Имеется роутер на Centos7
Прописываю:
arp -s 1.2.3.4 04:D1:69:8D:35:FF -i vlan100
В sysctl.conf:
net.ipv4.conf.all.arp_ignore = 1
net.ipv4.conf.all.arp_announce = 2
На тестовом устройстве с другим MAC-адресом указываю ip-адрес 1.2.3.4. Получаю доступ к сети. Почему так происходит, я ведь указал статический mac? Почему я с другого мака получаю доступ?
Edited by tranger
1.2.3.1 - наш роутер
1.2.3.4 - наш IP
05:C9:55:1E:86:FE - мак роутера
14:19:16.660585 ARP, Request who-has 1.2.3.4 tell 0.0.0.0, length 46
14:19:16.905173 ARP, Request who-has 1.2.3.1 tell 1.2.3.4, length 46
14:19:16.905198 ARP, Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE (oui Unknown), length 28
14:19:17.658867 ARP, Request who-has 1.2.3.4 tell 0.0.0.0, length 46
14:19:18.657202 ARP, Request who-has 1.2.3.4 tell 0.0.0.0, length 46
14:19:19.655526 ARP, Request who-has 1.2.3.4 tell 1.2.3.4, length 46
14:19:19.808556 ARP, Request who-has 1.2.3.1 tell 1.2.3.4, length 46
14:19:19.808574 ARP, Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE (oui Unknown), length 28
14:19:20.373830 ARP, Request who-has 1.2.3.1 tell 1.2.3.4, length 46
14:19:20.373860 ARP, Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE (oui Unknown), length 28
14:19:22.515048 ARP, Request who-has 1.2.3.1 tell 1.2.3.4, length 46
14:19:22.515063 ARP, Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE (oui Unknown), length 28
14:19:22.560357 ARP, Request who-has 1.2.3.1 tell 1.2.3.4, length 46
14:19:22.560372 ARP, Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE (oui Unknown), length 28
14:19:23.129135 ARP, Request who-has 1.2.3.1 tell 1.2.3.4, length 46
14:19:23.129156 ARP, Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE (oui Unknown), length 28
14:19:23.424724 ARP, Request who-has 1.2.3.1 tell 1.2.3.4, length 46
14:19:23.424744 ARP, Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE (oui Unknown), length 28
14:19:27.209361 ARP, Request who-has 1.2.3.1 tell 1.2.3.4, length 46
14:19:27.209379 ARP, Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE (oui Unknown), length 28
В таблицу запись становится:
1.2.3.4             ether   04:d1:69:8d:35:ff   CM                    vlan100
Трафик летит точно с указанного IP-адреса.
Как втыкаю кабель в тестовое устройство, tcpdump показывает то что я выше опубликовал, дальше летит трафик во внешку
И ещё когда тестовое устройство втыкаю с прописанным IP-адресом, в arp таблице я не вижу МАКа этого устройства. Арп таблица показывает прописанный руками мак.
Я уже со всеми параметрами игрался arp_ignore, arp_announce, rp_filter - нифига не помогает
Поэтому и написал на форум, может кто-то с подобным встречался.
Точно могу сказать, что год назад всё работало. Но за этот год никаких изменений не делали (кроме обновления пакетов yum update). У сервера аптайм 558 дней. Хрен знает, может ребутнуть его :-) (Ребутнуть смогу только ночью, много абонентов работает...)
Edited by tranger
4 часа назад, tranger сказал:
Что вы хотите сделать?
1.2.3.4 - наш IP
tcpdump -e -n ...
то что у вас - без мак адресов, на половину бесполезно для понимания.
2 часа назад, tranger сказал:
rp_filter
Вообще из другой оперы.
