Кнонибудь проверял будет-ли работать след схема с cisco Airnet
AccessPoint-----Repeater-----Repeater----Client ?
схема AccessPoint-----Repeater-----Client работает, сейчас не хватает железа проверить схему с двумя репитерами
Репитер работает только от точки доступа.
AP > AP >AP >AP ... > Client , i vsjo eto v rezhime WDS .Budet
странно, каким образом wds может тут помочь?
When you configure Wireless Domain Services on your network, access points on your wireless LAN use the WDS device (either an access point or a switch configured as the WDS device) to provide fast, secure roaming for client devices and to participate in radio management. If you use a switch as the WDS device, the switch must be equipped with a Wireless LAN Services Module (WLSM). An access point configured as the WDS device supports up to 60 participating access points. A WLSM-equipped switch supports up to 300 participating access points.
Fast, secure roaming provides rapid reauthentication when a client device roams from one access point to another, preventing delays in voice and other time-sensitive applications.
Access points participating in radio management forward information about the radio environment (such as possible rogue access points and client associations and disassociations) to the WDS device. The WDS device aggregates the information and forwards it to a wireless LAN solution engine (WLSE) device on your network.
это ведь только роуминг клиентов между станциями
