Всем привет. Поставил на HP DL360 G6 debian 10, завел туда vlan. и на этом виртуальном интерфейсе идут странные дропы, причем на физическом интерфейсе и на порту со стороны коммутатора порты чисты:
Скрытый текст
ens1f0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet6 fe80::92e2:baff:fe1b:9114  prefixlen 64  scopeid 0x20<link>
        ether 90:e2:ba:1b:91:14  txqueuelen 10000  (Ethernet)
        RX packets 960705  bytes 111830032 (106.6 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 34740  bytes 5727011 (5.4 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device memory 0xfbfe0000-fbffffff
ens1f0.4: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 1.1.1.1  netmask 255.255.255.0  broadcast 1.1.1.255
        RX packets 959419  bytes 98314532 (93.7 MiB)
        RX errors 0  dropped 11139  overruns 0  frame 0
        TX packets 33731  bytes 5671885 (5.4 MiB)
ethtool -S ens1f0 тоже чистый:
Скрытый текст
NIC statistics:
     rx_packets: 973720
     tx_packets: 35724
     rx_bytes: 120759858
     tx_bytes: 6176447
     rx_broadcast: 935912
     tx_broadcast: 9
     rx_multicast: 1673
     tx_multicast: 68
     multicast: 1673
     collisions: 0
     rx_crc_errors: 0
     rx_no_buffer_count: 0
     rx_missed_errors: 0
     tx_aborted_errors: 0
     tx_carrier_errors: 0
     tx_window_errors: 0
     tx_abort_late_coll: 0
     tx_deferred_ok: 0
     tx_single_coll_ok: 0
     tx_multi_coll_ok: 0
     tx_timeout_count: 0
     rx_long_length_errors: 0
     rx_short_length_errors: 0
     rx_align_errors: 0
     tx_tcp_seg_good: 0
     tx_tcp_seg_failed: 0
     rx_flow_control_xon: 0
     rx_flow_control_xoff: 0
     tx_flow_control_xon: 0
     tx_flow_control_xoff: 0
     rx_long_byte_count: 120759858
     tx_dma_out_of_sync: 0
     tx_smbus: 0
     rx_smbus: 0
     dropped_smbus: 0
     os2bmc_rx_by_bmc: 0
     os2bmc_tx_by_bmc: 0
     os2bmc_tx_by_host: 0
     os2bmc_rx_by_host: 0
     tx_hwtstamp_timeouts: 0
     tx_hwtstamp_skipped: 0
     rx_hwtstamp_cleared: 0
     rx_errors: 0
     tx_errors: 0
     tx_dropped: 0
     rx_length_errors: 0
     rx_over_errors: 0
     rx_frame_errors: 0
     rx_fifo_errors: 0
     tx_fifo_errors: 0
     tx_heartbeat_errors: 0
     tx_queue_0_packets: 2773
     tx_queue_0_bytes: 259564
     tx_queue_0_restart: 0
     tx_queue_1_packets: 4536
     tx_queue_1_bytes: 403732
     tx_queue_1_restart: 0
     tx_queue_2_packets: 6511
     tx_queue_2_bytes: 2669154
     tx_queue_2_restart: 0
     tx_queue_3_packets: 3207
     tx_queue_3_bytes: 303544
     tx_queue_3_restart: 0
     tx_queue_4_packets: 4979
     tx_queue_4_bytes: 947099
     tx_queue_4_restart: 0
     tx_queue_5_packets: 6113
     tx_queue_5_bytes: 597629
     tx_queue_5_restart: 0
     tx_queue_6_packets: 2994
     tx_queue_6_bytes: 275093
     tx_queue_6_restart: 0
     tx_queue_7_packets: 4611
     tx_queue_7_bytes: 406066
     tx_queue_7_restart: 0
     rx_queue_0_packets: 441018
     rx_queue_0_bytes: 27338079
     rx_queue_0_drops: 0
     rx_queue_0_csum_err: 0
     rx_queue_0_alloc_failed: 0
     rx_queue_1_packets: 4571
     rx_queue_1_bytes: 805373
     rx_queue_1_drops: 0
     rx_queue_1_csum_err: 0
     rx_queue_1_alloc_failed: 0
     rx_queue_2_packets: 3102
     rx_queue_2_bytes: 842645
     rx_queue_2_drops: 0
     rx_queue_2_csum_err: 0
     rx_queue_2_alloc_failed: 0
     rx_queue_3_packets: 171201
     rx_queue_3_bytes: 26365213
     rx_queue_3_drops: 0
     rx_queue_3_csum_err: 0
     rx_queue_3_alloc_failed: 0
     rx_queue_4_packets: 6959
     rx_queue_4_bytes: 3166158
     rx_queue_4_drops: 0
     rx_queue_4_csum_err: 0
     rx_queue_4_alloc_failed: 0
     rx_queue_5_packets: 171130
     rx_queue_5_bytes: 26708756
     rx_queue_5_drops: 0
     rx_queue_5_csum_err: 0
     rx_queue_5_alloc_failed: 0
     rx_queue_6_packets: 169942
     rx_queue_6_bytes: 27020495
     rx_queue_6_drops: 0
     rx_queue_6_csum_err: 0
     rx_queue_6_alloc_failed: 0
     rx_queue_7_packets: 5797
     rx_queue_7_bytes: 725831
     rx_queue_7_drops: 0
     rx_queue_7_csum_err: 0
     rx_queue_7_alloc_failed: 0
Как это понимать вообще? куда пакеты дропаться могут в таком случае? На серваке нагрузки никакой, сетевого обмена тоже никакого, просто сижу и по ssh его настраиваю. стоит вообще бить тревогу? Сетевая стоит Intel Corporation 82576 Gigabit Network Connection (rev 01), двухголовая. Переключался на встроенные сетевые, там те же самые дропы.
