Коллеги, приветствую!
Вчера делал правки в firewall family inet filter, добавил term и сделал commit confirmed 5 и после этого моргнули xe порты на fpc5,fpc6 и что-то произошло на fpc7. Само восстановилось, но стремный момент, подскажите, куда копать?
Информация о стеке:
show system software all-members | match "JUNOS Base OS Software"
JUNOS Base OS Software Suite [12.3R9.4]
show chassis firmware
Part                     Type       Version
FPC 2                    uboot      U-Boot 1.1.6 (Jul  5 2012 - 11:58:22) 1.0.0
                         loader     FreeBSD/PowerPC U-Boot bootstrap loader 2.4
FPC 3                    uboot      U-Boot 1.1.6 (Jul  5 2012 - 11:58:22) 1.0.0
FPC 4                    uboot      U-Boot 1.1.6 (Jul  5 2012 - 11:58:22) 1.0.0
FPC 5                    uboot      U-Boot 1.1.6 (Jul  5 2012 - 11:58:22) 1.0.0
FPC 6                    uboot      U-Boot 1.1.6 (Jul  5 2012 - 11:58:22) 1.0.0
FPC 7                    uboot      U-Boot 1.1.6 (Jul  5 2012 - 11:58:22) 1.0.0
show chassis hardware | match FPC
FPC 2            REV 07   750-033064   *329      EX4200-48P, 48 POE
  CPU                     BUILTIN      BUILTIN           FPC CPU
FPC 3            REV 17   750-033063   *468      EX4200-48T, 8 POE
FPC 4            REV 17   750-033063   *467      EX4200-48T, 8 POE
FPC 5            REV 18   750-021255   *226      EX4200-48P, 48 POE
FPC 6            REV 14   750-033064   *497      EX4200-48P, 48 POE
FPC 7            REV 12   750-033064   *213      EX4200-48P, 48 POE
show virtual-chassis status
Preprovisioned Virtual Chassis
Virtual Chassis ID: 6c74.beb7.f5e4
Virtual Chassis Mode: Enabled
                                           Mstr           Mixed Neighbor List
Member ID  Status   Serial No    Model     prio  Role      Mode ID  Interface
2 (FPC 2)  Prsnt    *329 ex4200-48p 129  Master*      N  3  vcp-0
        7  vcp-1
3 (FPC 3)  Prsnt    *468 ex4200-48t 129  Backup       N  4  vcp-0
        2  vcp-1
4 (FPC 4)  Prsnt    *467 ex4200-48t   0  Linecard     N  5  vcp-0
        3  vcp-1
5 (FPC 5)  Prsnt    *226 ex4200-48p   0  Linecard     N  6  vcp-0
        4  vcp-1
6 (FPC 6)  Prsnt    *497 ex4200-48p   0  Linecard     N  7  vcp-0
        5  vcp-1
7 (FPC 7)  Prsnt    *213 ex4200-48p   0  Linecard     N  2  vcp-0
        6  vcp-1
Лог:
Цитата
Nov 16 17:53:20  jEX4200-VC mgd[868]: UI_COMMIT: User 'exadmin' requested 'commit' operation (comment: none)
Nov 16 17:53:26  jEX4200-VC dcd[948]: ae0 : Warning: aggregated-ether-options link-speed no kernel value! default to  0
Nov 16 17:53:26  jEX4200-VC dcd[948]: ae1 : Warning: aggregated-ether-options link-speed no kernel value! default to  0
Nov 16 17:53:26  jEX4200-VC dcd[948]: ae2 : Warning: aggregated-ether-options link-speed no kernel value! default to  0
Nov 16 17:53:26  jEX4200-VC dcd[948]: ae3 : Warning: aggregated-ether-options link-speed no kernel value! default to  0
Nov 16 17:53:26  jEX4200-VC dcd[948]: ae5 : Warning: aggregated-ether-options link-speed no kernel value! default to  0
Nov 16 17:53:26  jEX4200-VC dcd[948]: ae6 : Warning: aggregated-ether-options link-speed no kernel value! default to  0
Nov 16 17:53:26  jEX4200-VC dcd[948]: ae7 : Warning: aggregated-ether-options link-speed no kernel value! default to  0
Nov 16 17:53:26  jEX4200-VC dcd[948]: ae8 : Warning: aggregated-ether-options link-speed no kernel value! default to  0
Nov 16 17:53:26  jEX4200-VC dcd[948]: ae23 : Warning: aggregated-ether-options link-speed no kernel value! default to  0
Nov 16 17:53:48  jEX4200-VC mgd[868]: UI_COMMIT_CONFIRMED_REMINDER: 'commit confirmed' must be confirmed within 5 minutes
Nov 16 17:53:50  jEX4200-VC dcd[84599]: ae0 : aggregated-ether-options link-speed set to kernel value of  10000000000
Nov 16 17:53:50  jEX4200-VC dcd[84599]: ae1 : aggregated-ether-options link-speed set to kernel value of  10000000000
Nov 16 17:53:50  jEX4200-VC dcd[84599]: ae2 : aggregated-ether-options link-speed set to kernel value of  1000000000
Nov 16 17:53:50  jEX4200-VC dcd[84599]: ae3 : aggregated-ether-options link-speed set to kernel value of  1000000000
Nov 16 17:53:50  jEX4200-VC dcd[84599]: ae5 : aggregated-ether-options link-speed set to kernel value of  10000000000
Nov 16 17:53:50  jEX4200-VC dcd[84599]: ae6 : aggregated-ether-options link-speed set to kernel value of  10000000000
Nov 16 17:53:50  jEX4200-VC dcd[84599]: ae7 : Warning: aggregated-ether-options has no childern! link-speed set to  0
Nov 16 17:53:50  jEX4200-VC dcd[84599]: ae8 : Warning: aggregated-ether-options has no childern! link-speed set to  0
