Добрый день!
Коллеги, подскажите может не то настраиваю на huawei.  Пытаюсь поднять xconnect на mpls между juniper и huawei 5320-36.  На джуне тоннель взлетает, а на хувике нет.
джун
Neighbor: 10.120.1.20
    Interface                 Type  St     Time last up          # Up trans
    ge-0/2/1.50(vc 50)        rmt   Up     Dec  6 05:53:06 2020           1
      Remote PE: 10.120.1.20, Negotiated control-word: No
      Incoming label: 300256, Outgoing label: 1043
      Negotiated PW status TLV: No
      Local interface: ge-0/2/1.50, Status: Up, Encapsulation: VLAN
      Flow Label Transmit: No, Flow Label Receive: No
на хувике VC в Down
display mpls l2vc
 Total LDP VC : 1     0 up       1 down
 *client interface       : GigabitEthernet0/0/27.50 is up
  Administrator PW       : no
  session state          : up
  AC status              : up
  Ignore AC state        : disable
  VC state               : down
  Label state            : 0
  Token state            : 0
  VC ID                  : 50
  VC type                : VLAN
  destination            : 10.120.1.5
  local VC label         : 1043         remote VC label      : 0
  control word           : disable
  remote control word    : none
  forwarding entry       : not exist
  local group ID         : 0
  remote group ID        : 0
  local AC OAM State     : up
  local PSN OAM State    : up
  local forwarding state : forwarding
  local status code      : 0x0
  BFD for PW             : unavailable
  VCCV State             : up
  manual fault           : not set
  active state           : inactive
  link state             : down
  local VC MTU           : 1600         remote VC MTU        : 0
  local VCCV             : alert ttl lsp-ping bfd
  remote VCCV            : none
  tunnel policy name     : --
  PW template name       : --
  primary or secondary   : primary
  load balance type      : flow
  Access-port            : false
  Switchover Flag        : false
  VC tunnel/token info   : 1 tunnels/tokens
    NO.0  TNL type       : lsp   , TNL ID : 0x48000011
    Backup TNL type      : lsp   , TNL ID : 0x0
  create time            : 0 days, 3 hours, 18 minutes, 19 seconds
  up time                : 0 days, 0 hours, 0 minutes, 0 seconds
  last change time       : 0 days, 3 hours, 18 minutes, 19 seconds
  VC last up time        : 0000/00/00 00:00:00
  VC total up time       : 0 days, 0 hours, 0 minutes, 0 seconds
  CKey                   : 30
  NKey                   : 29
  PW redundancy mode     : frr
  AdminPw interface      : --
  AdminPw link state     : --
  Diffserv Mode          : uniform
  Service Class          : be
  Color                  : --
  DomainId               : --
  Domain Name            : --
конфиг джуна:
interfaces {
 ge-0/2/1 {
        description dlink-3200-18;
        flexible-vlan-tagging;
        mtu 9000;
        encapsulation flexible-ethernet-services;
        unit 50 {
            description test-5320-36;
            encapsulation vlan-ccc;
            vlan-id 50;
            family ccc;
  l2circuit {
  neighbor 10.120.1.20 {
            interface ge-0/2/1.50 {
                virtual-circuit-id 50;
                no-control-word;
                mtu 1600;
OSPF и LDP связанность есть
show ospf neighbor
Address          Interface              State     ID               Pri  Dead
10.120.40.13     xe-0/3/0.9             Full      10.120.40.13       1    31
show ldp neighbor
10.120.40.13                        xe-0/3/0.9      10.120.1.20:0        14
конфиг 5320-36
interface Vlanif9  ( стыковочный интефейс с джуном)
 mtu 2000
 ip address 10.120.40.13 255.255.255.252
 ospf network-type p2p
 ospf ldp-sync
 mpls
 mpls te
 mpls rsvp-te
 mpls ldp
interface GigabitEthernet0/0/27.50
 mtu 1600
 dot1q termination vid 50
 mpls l2vc 10.120.1.5 50
5320-36>display ospf peer
         OSPF Process 1 with Router ID 10.120.40.13
                 Neighbors
 Area 0.0.0.0 interface 10.120.40.13(Vlanif9)'s neighbors
 Router ID: 10.120.1.5       Address: 10.120.40.14
   State: Full  Mode:Nbr is  Slave  Priority: 128
   DR: None   BDR: None   MTU: 2000
   Dead timer due in 38  sec
   Retrans timer interval: 5
   Neighbor is up for 29:26:38
   Authentication Sequence: [ 0 ]
                 Neighbors
 Area 0.0.0.0 interface 10.120.40.2(Vlanif10)'s neighbors
 Router ID: 10.120.19.10     Address: 10.120.40.1
   DR: None   BDR: None   MTU: 0
   Retrans timer interval: 2
   Neighbor is up for 23:46:17
display mpls ldp session
 LDP Session(s) in Public Network
 Codes: LAM(Label Advertisement Mode), SsnAge Unit(DDDD:HH:MM)
 A '*' before a session means the session is being deleted.
 PeerID             Status      LAM  SsnRole  SsnAge      KASent/Rcv
 10.120.1.5:0       Operational DU   Active   0000:03:31  1271/1268
Если соединяю междк собой два хувика, то все взлетает
