Сиськовед Posted November 7, 2020 Posted November 7, 2020 Добрый день! На BDCOM GP3600-16B на одной ветке попеременно отваливаются ONU, ветка новая, на ней только две ONU, обе подключены с одного делителя. При появление одной отваливается другая и наоборот. Подскажите в чем может быть причина? В логах следующая картина(похоже на коллизию маков): Nov 7 13:20:02 %GPON-ONUDISABLE: ONU 48575443E61DFF75 is disabled on GPON0/8:2. Nov 7 13:20:02 %GPON-ONUACTIVATE: ONU 48575443E61DFF75 activate failed on GPON0/8:2. Nov 7 13:20:02 %GPON-ONUDISCOVER: ONU 48575443E61DFF75 is discovered on GPON0/8:2. Nov 7 13:16:30 %GPON-ONUDISABLE: ONU 48575443E61DFF75 is disabled on GPON0/8:2. Nov 7 13:16:30 %GPON-ONUACTIVATE: ONU 48575443E61DFF75 activate failed on GPON0/8:2. Nov 7 13:16:29 %GPON-ONUDISCOVER: ONU 48575443E61DFF75 is discovered on GPON0/8:2. Nov 7 13:15:08 %GPON-ONUDISABLE: ONU 48575443E61DFF75 is disabled on GPON0/8:2. Nov 7 13:15:08 %GPON-ONUACTIVATE: ONU 48575443E61DFF75 activate failed on GPON0/8:2. Nov 7 13:15:07 %GPON-ONUDISCOVER: ONU 48575443E61DFF75 is discovered on GPON0/8:2. Nov 7 13:12:08 %GPON-ONUDISABLE: ONU 48575443E61DFF75 is disabled on GPON0/8:2. Nov 7 13:12:08 %GPON-ONUACTIVATE: ONU 48575443E61DFF75 activate failed on GPON0/8:2. Nov 7 13:12:07 %GPON-ONUDISCOVER: ONU 48575443E61DFF75 is discovered on GPON0/8:2. Nov 7 13:11:02 %GPON-ONULOS: ONU 48575443E61DFF75 is offline on GPON0/8:2. Nov 7 13:11:00 %GPON-ONUACTIVATE: ONU 48575443E61DFF77 is activated on GPON0/8:1. Nov 7 13:10:59 %GPON-ONUDISCOVER: ONU 48575443E61DFF77 is discovered on GPON0/8:1. Nov 7 13:10:50 %GPON-ONULOS: ONU 48575443E61DFF77 is offline on GPON0/8:1. Nov 7 13:10:40 %GPON-ONUACTIVATE: ONU 48575443E61DFF75 is activated on GPON0/8:2. Nov 7 13:10:39 %GPON-ONUDISCOVER: ONU 48575443E61DFF75 is discovered on GPON0/8:2. Nov 7 13:09:18 %GPON-ONUDISABLE: ONU 48575443E61DFF75 is disabled on GPON0/8:2. Nov 7 13:09:18 %GPON-ONUACTIVATE: ONU 48575443E61DFF75 activate failed on GPON0/8:2. Nov 7 13:09:17 %GPON-ONUDISCOVER: ONU 48575443E61DFF75 is discovered on GPON0/8:2. Nov 7 13:07:28 %GPON-ONUDISABLE: ONU 48575443E61DFF75 is disabled on GPON0/8:2. Nov 7 13:07:28 %GPON-ONUACTIVATE: ONU 48575443E61DFF75 activate failed on GPON0/8:2. Nov 7 13:07:27 %GPON-ONUDISCOVER: ONU 48575443E61DFF75 is discovered on GPON0/8:2. Nov 7 13:05:18 %GPON-ONUDISABLE: ONU 48575443E61DFF75 is disabled on GPON0/8:2. Nov 7 13:05:18 %GPON-ONUACTIVATE: ONU 48575443E61DFF75 activate failed on GPON0/8:2. Nov 7 13:05:17 %GPON-ONUDISCOVER: ONU 48575443E61DFF75 is discovered on GPON0/8:2. Nov 7 13:05:14 %GPON-ONULOS: ONU 48575443E61DFF75 is offline on GPON0/8:2. Nov 7 13:05:10 %GPON-ONUACTIVATE: ONU 48575443E61DFF77 is activated on GPON0/8:1. Nov 7 13:05:09 %GPON-ONUDISCOVER: ONU 48575443E61DFF77 is discovered on GPON0/8:1. Nov 7 13:02:06 %GPON-ONUDISABLE: ONU 48575443E61DFF77 is disabled on GPON0/8:1. Nov 7 13:02:06 %GPON-ONUACTIVATE: ONU 48575443E61DFF77 activate failed on GPON0/8:1. Nov 7 13:02:05 %GPON-ONUDISCOVER: ONU 48575443E61DFF77 is discovered on GPON0/8:1. Nov 7 13:00:42 %GPON-ONUDISABLE: ONU 48575443E61DFF77 is disabled on GPON0/8:1. Nov 7 13:00:42 %GPON-ONUACTIVATE: ONU 48575443E61DFF77 activate failed on