Nov 16 17:53:50  jEX4200-VC dcd[84599]: ae23 : aggregated-ether-options link-speed set to kernel value of  1000000000
Nov 16 17:54:04  jEX4200-VC /kernel: peer_input_pending_internal:[4226] VKS0 for peer type 25 indx 7 reported a sb_state 32 = SBS_CANTRCVMORE
Nov 16 17:54:04  jEX4200-VC /kernel: peer_inputs:4477 VKS0 closing connection peer type 25 indx 7 err 5
Nov 16 17:54:08  jEX4200-VC /kernel: tcp_timer_keep: Dropping socket connection due to keepalive timer expiration
Nov 16 17:54:08  jEX4200-VC /kernel: ae_bundlestate_ifd_change: bundle ae6: bundle IFD minimum links not met 0 < 1
Nov 16 17:54:08  jEX4200-VC /kernel: KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-6/1/0 - ATTACHED state - acting as standby link
Nov 16 17:54:08  jEX4200-VC lacpd[34373]: LACPD_TIMEOUT: xe-6/1/0: lacp current while timer expired current Receive State: CURRENT
Nov 16 17:54:08  jEX4200-VC lacpd[34373]: LACP_INTF_DOWN: ae6: Interface marked down due to lacp timeout on member xe-6/1/0
Nov 16 17:54:10  jEX4200-VC last message repeated 2 times
Nov 16 17:54:10  jEX4200-VC lacpd[34373]: LACPD_TIMEOUT: xe-5/1/0: lacp current while timer expired current Receive State: CURRENT
Nov 16 17:54:10  jEX4200-VC /kernel: tcp_timer_keep: Dropping socket connection due to keepalive timer expiration
Nov 16 17:54:10  jEX4200-VC /kernel: peer_input_pending_internal:[4219] VKS0 for peer type 24 indx 6 reported a so_error 60
Nov 16 17:54:10  jEX4200-VC /kernel: peer_inputs:4477 VKS0 closing connection peer type 24 indx 6 err 5
Nov 16 17:54:10  jEX4200-VC /kernel: peer_input_pending_internal:[4219] VKS0 for peer type 23 indx 6 reported a so_error 60
Nov 16 17:54:10  jEX4200-VC /kernel: peer_inputs:4477 VKS0 closing connection peer type 23 indx 6 err 5
Nov 16 17:54:10  jEX4200-VC /kernel: pfe_send_failed(index 6, type 23), err=32
Nov 16 17:54:10  jEX4200-VC /kernel: peer_input_pending_internal:[4219] VKS0 for peer type 24 indx 5 reported a so_error 54
Nov 16 17:54:10  jEX4200-VC /kernel: peer_inputs:4477 VKS0 closing connection peer type 24 indx 5 err 5
Nov 16 17:54:10  jEX4200-VC /kernel: peer_input_pending_internal:[4219] VKS0 for peer type 23 indx 5 reported a so_error 54
Nov 16 17:54:10  jEX4200-VC /kernel: peer_inputs:4477 VKS0 closing connection peer type 23 indx 5 err 5
Nov 16 17:54:10  jEX4200-VC /kernel: pfe_send_failed(index 5, type 23), err=32
Nov 16 17:54:10  jEX4200-VC /kernel: ae_bundlestate_ifd_change: bundle ae5: bundle IFD minimum links not met 0 < 1
Nov 16 17:54:10  jEX4200-VC /kernel: KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-5/1/0 - ATTACHED state - acting as standby link
Nov 16 17:54:10  jEX4200-VC /kernel: peer_input_pending_internal:[4219] VKS0 for peer type 24 indx 7 reported a so_error 60
Nov 16 17:54:10  jEX4200-VC /kernel: peer_inputs:4477 VKS0 closing connection peer type 24 indx 7 err 5
Nov 16 17:54:10  jEX4200-VC /kernel: peer_input_pending_internal:[4219] VKS0 for peer type 23 indx 7 reported a so_error 60
Nov 16 17:54:10  jEX4200-VC /kernel: peer_inputs:4477 VKS0 closing connection peer type 23 indx 7 err 5
Nov 16 17:54:10  jEX4200-VC /kernel: pfe_send_failed(index 7, type 23), err=32
Nov 16 17:54:10  jEX4200-VC lacpd[34373]: LACP_INTF_DOWN: ae5: Interface marked down due to lacp timeout on member xe-5/1/0
Nov 16 17:54:10  jEX4200-VC /kernel: KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-5/1/2 - ATTACHED state - acting as standby link
Nov 16 17:54:10  jEX4200-VC lacpd[34373]: LACPD_TIMEOUT: xe-5/1/2: lacp current while timer expired current Receive State: CURRENT
Nov 16 17:54:10  jEX4200-VC /kernel: peer_input_pending_internal:[4219] VKS0 for peer type 25 indx 5 reported a so_error 54
Nov 16 17:54:10  jEX4200-VC /kernel: peer_inputs:4477 VKS0 closing connection peer type 25 indx 5 err 5
Nov 16 17:54:10  jEX4200-VC /kernel: peer_input_pending_internal:[4219] VKS0 for peer type 25 indx 6 reported a so_error 60
Nov 16 17:54:10  jEX4200-VC /kernel: peer_inputs:4477 VKS0 closing connection peer type 25 indx 6 err 5
Nov 16 17:54:11  jEX4200-VC /kernel: KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-6/1/0 - DETACHED state - will not carry traffic
Nov 16 17:54:13  jEX4200-VC /kernel: KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-5/1/0 - DETACHED state - will not carry traffic
Nov 16 17:54:13  jEX4200-VC /kernel: KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-5/1/2 - DETACHED state - will not carry traffic
Nov 16 17:54:15  jEX4200-VC /kernel: pic_listener_connect: conn established: mgmt addr=0x80000017,
Nov 16 17:54:16  jEX4200-VC /kernel: pfem_peer_init:overriding peertype_module
