 110 с доступа и Вам его нужно странслировать в 2032 в Вашем ядре... то и создавать нужно 2032..а не 110 Вставить ник Quote
Mechanic Posted January 17, 2021 Author Posted January 17, 2021 у меня наоборот 110, его нужно в порт аплинка выплюнуть как 2032 Вставить ник Quote
burevestnik_1983 Posted March 11, 2021 Posted March 11, 2021 Nexus 3064 NXOS: version 9.2(3) Вопрос - можно ли по snmp как-то замониторить настройки vlan_mapping - аналог вывода команды show int eth1/3 vlan mapping в ciscoVtpMIB не нашёл подобного в других MIB CISCO искал по слову mapping - ничего не нашёл Вставить ник Quote