20 часов назад, jffulcrum сказал:
Возьмите tcpdump да и посмотрите, что там прилетает из сети. Чаще всего у какого-то устройства в сети jumbo кадры были включены.
Смотрел tsharkом. Бывают прилетают icmpv6 и dhcpv6. Как там вообще распознать то, что будет дропаться системой? на других железках в этой сети дропов таких нет, отличие этих железок в том, что на других стоит centos 6, а здесь debian 10. Может что-то в сетевой подсистеме изменилось, так, что некоторые отброшенные пакеты, стали учитываться в дропах?
Вот так dropwatch отработал:
dropwatch> start
Enabling monitoring...
Kernel monitoring activated.
Issue Ctrl-C to stop monitoring
1 drops at location 0xffffffffb2a30f07 [software]
1 drops at location 0xffffffffb29e3801 [software]
2 drops at location 0xffffffffb2a30f07 [software]
^CGot a stop message
dropwatch> exit
Shutting down ...
как понять из этого кто пакеты дропает?
2 часа назад, roma33rus сказал:
Такое вижу впервые...уж не поломали ли вас? Попробуйте захватить эти дропнутые пакеты и посмотреть, что в них, методика захвата в https://github.com/Mellanox/mlxsw/wiki/Packet-Drops-Monitoring#packet-dissection-using-wireshark
Какая-то у меня прям неудача с железкой. rsync не копирует большие файлы, при этом винты отваливаются. в инете вычитал, что это проблема с драйверами контроллера hp smart array. Сейчас решил free поставить. Сервак быстрее надо привести в рабочее состояние. Времени на эксперименты нет к сожалению.
P.S.: dwdump попробовал по быстрому. Не взлетело. Утилита собралась скорее всего без чего-то нужного.
А мне тоже интересно стало, есть CentOS7, на интерфейс em2 летит зеркало трафика с коммутатора с двух VLAN.
em2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        ether X:X:X:X:X:X  txqueuelen 10000  (Ethernet)
        RX packets 894616  bytes 1025401074 (977.8 MiB)
        RX errors 0  dropped 202700  overruns 0  frame 0
        TX packets 2  bytes 92 (92.0 B)
и в ethtool -S тоже по нулям.
dropwatch
Initalizing null lookup method
dropwatch> start
2 drops at location 0xffffffff815d3521
1 drops at location 0xffffffff815c2d40
1 drops at location 0xffffffff815d3521
1 drops at location 0xffffffff81593858
2 drops at location 0xffffffff8160d6e9
2 drops at location 0xffffffff815c2d40
3 drops at location 0xffffffff815d3521
После недолгих запусков tcpdump
382 packets received by filter
0 packets dropped by kernel
44 packets dropped by interface
        RX packets 898386  bytes 1027319612 (979.7 MiB)
        RX errors 0  dropped 203942  overruns 0  frame 0
Дропы растут именно после запусков tcpdump, при этом FC выключен с обоих сторон..
В 25.05.2020 в 16:44, hsvt сказал:
dropwatch
dropwatch> start
Вам удалось как-то победить такую проблему?
3 часа назад, roma33rus сказал:
Да, в моём случае на em2 летели кадры с VLAN который сервер не ждал и видимо срабатывал какой то ingress checking. Создал интерфейс в том VLAN который в тесте зеркалирую и всё в порядке стало.
tcpdump: listening on em2.777, link-type EN10MB (Ethernet), capture size 262144 bytes
^C2938 packets captured
2938 packets received by filter