Nov 16 17:54:16  jEX4200-VC fpc7 trunk_stk_mem_add: Recieved vc add for trunk id 1 for the member (device 0 port 26)
Nov 16 17:54:16  jEX4200-VC fpc7 trunk_stk_mem_add: Recieved vc add for trunk id 1 for the member (device 0 port 27)
Nov 16 17:54:16  jEX4200-VC fpc7 trunk_stk_mem_add: Recieved vc add for trunk id 2 for the member (device 0 port 24)
Nov 16 17:54:16  jEX4200-VC fpc7 trunk_stk_mem_add: Recieved vc add for trunk id 2 for the member (device 0 port 25)
Nov 16 17:54:16  jEX4200-VC fpc7 trunk_stk_mem_add: Recieved vc add for trunk id 1 for the member (device 2 port 27)
Nov 16 17:54:16  jEX4200-VC fpc7 trunk_stk_mem_add: Recieved vc add for trunk id 1 for the member (device 2 port 26)
Nov 16 17:54:16  jEX4200-VC /kernel: pic_listener_connect: conn established: mgmt addr=0x80000017,
Nov 16 17:54:16  jEX4200-VC fpc7 trunk_stk_mem_add: Recieved vc add for trunk id 2 for the member (device 2 port 24)
Nov 16 17:54:16  jEX4200-VC fpc7 trunk_stk_mem_add: Recieved vc add for trunk id 2 for the member (device 2 port 25)
Nov 16 17:54:16  jEX4200-VC /kernel: pic_listener_connect: conn established: mgmt addr=0x80000016,
Nov 16 17:54:16  jEX4200-VC fpc7 trunk_stk_mem_add: Recieved vc add for trunk id 1 for the member (device 1 port 25)
Nov 16 17:54:16  jEX4200-VC mib2d[33486]: MIB2D_RTSLIB_READ_FAILURE: check_rtsock_rc: failed in reading dfw: 0 (Operation timed out)
Nov 16 17:54:17  jEX4200-VC fpc7 trunk_stk_mem_add: Recieved vc add for trunk id 1 for the member (device 1 port 24)
Nov 16 17:54:17  jEX4200-VC fpc7 trunk_stk_mem_add: Recieved vc add for trunk id 2 for the member (device 1 port 26)
Nov 16 17:54:17  jEX4200-VC /kernel: pic_listener_connect: conn established: mgmt addr=0x80000016,
Nov 16 17:54:17  jEX4200-VC /kernel: pic_listener_connect: conn established: mgmt addr=0x80000015,
Nov 16 17:54:18  jEX4200-VC /kernel: KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-6/1/0 - ATTACHED state - acting as standby link
Nov 16 17:54:18  jEX4200-VC /kernel: KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-6/1/0 - CD state - ready to carry traffic
Nov 16 17:54:18  jEX4200-VC /kernel: KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-5/1/0 - ATTACHED state - acting as standby link
Nov 16 17:54:18  jEX4200-VC /kernel: KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-5/1/0 - CD state - ready to carry traffic
Nov 16 17:54:18  jEX4200-VC /kernel: if_pfe: Error 5 (Invalid) on IF command 87 (Ae add IFL)
Nov 16 17:54:18  jEX4200-VC last message repeated 5 times
Nov 16 17:54:19  jEX4200-VC /kernel: KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-5/1/2 - ATTACHED state - acting as standby link
Nov 16 17:54:19  jEX4200-VC /kernel: KERN_LACP_INTF_STATE_CHANGE: lacp_update_state_userspace: cifd xe-5/1/2 - CD state - ready to carry traffic
Nov 16 17:54:20  jEX4200-VC fpc7 trunk_stk_mem_add: Recieved vc add for trunk id 2 for the member (device 1 port 27)
Nov 16 17:54:20  jEX4200-VC /kernel: if_pfe: Error 5 (Invalid) on IF command 87 (Ae add IFL)
Nov 16 17:54:21  jEX4200-VC last message repeated 10 times
Nov 16 17:54:21  jEX4200-VC fpc7 Reserved 748 buffers from shared pool for dev 0 type 0.Availability reduced to 3004
Nov 16 17:54:21  jEX4200-VC fpc7 Reserved 748 buffers from shared pool for dev 0 type 0.Availability reduced to 2256
Nov 16 17:54:21  jEX4200-VC fpc7 Reserved 748 buffers from shared pool for dev 1 type 0.Availability reduced to 3004
Nov 16 17:54:21  jEX4200-VC fpc7 Reserved 748 buffers from shared pool for dev 1 type 0.Availability reduced to 2256
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 0
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 1
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 2
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 3
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 4
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 5
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 6
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 7
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 8
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 9
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 10
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 11
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 12
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 13
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 14
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 15
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 16
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_dfw_dyn_init: 17
Nov 16 17:54:21  jEX4200-VC fpc7 Firewall rows need not be redirected on device 0.
