Добрый день.Приехала железка p3310d.
Проблема в следующем, onu попадает в vlan 1, пользователь за ней в правильный влан.Не могу понять причину.
выдержки из конфига.
BDCOM(tm) P3310D Software, Version 10.1.0F Build 69083
#show running-config
Building configuration...
Current configuration:
!version 10.1.0F build 69083
service timestamps log date
service timestamps debug date
service password-encryption
logging buffered 4096
ip default-gateway 172.18.0.254
epon oam-version 1 0x30
epon oam-version 2 0x21
epon oam-version 3 0x20
epon onu-config-template PON-1
 cmd-sequence 001 switchport port-security dynamic maximum 10
 cmd-sequence 002 switchport port-security mode dynamic
 cmd-sequence 003 epon onu all-port ctc vlan mode tag 800
 cmd-sequence 004 epon onu all-port ctc loopback detect
!!slot 0 89 unknow CARD
interface GigaEthernet0/1
 description Uplink
 switchport trunk vlan-allowed 500,800-803
 switchport trunk vlan-untagged none
 switchport mode trunk
 switchport pvid 500
interface EPON0/2
 epon pre-config-template PON-1 binded-onu-llid 1-64
 epon bind-onu mac 9845.623f.9b31 1
 switchport trunk vlan-allowed 800
 switchport protected 1
interface EPON0/2:1
  epon onu port 1 ctc vlan mode tag 800 priority 0
  epon onu port 1 ctc loopback detect
interface VLAN500
 description MANAGEMENT
 ip address 172.18.0.1 255.255.255.0
filter enable
vlan 1,500,800-803
 loopback-detection
line console 0
 length 0
 width 256
ip sshd auth-method ssh-auth
ip sshd save
ip sshd enable
Таблица MAC
        Mac Address Table (Total 4)
Vlan    Mac Address       Type       Ports
All     9845.6296.0d2e    STATIC     CPU
500     b869.f400.8c9d    DYNAMIC    g0/1
800     b869.f400.8c9d    DYNAMIC    g0/1
1       9845.623f.9b31    DYNAMIC    epon0/2:1
800     90e6.ba1b.8cbc    DYNAMIC    epon0/2:1
Вланы
novopyshkino_pon#show vlan
VLAN Status  Name                             Ports
1    Static  Default                          g0/3, g0/4, g0/5, g0/6, epon0/3
                                              epon0/4
500  Static  VLAN0500                         g0/1, g0/2
800  Static  VLAN0800                         g0/1, g0/2, epon0/1, epon0/2
801  Static  VLAN0801                         g0/1, g0/2
802  Static  VLAN0802                         g0/1, g0/2
803  Static  VLAN0803                         g0/1, g0/2
1 час назад, stik сказал:
Добрый день!
Вы назначаете в настройках "interface EPON0/2:1" номер VLAN для UNI порта ONU.
Уточните, на самой ОНУ какие-то настройки применены?
53 минуты назад, Nikita Devyatyarov сказал:
Добрый день!
Что имеется ввиду?
если epon onu ctc ip address static A.B.C.D 255.255.255.0 gateway A.B.C.254 cvlan XX svlan X
то нет.
Только шаблон
3 часа назад, stik сказал:
Вывод с интерфейса
show vlan interface epon0/2
Interface            VLAN
Name                 Property PVID Vlan-Map         uTagg-Vlan-Map
EPON0/2              Trunk    1    800              none
Onu - PVID 1?
15 часов назад, stik сказал:
Что имеется ввиду?
ОНУ также имеет настройки через WEB, предполагаю, что может быть там создан WAN-интерфейс.
Вывод с интерфейса
Interface            VLAN
Onu - PVID 1?
Да, по умолчанию, если на ONU WAN-интерфейс создан без указания определенного VLAN - трафик с данного WAN передается в режиме access. На EPON-порту установлен PVID = 1 и кадры без тега 802.1Q приходят в 1 VLAN.
