новичёк учится- объединить 3 WAN порта в один канал
ну тема  3 вхоящих ван    ,, два ван   работают а по 3 не идут  пакеты  10 раз перепроверил -переделал уже
совет нужен уже всякую чушь гуглю
# jan/02/1970 02:05:17 by RouterOS 6.46.5
# software id = DDNN-M8MS
# model = 951Ui-2HnD
# serial number = 8D0008D5117B
/interface ethernet
set [ find default-name=ether5 ] name=Local
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
set [ find default-name=ether3 ] name=WAN3
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/ip pool
add name=dhcp_pool0 ranges=192.168.0.2-192.168.0.254
/ip dhcp-server
add address-pool=dhcp_pool0 disabled=no interface=Local name=dhcp1
/ip neighbor discovery-settings
set discover-interface-list=all
/ip address
add address=192.168.0.1/24 interface=Local network=192.168.0.0
add address=192.168.1.2/24 interface=WAN1 network=192.168.1.0
add address=192.168.3.2/24 interface=WAN2 network=192.168.3.0
add address=192.168.2.2/24 interface=WAN3 network=192.168.2.0
/ip dhcp-server network
add address=192.168.0.0/24 dns-server=8.8.8.8 gateway=192.168.0.1
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=\
    WAN1_conn
add action=mark-connection chain=input in-interface=WAN2 new-connection-mark=\
    WAN2_conn
add action=mark-routing chain=output connection-mark=WAN1_conn \
    new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn \
    new-routing-mark=to_WAN2
add action=accept chain=prerouting dst-address=192.168.1.0/24 in-interface=\
    Local
add action=accept chain=prerouting dst-address=192.168.3.0/24 in-interface=\
    Local
add action=mark-connection chain=prerouting dst-address-type=!local \
    in-interface=Local new-connection-mark=WAN1_conn passthrough=yes \
    per-connection-classifier=both-addresses-and-ports:3/0
    in-interface=Local new-connection-mark=WAN2_conn passthrough=yes \
    per-connection-classifier=both-addresses-and-ports:3/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
    in-interface=Local new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
    in-interface=Local new-routing-mark=to_WAN2
add action=mark-connection chain=input in-interface=WAN3 new-connection-mark=\
    WAN3_conn
add action=mark-routing chain=prerouting connection-mark=WAN3_conn \
    in-interface=Local new-routing-mark=to_WAN3
add action=accept chain=prerouting dst-address=192.168.2.0/24 in-interface=\
    Local
add action=mark-connection chain=prerouting in-interface=Local \
    new-connection-mark=WAN3_conn passthrough=yes per-connection-classifier=\
    both-addresses-and-ports:3/2
add action=mark-routing chain=output connection-mark=WAN3_conn \
    new-routing-mark=to_WAN3 passthrough=yes
/ip firewall nat
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add action=masquerade chain=srcnat out-interface=WAN3
/ip route
add check-gateway=ping distance=1 gateway=192.168.1.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=192.168.3.1 routing-mark=to_WAN2
add check-gateway=ping distance=1 gateway=192.168.2.1 routing-mark=to_WAN3
add check-gateway=ping distance=2 gateway=192.168.2.1
Edited by trew911
Вам надо балансировать входящий трафик или исходящий? Для исходящего достаточно ECMP
Вообще, вот тут актуален дежурный совет про "надо больше микротиков" - эксплуатировать такие конфигурации "все в одном устройстве" себе дороже, плюс норовят упасть под собственной тяжестью.
RTFM
https://wiki.mikrotik.com/wiki/Manual:IP/Route
https://wiki.mikrotik.com/wiki/Manual:IP/Firewall/Mangle
https://www.freebsd.org/cgi/man.cgi?ipfw(8)
Порядок строк в ИП ФАЙРВОЛ ОЧЕНЬ ВАЖЕН!
Вам надо поменять порядок строчек в адд марке для ВАН3 в цепочке прероутинга.
Совет:  разместите все однотипные команды для ВАН3 в одних группах строк рядом с такими-же строками для ВАН1 и 2, и, я думаю, всё заработает.
З.Ы.
Если не поможет:
1. Напишите через какой ВАН и какие пакеты у Вас не идут.
2. Помните, маршрутизация требует настроек с обеих сторон!
В 07.08.2020 в 20:40, jffulcrum сказал:
ECMP штука простая, вот только таблица роутинга обнуляется каждые 10 минут.
Как следствие — соединение может пойти через другого провайдера, что из-за использования nat'а приведёт к обрыву соединения.
моя схема изначально кривая(((  надо с нуля делать , опять гугл те же самые ссылки и форумы
нужно с нуля
192.168.0.1 my LAN
ether1 - WAN1 - 192.168.1.1
ether2 - WAN2 - 192.168.2.1
как суммировать 2 входящих канала 40 и 30 мбит и получить 70
С нуля а то везде по гайдам начинается с  мангл, а как настроен-сброшен микротик ??    по дефаулту или пустая конфигурация ничего нет
ECMP    да на вики вроде всё просто ,но   какие прежде настройки должны быть?
12 минут назад, maxkst сказал:
Я бы LAN поделил на две части, одну половину отправил бы в интернет через WAN1 а другую через WAN2. Проще уж точно некуда
как можно пример текста?
какой бан вы что я серьёзно я учу только
вот конфиг
# aug/13/2020 00:27:40 by RouterOS 6.46.5
/interface ethernet
/interface wireless
/ip pool
/ip dhcp-server
/ip address
add address=192.168.2.2/24 interface=WAN2 network=192.168.2.0
/ip dns
set servers=192.168.1.1,192.168.2.1,8.8.8.8
/ip firewall mangle
    WAN1_conn
    WAN2_conn
    Local
    Local
add action=mark-connection chain=prerouting connection-mark=no-mark \
    dst-address-type=!local in-interface=Local new-connection-mark=WAN1_conn \
    passthrough=yes per-connection-classifier=both-addresses-and-ports:2/0
    dst-address-type=!local in-interface=Local new-connection-mark=WAN2_conn \
    passthrough=yes per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting new-routing-mark=mixed src-address=\
    192.168.0.0/24
/ip firewall nat
/ip route
add check-gateway=ping distance=1 gateway=192.168.2.1 routing-mark=to_WAN2
/system clock
set time-zone-name=Asia/Yekaterinburg
Edited by trew911