Nov 16 17:54:21  jEX4200-VC fpc7 Firewall rows need not be redirected on device 1.
Nov 16 17:54:21  jEX4200-VC fpc7 Firewall rows need not be redirected on device 2.
Nov 16 17:54:21  jEX4200-VC fpc7 Route TCAM rows need not be redirected on device 0.
Nov 16 17:54:21  jEX4200-VC fpc7 Route TCAM rows need not be redirected on device 1.
Nov 16 17:54:21  jEX4200-VC fpc7 Route TCAM rows need not be redirected on device 2.
Nov 16 17:54:21  jEX4200-VC fpc7 PFEM: Enabling traffic for dev 0
Nov 16 17:54:21  jEX4200-VC fpc7 PFEM: Enabling traffic for dev 1
Nov 16 17:54:21  jEX4200-VC fpc7 PFEM: Enabling traffic for dev 2
Nov 16 17:54:21  jEX4200-VC fpc7 pfe_pme_max 24
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_vcp_ifd_change: ifd idx 66 already present
Nov 16 17:54:21  jEX4200-VC fpc7 PFEMAN: fail VCP port update
Nov 16 17:54:21  jEX4200-VC fpc7 mrvl_vcp_ifd_change: ifd idx 67 already present
Nov 16 17:54:22  jEX4200-VC fpc7 PFEMAN: fail VCP port update
Nov 16 17:54:22  jEX4200-VC fpc7 IFRT: 'Aggregate interface ifl add req' (opcode 87) failed
Nov 16 17:54:22  jEX4200-VC fpc7   ifl 65, child ifl 235; child not found
Nov 16 17:54:22  jEX4200-VC fpc7   ifl 65, child ifl 280; child not found
Nov 16 17:54:22  jEX4200-VC fpc7   ifl 66, child ifl 284; child not found
Nov 16 17:54:22  jEX4200-VC fpc7   ifl 66, child ifl 285; child not found
Nov 16 17:54:22  jEX4200-VC fpc7   ifl 67, child ifl 286; child not found
Nov 16 17:54:23  jEX4200-VC fpc7 IFRT: 'Aggregate interface ifl add req' (opcode 87) failed
Nov 16 17:54:23  jEX4200-VC fpc7   ifl 67, child ifl 287; child not found
Nov 16 17:54:23  jEX4200-VC fpc7 Reserved 508 buffers from shared pool for dev 0 type 0.Availability reduced to 2764
Nov 16 17:54:23  jEX4200-VC fpc7 Reserved 508 buffers from shared pool for dev 0 type 0.Availability reduced to 2256
Nov 16 17:54:23  jEX4200-VC fpc7 Reserved 508 buffers from shared pool for dev 1 type 0.Availability reduced to 2764
Nov 16 17:54:24  jEX4200-VC fpc5 PFEMAN: Couldn't write "pfe peer ack reply" msg to master pipe
Nov 16 17:54:25  jEX4200-VC fpc6 PFEMAN: Couldn't write "pfe peer ack reply" msg to master pipe
Nov 16 17:54:25  jEX4200-VC fpc6 PFEMAN: Master socket closed
Nov 16 17:54:25  jEX4200-VC fpc6 PFEMAN disconnected; PFEMAN socket closed abruptly
Nov 16 17:54:25  jEX4200-VC fpc7 Reserved 508 buffers from shared pool for dev 1 type 0.Availability reduced to 2256
Nov 16 17:54:25  jEX4200-VC fpc7 IFRT: 'Aggregate interface ifl add req' (opcode 87) failed
Nov 16 17:54:25  jEX4200-VC fpc7   ifl 73, child ifl 196; child not found
Nov 16 17:54:26  jEX4200-VC fpc6 Routing engine PFEMAN reconnection succeeded after 1 tries
Nov 16 17:54:26  jEX4200-VC /kernel: pic_listener_connect: conn established: mgmt addr=0x80000016,
Nov 16 17:54:26  jEX4200-VC fpc6 PFEMAN master RE reconnection made
Nov 16 17:54:26  jEX4200-VC fpc6 PFEMAN: updated global master on reconnect = 2
Nov 16 17:54:26  jEX4200-VC /kernel: RT_PFE: RT msg op 2 (PREFIX DELETE) failed, err 5 (Invalid)
Nov 16 17:54:26  jEX4200-VC /kernel: last message repeated 337 times
Nov 16 17:54:26  jEX4200-VC /kernel: RT_PFE: NH IPC op 11 (DELETE NEXTHOP) failed, err 7 (Doesn't Exist) peer_class 0, peer_index 6 peer_type 25
Nov 16 17:54:26  jEX4200-VC fpc7 IFRT: 'Aggregate interface ifl add req' (opcode 87) failed
Nov 16 17:54:26  jEX4200-VC fpc7   ifl 73, child ifl 197; child not found
Nov 16 17:54:26  jEX4200-VC mib2d[33486]: MIB2D_RTSLIB_READ_FAILURE: check_rtsock_rc: failed in reading dfw: 0 (Operation timed out)
Nov 16 17:54:27  jEX4200-VC fpc7 IFRT: 'Aggregate interface ifl add req' (opcode 87) failed
Nov 16 17:54:27  jEX4200-VC fpc7   ifl 73, child ifl 198; child not found
Nov 16 17:54:27  jEX4200-VC fpc7   ifl 73, child ifl 199; child not found
Nov 16 17:54:28  jEX4200-VC fpc7 IFRT: 'Aggregate interface ifl add req' (opcode 87) failed
Nov 16 17:54:28  jEX4200-VC fpc7   ifl 73, child ifl 272; child not found
Nov 16 17:54:28  jEX4200-VC fpc6 RT-HAL,rt_msg_handler,589: route check failed 22
Nov 16 17:54:28  jEX4200-VC fpc5 PFEMAN: Couldn't write "NHDB" msg to master pipe
Nov 16 17:54:28  jEX4200-VC fpc5 PFEMAN: Master socket closed
Nov 16 17:54:28  jEX4200-VC fpc5 PFEMAN disconnected; PFEMAN socket closed abruptly
Nov 16 17:54:28  jEX4200-VC fpc7   ifl 73, child ifl 273; child not found
Nov 16 17:54:28  jEX4200-VC fpc5 without IPC pipe/thread pipe 0, thread 1879139784
Nov 16 17:54:29  jEX4200-VC fpc7 IFRT: 'Aggregate interface ifl add req' (opcode 87) failed
Nov 16 17:54:29  jEX4200-VC fpc6 NH: Failed to find nh (1689) for deletion
Nov 16 17:54:29  jEX4200-VC /kernel: pic_listener_connect: conn established: mgmt addr=0x80000015,
Nov 16 17:54:29  jEX4200-VC fpc5 Routing engine PFEMAN reconnection succeeded after 1 tries
Nov 16 17:54:29  jEX4200-VC fpc5 PFEMAN master RE reconnection made
Nov 16 17:54:29  jEX4200-VC fpc5 PFEMAN: updated global master on reconnect = 2
Nov 16 17:54:29  jEX4200-VC /kernel: RT_PFE: RT msg op 2 (PREFIX DELETE) failed, err 5 (Invalid)
Nov 16 17:54:29  jEX4200-VC /kernel: RT_PFE: NH IPC op 11 (DELETE NEXTHOP) failed, err 7 (Doesn't Exist) peer_class 0, peer_index 5 peer_type 25
Nov 16 17:54:29  jEX4200-VC fpc7   ifl 73, child ifl 274; child not found
Nov 16 17:54:29  jEX4200-VC fpc7   ifl 73, child ifl 275; child not found
Nov 16 17:54:30  jEX4200-VC fpc7 IFRT: 'Aggregate interface ifl add req' (opcode 87) failed
