golova-bdcom#show version
BDCOM(tm) P3310C Software, Version 10.1.0E Build 50174
Copyright by Shanghai Baud Data Communication CO. LTD.
Compiled: 2018-2-6 14:54:39 by SYS, Image text-base: 0x80008000
ROM: System Bootstrap, Version 0.4.1, Serial num:00316004224
System image file is "Switch.bin"
hardware version:V1.0
(RISC) processor with 131072K bytes of memory, 16384K bytes of flash
Base ethernet MAC Address: 84:79:73:5b:c1:7c
snmp info:
  product_ID:294   system_ID:1.3.6.1.4.1.3320.1.294.0
golova-bdcom uptime is 4:01:19:01, The current time: 2020-6-24 22:29:3
Ошибка , не регистрируется ONU терминал. Типо данный MAC адрес в "чёрном списке"
golova-bdcom_config_epon0/2#show epon onu-information interface EPON 0/2
Interface EPON0/2 has registered 19 ONUs:
IntfName   VendorID  ModelID    MAC Address    Description                     BindType  Status          Dereg Reason
EPON0/2:1  BDCM      6001       8479.7399.db7a Uzel                            static    auto-configured N/A
EPON0/2:2  ----      0x00000000 8479.73ed.5faa N/A                             static    lost            unknow
EPON0/2:3  xPON      100Z       e067.b33d.66ea Dog219                          static    deregistered    llid-admin-down
EPON0/2:4  xPON      100Z       e067.b33d.66d2 Dog126_Chap4                    static    auto-configured N/A
EPON0/2:5  ----      0x00000000 e067.b33d.66de N/A                             static    lost            unknow
EPON0/2:6  xPON      100Z       e067.b33d.484b Dog181                          static    auto-configured N/A
EPON0/2:7  xPON      100Z       e067.b33d.66e7 Dog94                           static    auto-configured N/A
EPON0/2:8  xPON      100Z       e067.b33d.66cc Dog122_Uralsk18                 static    auto-configured N/A
EPON0/2:9  ----      0x00000000 544b.9004.f896 N/A                             static    lost            unknow
EPON0/2:10 BDCM      6013       8479.73ed.5f1f Dog110                          static    auto-configured N/A
EPON0/2:11 ZTE       125E       500b.91ea.5882 Dog214                          static    auto-configured N/A
EPON0/2:12 ZTE       125E       500b.91ea.58b8 Dog80                           static    auto-configured N/A
EPON0/2:13 ZTE       125E       500b.91ea.5b6d Dog74                           static    auto-configured N/A
EPON0/2:14 BDCM      6013       8479.73ed.63a1 Dog125                          static    auto-configured N/A
EPON0/2:15 BDCM      6013       8479.73ed.67d3 Dog128                          static    auto-configured N/A
EPON0/2:16 xPON      101Z       e067.b3b6.aad6 Dog139                          static    auto-configured N/A
EPON0/2:17 MONU      D401       8014.a8fb.647c N/A                             static    auto-configured N/A
EPON0/2:18 ----      0x00000000 e067.b3b6.aac0 N/A                             static    lost            unknow
EPON0/2:19 HWTC      310M       2ccf.58e6.69dd N/A                             static    auto-configured N/A
Попробовал как тут https://www.youtube.com/watch?v=IzaWxnFF2QU
golova-bdcom_config_epon0/2#no epon onu-blacklist mac e067.b33d.66ea
  the MAC address (e067.b33d.66ea)is not in the blacklist.
Типа нет в "чёрном списке"...
Кто-нибудь сможет помочь?
3 часа назад, Nikita Devyatyarov сказал:
Добрый день!
Видел Ваше сообщение в телеграм канале, правильно ли я понимаю, что проблема решилась после отключения ONU на какое-то время?
На час.
  • 11 months later...
Добрый день. Прошу помощи, у меня аналогичная проблема, онушки не могут авторизоваться и в статусе пишет llid-admin-down, при этом сигнал на онушке -22.
По голове
Device TypeP3310C
BIOS Version0.4.1
Firmware Version10.1.0F Build 66461
Serial No.00316013749
MAC Address9845.627F.3BB8
Current Time2021-6-16 8:45:29
Uptime491d-17h-33m-4s
Так же как у ТС проверка на blacklist не дала результата, ссылаясь на то, что онушка не в черном списке.
Проблема наблюдается на онушках bdcom p1501dt и на v-sol v2801se. Занятость порта в среднем 50% от максимальной емкости. Подскажите куда копать?
Ситуация очень странная. Смотрите. Заменили sfp модуль, перезагрузили OLT, но ничего не поменялось. Сама проблема вот в чем.
На порту всего 37 онушек, из них 2 не могут авторизоваться. Причем эти 2 рандомные. К примеру какая то из рабочих отключится (по питанию или потеря связи с OLT) то одна из 2х нерабочих становится рабочей и так по кругу. Великий китайский рандом. Обновил прошивку на OLT на 10.1.0F Build 81296, понаблюдаем, что из этого получится.
  • 1 year later...
llid-admin-down
2023год. P3608 тоже такая проблема. Решилось только поднятием уровня сигнала  до -25Дб, но после этого со всеми бубнами не взлетело.
к вылизыванию линии добавили ребут и помогло...