GPON0/8:1. Nov 7 13:00:41 %GPON-ONUDISCOVER: ONU 48575443E61DFF77 is discovered on GPON0/8:1. Nov 7 12:57:52 %GPON-ONUDISABLE: ONU 48575443E61DFF77 is disabled on GPON0/8:1. bdcom-trud#sh gpon optical-transceiver-diagnosis int gpon0/8 interface Temperature(degree) Voltage(V) Current(mA) TxPower(dBm) ----------- --------------------- ------------ ------------- -------------- gpon0/8 46.0 3.3 33.7 7.5 interface RxPower(dBm) ----------- -------------- gpon0/8:1 -20.3 bdcom-trud# bdcom-trud#sh gpon int gpon0/8:1 onu basic-info Serial number HWTC:E61DFF77 (48575443E61DFF77) VendorID HWTC (48575443) Version HZ660.2A (485A3636302E3241000000000000) Traffic management option Priority and rate (2) Battery backup Disable monitoring (0) Admin state Unlock (1) Operational state Enabled (1) EquipmentID ONT1GEZ OMCC version ITU-T G.988 (2010)(Baseline only) Vendor product code 0 Security capability AES-128 (1) Security mode AES-128 (1) Total priority queue number 120 Total traffic scheduler number 15 Total GEM port number 256 Total ethernet UNI number 1 Total VEIP UNI number 1 Total IpHost UNI number 8 Total POTS UNI number 0 Total CATV UNI number 0 Total Private CATV UNI number 0 Image #0 version V3.0.4 (56332E302E340000000000000000) Image #0 status valid/active/committed Image #1 version V3.0.4 (56332E302E340000000000000000) Image #1 status valid/inactive/uncommitted Piggyback DBA reporting Mode 0 only (0) Whole ONU DBA reporting Not supported (0) Distance 11073.0 m Image update state None (0) Operator ID CTC CTC SpecVersion 0 CTC Onu Type SFU (0) TxPowerControl 1 ONU Config Success (2) Applied onutype template N/A ONU Description N/A Online Duration 0h 10m 41s -------------------------------------------------------------- The current time: 2020-11-7 13:21:42 Seq Active Time Deactive Time Deactive Reason 01 2020-10-13 11:29:21 2020-11-07 11:36:15 Ranging failed 02 2020-11-07 11:55:38 2020-11-07 12:06:20 Losi 03 2020-11-07 12:35:44 2020-11-07 12:40:35 Losi 04 2020-11-07 13:05:10 2020-11-07 13:10:50 Losi 05 2020-11-07 13:11:00 bdcom-trud#sh gpon int gpon0/8:2 onu basic-info Serial number HWTC:E61DFF75 (48575443E61DFF75) Applied onutype template N/A ONU Description N/A -------------------------------------------------------------- The current time: 2020-11-7 13:21:56 Seq Active Time Deactive Time Deactive Reason 01 2020-10-13 11:29:21 2020-11-07 11:38:20 Admin ctrol 02 2020-11-07 11:43:54 2020-11-07 11:56:33 Losi 03 2020-11-07 12:05:20 2020-11-07 12:35:50 Losi 04 2020-11-07 12:40:26 2020-11-07 13:05:14 Losi 05 2020-11-07 13:10:40 2020-11-07 13:11:02 Losi Вставить ник Quote
Nikita Devyatyarov Posted November 24, 2020 Posted November 24, 2020 Добрый день! Как правило, deactivate reason "Losi" обозначает проблему на оптике, возможно проблема в делителе, так как обе ОНУ подключены через один. Вставить ник Quote
sexp Posted December 4, 2020 Posted December 4, 2020 нужно играться с профайлом ГПОН-модуля. было такое Вставить ник Quote
Сиськовед Posted December 10, 2020 Author Posted December 10, 2020 В 04.12.2020 в 16:15, sexp сказал: нужно играться с профайлом ГПОН-модуля. было такое Спасибо, проблема ушла при установке: gpon transceiver Any-Reset-Preamble Вставить ник Quote