Nov 16 17:54:30  jEX4200-VC fpc5 RT-HAL,rt_msg_handler,589: route check failed 22
Nov 16 17:54:30  jEX4200-VC fpc7   ifl 74, child ifl 232; child not found
Nov 16 17:54:30  jEX4200-VC fpc5 NH: Failed to find nh (1689) for deletion
Nov 16 17:54:31  jEX4200-VC fpc7   ifl 75, child ifl 233; child not found
Nov 16 17:54:31  jEX4200-VC fpc7 IFRT: 'Aggregate interface ifl add req' (opcode 87) failed
Nov 16 17:54:31  jEX4200-VC fpc7   ifl 238, child ifl 239; child not found
Nov 16 17:54:36  jEX4200-VC mib2d[33486]: MIB2D_RTSLIB_READ_FAILURE: check_rtsock_rc: failed in reading dfw: 0 (Operation timed out)
Nov 16 17:54:46  jEX4200-VC mib2d[33486]: MIB2D_RTSLIB_READ_FAILURE: check_rtsock_rc: failed in reading dfw: 0 (Operation timed out)
Nov 16 17:54:47  jEX4200-VC mib2d[33486]: SNMP_TRAP_LINK_DOWN: ifIndex 585, ifAdminStatus up(1), ifOperStatus down(2), ifName ae6
Nov 16 17:54:56  jEX4200-VC /kernel: RT_PFE: RT msg op 2 (PREFIX DELETE) failed, err 5 (Invalid)
Nov 16 17:54:56  jEX4200-VC /kernel: RT_PFE: NH IPC op 11 (DELETE NEXTHOP) failed, err 7 (Doesn't Exist) peer_class 0, peer_index 6 peer_type 25
Nov 16 17:54:56  jEX4200-VC last message repeated 8 times
Nov 16 17:54:56  jEX4200-VC /kernel: if_pfe: Error 4 (Exists Already) on IF command 3 (IFD add)
Nov 16 17:54:56  jEX4200-VC last message repeated 2 times
Nov 16 17:54:56  jEX4200-VC last message repeated 6 times
Nov 16 17:54:56  jEX4200-VC last message repeated 4 times
Nov 16 17:54:56  jEX4200-VC last message repeated 3 times
Nov 16 17:54:56  jEX4200-VC last message repeated 47 times
Nov 16 17:54:56  jEX4200-VC /kernel: if_pfe: Error 4 (Exists Already) on IF command 23 (IFL add)
Nov 16 17:54:56  jEX4200-VC /kernel: if_pfe: Error 5 (Invalid) on IF command 87 (Ae add IFL)
Nov 16 17:54:56  jEX4200-VC fpc6 RT-HAL,rt_msg_handler,589: route check failed 22
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1738) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1745) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1671) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1890) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1916) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1905) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2045) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2018) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2038) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 IFRT: 'IFD add' (opcode 3) failed
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 128; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 138; already exists
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2055) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1983) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2020) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 139; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 140; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 141; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 142; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 143; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 144; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 145; already exists
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2047) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1900) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1595) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 146; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 147; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 130; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 148; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 149; already exists
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2056) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1471) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 150; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 151; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 131; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 132; already exists
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1472) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1785) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1549) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2017) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2051) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 135; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 136; already exists
Nov 16 17:54:56  jEX4200-VC fpc6   ifd 137; already exists
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1952) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1633) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2057) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1857) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1909) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1667) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1631) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1684) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1648) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1639) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2000) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1977) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1530) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2011) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