Помогите подружить OrangePI one plus и SNR-UPS-LID-600-XPS  через USB и софт NUT.
nut.conf
[snr]
driver = blazer_usb
port = auto
default.battery.voltage.high = 13.60
default.battery.voltage.low = 10.60
runtimecal = 240,100,720,50
Конектится, но параметры не выдает?
root@orangepioneplus:/etc/nut# upsc snr
Init SSL without certificate database
battery.charge: 0
battery.runtime: 1
battery.voltage: 0.00
battery.voltage.high: 13.60
battery.voltage.low: 10.60
battery.voltage.nominal: 0.0
device.mfr:
device.model:
device.type: ups
driver.name: blazer_usb
driver.parameter.pollinterval: 2
driver.parameter.port: auto
driver.parameter.runtimecal: 240,100,720,50
driver.version: 2.7.2
driver.version.internal: 0.11
input.current.nominal: 0.0
input.frequency: 0.0
input.frequency.nominal: 0
input.voltage: 0.0
input.voltage.fault: 0.0
input.voltage.nominal: 0
output.voltage: 0.0
ups.beeper.status: disabled
ups.delay.shutdown: 30
ups.delay.start: 180
ups.firmware:
ups.load: 0
ups.mfr:
ups.model:
ups.productid: 0000
ups.status: OL
ups.temperature: 0.0
ups.type: online
ups.vendorid: 0001
Edited by tosip
  • 2 weeks later...
