Добрый день, не могу понять глюк. Можно ли сделать зеркало трафика из 10гб интерфейса в 1г, при условии, что у 10г интерфейса трафика не больше 1гб/с.
Eth1/0/27 - 10G
Есть
  SNR-S2995G-24TX Device, Compiled on Jul 09 15:52:00 2018
  sysLocation Building 57/2,Predelnaya st, Ekaterinburg, Russia
  CPU Mac f8:f0:82:79:05:05
  Vlan MAC f8:f0:82:79:05:04
  SoftWare Package Version 7.5.3.2(R0004.0084)
  BootRom Version 7.5.21
  HardWare Version 1.0.1
  CPLD Version 1.08
Создал простой mirror:
SNR-S2995G-Maya#show monitor
monitor session 1:
Destination Ethernet1/0/24
Card: slot 1
source ports:
  RX port: 27
  TX port: 27
No monitor in session 2
Видно, что есть трафик:
SNR-S2995G-Maya#show int ethernet 1/0/24
Interface brief:
  Ethernet1/0/24 is up, line protocol is up
  Ethernet1/0/24 is layer 2 port, alias name is reductor, index is 24
  Hardware is Gigabit-TX, address is f8-f0-82-79-05-05
  PVID is 1
  MTU 2000 bytes, BW 1000000 Kbit
  Time since last status change:0w-0d-1h-32m-19s  (5539 seconds)
  Encapsulation ARPA, Loopback not set
  Auto-duplex: Negotiation full-duplex, Auto-speed: Negotiation 1G bits
  FlowControl is off, MDI type is auto
Statistics:
  5 minute input rate 300 bits/sec, 1 packets/sec
  5 minute output rate 827421157 bits/sec, 173196 packets/sec
  The last 5 second input rate 0 bits/sec, 0 packets/sec
  The last 5 second output rate 828491002 bits/sec, 170538 packets/sec
  Input packets statistics:
    7956 input packets, 509304 bytes, 0 no buffer
    0 unicast packets, 8 multicast packets, 120 broadcast packets
    0 input errors, 0 CRC, 0 frame alignment, 0 overrun, 0 ignored,
    0 abort, 0 length error, 0 undersize 0 jabber, 0 fragments, 7828 pause frame
  Output packets statistics:
    3458300677 output packets, 2028380402937 bytes, 0 underruns
    3458025873 unicast packets, 111104 multicast packets, 163700 broadcast packets
    0 output errors, 0 collisions, 0 late collisions, 0 pause frame
Но на Линукс трафика не вижу:
[root@localhost ~]# tcpdump -n -i eth1
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth1, link-type EN10MB (Ethernet), capture size 65535 bytes
18:09:12.944536 STP 802.1w, Rapid STP, Flags [Learn, Forward, Agreement], bridge-id 8000.e0:d9:e3:2a:4a:40.6980, length 43
18:09:12.944562 STP 802.1w, Rapid STP, Flags [Learn, Forward, Agreement], bridge-id 8000.e0:d9:e3:2a:4a:40.6980, length 43
18:09:14.944180 STP 802.1w, Rapid STP, Flags [Learn, Forward, Agreement], bridge-id 8000.e0:d9:e3:2a:4a:40.6980, length 43
18:09:14.944201 STP 802.1w, Rapid STP, Flags [Learn, Forward, Agreement], bridge-id 8000.e0:d9:e3:2a:4a:40.6980, length 43
18:09:16.947129 STP 802.1w, Rapid STP, Flags [Learn, Forward, Agreement], bridge-id 8000.e0:d9:e3:2a:4a:40.6980, length 43
18:09:16.947146 STP 802.1w, Rapid STP, Flags [Learn, Forward, Agreement], bridge-id 8000.e0:d9:e3:2a:4a:40.6980, length 43
18:09:17.249701
18:09:17.249716
18:09:18.944082 STP 802.1w, Rapid STP, Flags [Learn, Forward, Agreement], bridge-id 8000.e0:d9:e3:2a:4a:40.6980, length 43
18:09:18.944104 STP 802.1w, Rapid STP, Flags [Learn, Forward, Agreement], bridge-id 8000.e0:d9:e3:2a:4a:40.6980, length 43
18:09:20.944117 STP 802.1w, Rapid STP, Flags [Learn, Forward, Agreement], bridge-id 8000.e0:d9:e3:2a:4a:40.6980, length 43
18:09:20.944140 STP 802.1w, Rapid STP, Flags [Learn, Forward, Agreement], bridge-id 8000.e0:d9:e3:2a:4a:40.6980, length 43
18:09:22.944535 STP 802.1w, Rapid STP, Flags [Learn, Forward, Agreement], bridge-id 8000.e0:d9:e3:2a:4a:40.6980, length 43
@TRIada
Добрый день!
Можно даже если больше.
Возможно интерфейс не переключается в promiscuous mode, либо MTU меньше чем в зеркале.
Обновите версию ПО на последнюю рекомендуемую, эту проблему это не решит, но было исправлено много других проблем, используемая вами версия очень старая.