1923) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1895) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1988) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1996) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1997) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2036) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2040) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2034) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2032) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2062) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2058) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2059) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2064) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2060) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2061) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2077) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2067) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2068) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2065) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2021) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (2071) for deletion
Nov 16 17:54:56  jEX4200-VC fpc6 NH: Failed to find nh (1598) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 NH: Failed to find nh (2063) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 RT-HAL,rt_msg_handler,589: route check failed 22
Nov 16 17:54:57  jEX4200-VC fpc6 NH: Failed to find nh (1641) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 NH: Failed to find nh (1826) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 NH: Failed to find nh (1651) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 NH: Failed to find nh (1638) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 NH: Failed to find nh (1624) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 NH: Failed to find nh (1577) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 NH: Failed to find nh (1600) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 NH: Failed to find nh (1687) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 NH: Failed to find nh (1536) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 NH: Failed to find nh (1623) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 NH: Failed to find nh (1843) for deletion
Nov 16 17:54:57  jEX4200-VC fpc6 IFRT: 'IFD add' (opcode 3) failed
Nov 16 17:54:57  jEX4200-VC fpc6   ifd 133; already exists
Nov 16 17:54:57  jEX4200-VC fpc6 IFRT: 'IFL add' (opcode 23) failed
Nov 16 17:54:57  jEX4200-VC fpc6   ifl 74; already exists
Nov 16 17:54:57  jEX4200-VC fpc6 IFRT: 'Aggregate interface ifl add req' (opcode 87) failed
Nov 16 17:54:57  jEX4200-VC fpc6   ifl 74, child ifl 232; child already there
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32766,Flags:0x11,Type:1,IFL-Idx:74) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:74) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6   ifd 563; already exists
Nov 16 17:54:57  jEX4200-VC fpc6   ifl 232; already exists
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32767,Flags:0x11,Type:1,IFL-Idx:232) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:3,Flags:0x11,Type:1,IFL-Idx:232) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:232) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6   ifd 134; already exists
Nov 16 17:54:57  jEX4200-VC fpc6   ifl 75; already exists
Nov 16 17:54:57  jEX4200-VC fpc6   ifl 75, child ifl 233; child already there
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32766,Flags:0x11,Type:1,IFL-Idx:75) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:75) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6   ifd 513; already exists
Nov 16 17:54:57  jEX4200-VC fpc6   ifl 233; already exists
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32767,Flags:0x11,Type:1,IFL-Idx:233) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:3,Flags:0x11,Type:1,IFL-Idx:233) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:233) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6   ifl 104; already exists
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32766,Flags:0x11,Type:1,IFL-Idx:104) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:0,Flags:0x11,Type:1,IFL-Idx:104) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:2,Flags:0x11,Type:1,IFL-Idx:104) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:1,Flags:0x11,Type:1,IFL-Idx:104) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:104) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6   ifd 129; already exists
Nov 16 17:54:57  jEX4200-VC fpc6   ifl 65; already exists
Nov 16 17:54:57  jEX4200-VC fpc6   ifl 65, child ifl 235; child already there
Nov 16 17:54:57  jEX4200-VC fpc6   ifl 65, child ifl 280; child already there
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32766,Flags:0x11,Type:1,IFL-Idx:65) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:65) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6   ifd 564; already exists
Nov 16 17:54:57  jEX4200-VC fpc6   ifl 235; already exists
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32767,Flags:0x11,Type:1,IFL-Idx:235) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:3,Flags:0x11,Type:1,IFL-Idx:235) already exists!
Nov 16 17:54:57  jEX4200-VC fpc6 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:235) already exists!
