Что нужно подкрутить, чтоб снизить нагрузку на маршрутизатор
Посоветуйте, что нужно подкрутить, чтоб снизить нагрузку на маршрутизатор.
Пока только нашел address-list-timeout=1h, но полагаю это не единственное что можно подкрутить!?
Модель - CCR1036.
Скрытый текст
/ip firewall address-list
add address=0.0.0.0/8 list=BOGON
add address=10.0.0.0/8 list=BOGON
add address=100.64.0.0/10 list=BOGON
add address=127.0.0.0/8 list=BOGON
add address=169.254.0.0/16 list=BOGON
add address=172.16.0.0/12 list=BOGON
add address=192.0.0.0/24 list=BOGON
add address=192.0.2.0/24 list=BOGON
add address=192.168.0.0/16 list=BOGON
add address=198.18.0.0/15 list=BOGON
add address=198.51.100.0/24 list=BOGON
add address=203.0.113.0/24 list=BOGON
add address=224.0.0.0/4 list=BOGON
add address=240.0.0.0/4 list=BOGON
/ip firewall filter
add action=accept chain=input comment="Accept all incoming input established connections" connection-state=established,related
add action=accept chain=forward comment="Accept all incoming forward (transit traffic) established connections" connection-state=established,related
add action=drop chain=input comment="Drop all incoming input invalid connections" connection-state=invalid
add action=drop chain=forward comment="Drop all incoming forward (transit traffic) invalid connections" connection-state=invalid
add action=drop chain=forward comment="Drop all incoming connections to WAN which are not DSTNAT'ed" connection-nat-state=!dstnat in-interface-list=WAN
add action=drop chain=input comment="Drop ICMP echo request to interface WAN" in-interface-list=!LAN protocol=icmp
add action=drop chain=input comment="Drop all incoming packages to interface WAN" in-interface-list=WAN
add action=drop chain=forward comment="Limit 200, to each address" connection-limit=200,32 in-interface-list=LAN protocol=tcp
add action=drop chain=forward comment="Limit 200, to each address" connection-limit=200,32 in-interface-list=LAN protocol=udp
add action=accept chain=forward comment="IPsec connections" ipsec-policy=in,ipsec
add action=accept chain=forward comment="IPsec connections" ipsec-policy=out,ipsec
add action=drop chain=input comment="Block Bogon IP Address" disabled=yes in-interface-list=!LAN src-address-list=BOGON
add action=drop chain=forward comment="Block Bogon IP Address" disabled=yes in-interface-list=!LAN src-address-list=BOGON
/ ip firewall mangle;
add action=mark-connection chain=prerouting in-interface=ISP1 connection-mark=no-mark new-connection-mark=connection_to_ISP1 passthrough=no disabled=no;
add action=mark-connection chain=prerouting in-interface=ISP2 connection-mark=no-mark new-connection-mark=connection_to_ISP2 passthrough=no disabled=no;
add action=mark-connection chain=prerouting in-interface-list=LAN dst-address-type=!local connection-mark=no-mark new-connection-mark=connection_to_ISP1 per-connection-classifier=both-addresses:2/0 passthrough=yes disabled=no;
add action=mark-connection chain=prerouting in-interface-list=LAN dst-address-type=!local connection-mark=no-mark new-connection-mark=connection_to_ISP2 per-connection-classifier=both-addresses:2/1 passthrough=yes disabled=no;
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set www-ssl disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=none
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
@feeman Сори, я в микротах не спец. Это был дружеский совет по содержанию вопроса. В теме стоит описывать проблему подробнее. Уверен, если опишите что у Вас за проблема, то ответ будет точно быстрее и актуальнее.
Например, у меня остался вопрос:
Что значит "снизить нагрузку"? Чем так перегружен роутер? Какой тип трафика? Что рутит?
Варианты:
1) Купить нормальный маршрутизатор.
2) Нанять разбирающегося человека
6 минут назад, TriKS сказал:
Варианты:
Либо, отправить в бан @TriKS , чтоб офтопов не было.
43 минуты назад, sdy_moscow сказал:
Специально был создан "загончик" для счастливых обладателей одного вендора.
Но вот, что вас туда тянет если вы не в теме!?
Только что, alibek сказал:
Зачем его ждать? Нужно ещё два микротика купить, других советов не бывает.
Ну вообще-то это очевидно из конфига ТС.
У него два ISP. На каждого нужен свой микротик, а потом их через ospf объединить с 3-им.
А там уже думать надо что хочется. Можно их вообще по bgp объединить и сделать ecmp с as-path-relax, а можно и просто актив\бекап сделать благодаря netwatch.
45 минут назад, alibek сказал:
Всё уже сделано по некрофеншую. Одна финча - один микротик )))
Актуальный вопрос пожалуй в плане NAT'а.
46 минут назад, vurd сказал:
as-path multipath-relax ?
@vurd , а вы разве на сети используете некротики?
1 минуту назад, sheft сказал:
в чём собственно тормоза?
За тормоза пока не говорил! Но, хотелось бы перебЗЪдеть...
Есть же best practice джентльменский набор - для уменьшения нагрузки
15 минут назад, sheft сказал:
в конфиге ната не увидел
Полагал, что это неактуально
/interface list member;
add interface=ISP1 list=WAN;
add interface=ISP2 list=WAN;/
/ip firewall nat;
add action=masquerade chain=srcnat out-interface-list=WAN;/
Я бы запасся резервным БП и резервным некротом. Лично у меня, после тех чудес что наблюдались, к микротику жуткое недоверие, т.к. когда его начинает "плющить" понять, что с ним не так - не представляется возможным от слова "совсем".
А вышеуказанная модель именно так себя ведет. Если не дай бог питание начнет шалить, то на флэш памяти легко может случится что-то странное. Помогает только сброс и повторная перепрошивка. Поэтому на время возни второй подготовленный не помешает.
1 час назад, feeman сказал:
На сети нет. Дома использую, держу небольшой vpls домен от дома до столба с камерой и до квартиры. Мне прикольно.
Подскажите, почему не работает правило address-list-timeout=1h ?
/ip firewall filter add action=add-src-to-address-list address-list=users_sessions address-list-timeout=1h dst-address-type=!local chain=forward;/
/ip firewall address-list;
add address=10.0.0.0/8 disabled=no list=users_sessions;/
Для проверки, чтоб наверняка, поставил правило в firewall filter первым в списке. Но оно почему-то не работает...
@feeman если Нат используете. При большом количестве трафика таблица конекшен трекинг может раздуваться стоит снизить время на запись в таблице некоторых соединений.
@feeman ещё можно отключить не нужные модули которые не использукте.
Отключить внутренних базу dns.
Не стоит формировать графики на самом микротикe. Так же пагубно влияет опрос по snmp
6 минут назад, pingz сказал:
Сделано:
Скрытый текст
/ip service
set enabled=no
/tool mac-server
set enabled=no
12 минут назад, pingz сказал:
На данный момент использую как кеширующий.
8 минут назад, pingz сказал:
а графики и snmp на микротике вещи не взаимосвязанные?