Nov 16 17:54:58  jEX4200-VC mib2d[33486]: SNMP_TRAP_LINK_DOWN: ifIndex 584, ifAdminStatus up(1), ifOperStatus down(2), ifName ae5
Nov 16 17:54:59  jEX4200-VC /kernel: RT_PFE: RT msg op 2 (PREFIX DELETE) failed, err 5 (Invalid)
Nov 16 17:54:59  jEX4200-VC /kernel: last message repeated 68 times
Nov 16 17:54:59  jEX4200-VC /kernel: RT_PFE: NH IPC op 11 (DELETE NEXTHOP) failed, err 7 (Doesn't Exist) peer_class 0, peer_index 5 peer_type 25
Nov 16 17:54:59  jEX4200-VC last message repeated 8 times
Nov 16 17:54:59  jEX4200-VC /kernel: if_pfe: Error 4 (Exists Already) on IF command 3 (IFD add)
Nov 16 17:54:59  jEX4200-VC last message repeated 2 times
Nov 16 17:54:59  jEX4200-VC last message repeated 6 times
Nov 16 17:54:59  jEX4200-VC last message repeated 4 times
Nov 16 17:54:59  jEX4200-VC last message repeated 3 times
Nov 16 17:54:59  jEX4200-VC last message repeated 47 times
Nov 16 17:54:59  jEX4200-VC /kernel: if_pfe: Error 4 (Exists Already) on IF command 23 (IFL add)
Nov 16 17:54:59  jEX4200-VC /kernel: if_pfe: Error 5 (Invalid) on IF command 87 (Ae add IFL)
Nov 16 17:54:59  jEX4200-VC fpc5 RT-HAL,rt_msg_handler,589: route check failed 22
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (1738) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (1745) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (1671) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (1890) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (1916) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (1905) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (2045) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (2018) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (2038) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 IFRT: 'IFD add' (opcode 3) failed
Nov 16 17:54:59  jEX4200-VC fpc5   ifd 128; already exists
Nov 16 17:54:59  jEX4200-VC fpc5   ifd 138; already exists
Nov 16 17:54:59  jEX4200-VC mib2d[33486]: SNMP_TRAP_LINK_DOWN: ifIndex 718, ifAdminStatus up(1), ifOperStatus down(2), ifName vlan.115
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (2055) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (1983) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (2020) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5   ifd 139; already exists
Nov 16 17:54:59  jEX4200-VC fpc5   ifd 140; already exists
Nov 16 17:54:59  jEX4200-VC fpc5   ifd 141; already exists
Nov 16 17:54:59  jEX4200-VC fpc5   ifd 142; already exists
Nov 16 17:54:59  jEX4200-VC fpc5   ifd 143; already exists
Nov 16 17:54:59  jEX4200-VC fpc5   ifd 144; already exists
Nov 16 17:54:59  jEX4200-VC fpc5   ifd 145; already exists
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (2047) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (1900) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5 NH: Failed to find nh (1595) for deletion
Nov 16 17:54:59  jEX4200-VC fpc5   ifd 146; already exists
Nov 16 17:54:59  jEX4200-VC fpc5   ifd 147; already exists
Nov 16 17:54:59  jEX4200-VC fpc5   ifd 130; already exists
Nov 16 17:55:00  jEX4200-VC fpc5   ifd 148; already exists
Nov 16 17:55:00  jEX4200-VC fpc5 IFRT: 'IFD add' (opcode 3) failed
Nov 16 17:55:00  jEX4200-VC fpc5   ifd 149; already exists
Nov 16 17:55:00  jEX4200-VC fpc5 RT-HAL,rt_msg_handler,589: route check failed 22
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (2056) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1471) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5   ifd 150; already exists
Nov 16 17:55:00  jEX4200-VC fpc5   ifd 151; already exists
Nov 16 17:55:00  jEX4200-VC fpc5   ifd 131; already exists
Nov 16 17:55:00  jEX4200-VC fpc5   ifd 132; already exists
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1472) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1785) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1549) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (2017) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (2051) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5   ifd 135; already exists
Nov 16 17:55:00  jEX4200-VC fpc5   ifd 136; already exists
Nov 16 17:55:00  jEX4200-VC fpc5   ifd 137; already exists
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1952) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1633) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (2057) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1857) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1909) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1667) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1631) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1684) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1648) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1639) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (2000) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1977) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1530) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (2011) for deletion
Nov 16 17:55:00  jEX4200-VC fpc5 NH: Failed to find nh (1923) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 RT-HAL,rt_msg_handler,589: route check failed 22
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (1895) for deletion
Nov 16 17:55:00  jEX4200-VC mgd[990]: UI_OPEN_TIMEOUT: Timeout connecting to peer 'autoinstallation'
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (1988) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (1996) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (1997) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2036) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2040) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2034) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2032) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2062) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2058) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2059) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2064) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2060) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2061) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2077) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2067) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2068) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2065) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2021) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2071) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (1598) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (2063) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (1641) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (1826) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (1651) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (1638) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (1624) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (1577) for deletion
Nov 16 17:55:01  jEX4200-VC fpc5 NH: Failed to find nh (1600) for deletion
Nov 16 17:55:02  jEX4200-VC fpc5 NH: Failed to find nh (1687) for deletion
Nov 16 17:55:02  jEX4200-VC fpc5 RT-HAL,rt_msg_handler,589: route check failed 22
Nov 16 17:55:02  jEX4200-VC fpc5 NH: Failed to find nh (1536) for deletion
Nov 16 17:55:02  jEX4200-VC fpc5 NH: Failed to find nh (1623) for deletion
Nov 16 17:55:02  jEX4200-VC fpc5 NH: Failed to find nh (1843) for deletion
Nov 16 17:55:02  jEX4200-VC fpc5 IFRT: 'IFD add' (opcode 3) failed
Nov 16 17:55:02  jEX4200-VC fpc5   ifd 133; already exists
Nov 16 17:55:02  jEX4200-VC fpc5 IFRT: 'IFL add' (opcode 23) failed
Nov 16 17:55:02  jEX4200-VC fpc5   ifl 74; already exists
Nov 16 17:55:03  jEX4200-VC fpc5 IFRT: 'Aggregate interface ifl add req' (opcode 87) failed
Nov 16 17:55:03  jEX4200-VC fpc5   ifl 74, child ifl 232; child already there
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32766,Flags:0x11,Type:1,IFL-Idx:74) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:74) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 IFRT: 'IFD add' (opcode 3) failed
Nov 16 17:55:03  jEX4200-VC fpc5   ifd 563; already exists
Nov 16 17:55:03  jEX4200-VC fpc5 IFRT: 'IFL add' (opcode 23) failed
Nov 16 17:55:03  jEX4200-VC fpc5   ifl 232; already exists
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32767,Flags:0x11,Type:1,IFL-Idx:232) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:3,Flags:0x11,Type:1,IFL-Idx:232) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:232) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5   ifd 134; already exists
Nov 16 17:55:03  jEX4200-VC fpc5   ifl 75; already exists
Nov 16 17:55:03  jEX4200-VC fpc5   ifl 75, child ifl 233; child already there
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32766,Flags:0x11,Type:1,IFL-Idx:75) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:75) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5   ifd 513; already exists
Nov 16 17:55:03  jEX4200-VC fpc5   ifl 233; already exists
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32767,Flags:0x11,Type:1,IFL-Idx:233) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:3,Flags:0x11,Type:1,IFL-Idx:233) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:233) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5   ifl 104; already exists
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32766,Flags:0x11,Type:1,IFL-Idx:104) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:0,Flags:0x11,Type:1,IFL-Idx:104) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:2,Flags:0x11,Type:1,IFL-Idx:104) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:1,Flags:0x11,Type:1,IFL-Idx:104) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:104) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5   ifd 129; already exists
Nov 16 17:55:03  jEX4200-VC fpc5   ifl 65; already exists
Nov 16 17:55:03  jEX4200-VC fpc5   ifl 65, child ifl 235; child already there
Nov 16 17:55:03  jEX4200-VC fpc5   ifl 65, child ifl 280; child already there
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32766,Flags:0x11,Type:1,IFL-Idx:65) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:65) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5   ifd 564; already exists
Nov 16 17:55:03  jEX4200-VC fpc5   ifl 235; already exists
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32767,Flags:0x11,Type:1,IFL-Idx:235) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:3,Flags:0x11,Type:1,IFL-Idx:235) already exists!
Nov 16 17:55:03  jEX4200-VC fpc5 MRVL-L2:mrvl_brg_port_mfilter_add(),10857:MFilter (Idx:32765,Flags:0x11,Type:1,IFL-Idx:235) already exists!
Nov 16 17:55:04  jEX4200-VC fpc7 pfeman_msg2sfi_fdb_mac_del failed, Error(1000) in sending msg2sfi
Nov 16 17:55:40  jEX4200-VC file[983]: UI_CHILD_SIGNALED: Child received signal: PID 985, signal Broken pipe: 13, command='/usr/libexec/ui/show-support'
Как я понимаю, ноги у проблемы растут с fpc7 - там образовалась корка
 show system core-dumps member 7
fpc7:
/var/crash/*core*: No such file or directory
-rw-rw----  1 root  field    3439701 Nov 16 17:55 /var/tmp/pfem.core-tarball.0.tgz
/var/tmp/pics/*core*: No such file or directory
/var/crash/kernel.*: No such file or directory
total files: 1
и на нем меня смущает member 0 с NotPrsnt в virtual-chassis device-topology
fpc7:
                                               Neighbor List
Member  Device  Status   System ID         Member  Device  Interface
   0       0    NotPrsnt 7819.f783.b480
   0       1    NotPrsnt 7819.f783.b481
   0       2    NotPrsnt 7819.f783.b482
   2       6    Prsnt    50c5.8dba.7f80       2       8    internal-0/24
                                              3      10    vcp-0
   2       7    Prsnt    50c5.8dba.7f81       2       8    internal-1/25
                                              7      21    vcp-1
   2       8    Prsnt    50c5.8dba.7f82       2       6    internal-2/24
                                              2       7    internal-2/27
   3       9    Prsnt    b0a8.6e02.3800       3      11    internal-0/24
                                              4      13    vcp-0
   3      10    Prsnt    b0a8.6e02.3801       2       6    vcp-1
                                              3      11    internal-1/25
   3      11    Prsnt    b0a8.6e02.3802       3       9    internal-2/24
                                              3      10    internal-2/27
   4      12    Prsnt    b0a8.6e02.3980       5      16    vcp-0
                                              4      14    internal-0/24
   4      13    Prsnt    b0a8.6e02.3981       3       9    vcp-1
                                              4      14    internal-1/25
   4      14    Prsnt    b0a8.6e02.3982       4      12    internal-2/24
                                              4      13    internal-2/27
   5      15    Prsnt    0026.8867.1400       5      17    internal-0/24
                                              6      19    vcp-0
   5      16    Prsnt    0026.8867.1401       5      17    internal-1/25
                                              4      12    vcp-1
   5      17    Prsnt    0026.8867.1402       5      15    internal-2/24
                                              5      16    internal-2/27
   6      18    Prsnt    7819.f782.ba80       6      20    internal-0/24
                                              7      22    vcp-0
   6      19    Prsnt    7819.f782.ba81       5      15    vcp-1
                                              6      20    internal-1/25
   6      20    Prsnt    7819.f782.ba82       6      18    internal-2/24
                                              6      19    internal-2/27
   7      21    Prsnt    7819.f783.b480       2       7    vcp-0
                                              7      23    internal-0/24
   7      22    Prsnt    7819.f783.b481       6      18    vcp-1
                                              7      23    internal-1/25
   7      23    Prsnt    7819.f783.b482       7      21    internal-2/24
                                              7      22    internal-2/27
На других fpc такого нет, все member-ы верные, все в Prsnt.
В 17.11.2020 в 07:02, mse.rus77 сказал:
Совершенно верно. Почему крешанулся - не ясно, JTAC может подсказать.
В этом выводе тоже нету FPC0 и FPC1:
        7  vcp-1
        2  vcp-1
        3  vcp-1
        4  vcp-1
        5  vcp-1
        6  vcp-1
Покажите пожалуйста вывод "show configuration virtual-chassis".
@mse.rus77
выводите fpc7 из стека. Можно попробовать обнулить его и завести в стек заново, но на свой страх и риск
Ну и если выведете - погоняйте всякое, типа проверки flash