3 часа назад, Ivan_83 сказал:
Хочу чтобы при подмене IP-адреса у абонента не было доступа к сети, так как на роутере был указан статический MAC-адрес
Хз, проверил сейчас , как и положено пакетики от клиента без проблем просачиваются наружу , но ответы летят на неправильный мак адрес, и до этого абонента уже не доходят
08:52:40.005566 52:54:00:86:48:62 > 8e:12:8e:d5:9c:21, ethertype IPv4 (0x0800), length 98: 172.20.0.3 > 8.8.8.8: ICMP echo request, id 15999, seq 1, length 64
08:52:40.080633 8e:12:8e:d5:9c:21 > 52:54:00:86:48:61, ethertype IPv4 (0x0800), length 98: 8.8.8.8 > 172.20.0.3: ICMP echo reply, id 15999, seq 1, length 64
На клиенте при этом естественно 100% потерь
3 часа назад, orlik сказал:
На тестовом сервере всё отлично работает, на тестовом устройстве 100% потерь. Не могу понять в чём же дело... Ребут не помог :-)
Вот ещё раз tcpdump:
1.2.3.4 - наш IP
04:D1:69:8D:35:FF - прописанный мак в арп (arp -s 1.2.3.4 04:D1:69:8D:35:FF -i vlan100)
00:24:54:ca:b0:ba - мак тестового устройства
08:27:36.184409 00:24:54:ca:b0:ba > Broadcast, ethertype ARP (0x0806), length 60: Request who-has 1.2.3.1 tell 1.2.3.4, length 46
08:27:36.184422 05:C9:55:1E:86:FE > 00:24:54:ca:b0:ba, ethertype ARP (0x0806), length 42: Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE, length 28
08:27:36.258096 00:24:54:ca:b0:ba > Broadcast, ethertype ARP (0x0806), length 60: Request who-has 1.2.3.4 tell 0.0.0.0, length 46
08:27:37.256555 00:24:54:ca:b0:ba > Broadcast, ethertype ARP (0x0806), length 60: Request who-has 1.2.3.4 tell 0.0.0.0, length 46
08:27:38.255076 00:24:54:ca:b0:ba > Broadcast, ethertype ARP (0x0806), length 60: Request who-has 1.2.3.4 tell 0.0.0.0, length 46
08:27:39.253271 00:24:54:ca:b0:ba > Broadcast, ethertype ARP (0x0806), length 60: Request who-has 1.2.3.4 tell 1.2.3.4, length 46
08:27:39.762783 00:24:54:ca:b0:ba > Broadcast, ethertype ARP (0x0806), length 60: Request who-has 1.2.3.1 tell 1.2.3.4, length 46
08:27:39.762795 05:C9:55:1E:86:FE > 00:24:54:ca:b0:ba, ethertype ARP (0x0806), length 42: Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE, length 28
08:27:40.372230 00:24:54:ca:b0:ba > Broadcast, ethertype ARP (0x0806), length 60: Request who-has 1.2.3.1 tell 1.2.3.4, length 46
08:27:40.372242 05:C9:55:1E:86:FE > 00:24:54:ca:b0:ba, ethertype ARP (0x0806), length 42: Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE, length 28
08:27:42.372671 00:24:54:ca:b0:ba > Broadcast, ethertype ARP (0x0806), length 60: Request who-has 1.2.3.1 tell 1.2.3.4, length 46
08:27:42.372683 05:C9:55:1E:86:FE > 00:24:54:ca:b0:ba, ethertype ARP (0x0806), length 42: Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE, length 28
08:27:42.936064 00:24:54:ca:b0:ba > Broadcast, ethertype ARP (0x0806), length 60: Request who-has 1.2.3.1 tell 1.2.3.4, length 46
08:27:42.936076 05:C9:55:1E:86:FE > 00:24:54:ca:b0:ba, ethertype ARP (0x0806), length 42: Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE, length 28
08:27:43.047876 00:24:54:ca:b0:ba > Broadcast, ethertype ARP (0x0806), length 60: Request who-has 1.2.3.1 tell 1.2.3.4, length 46
08:27:43.047889 05:C9:55:1E:86:FE > 00:24:54:ca:b0:ba, ethertype ARP (0x0806), length 42: Reply 1.2.3.1 is-at 05:C9:55:1E:86:FE, length 28
Edited by tranger
Обмен трафика со внешкой происходит так:
05:C9:55:1E:86:FE > 04:D1:69:8D:35:FF
 00:24:54:ca:b0:ba > 05:C9:55:1E:86:FE
Роутер шлёт пакет на статический MAC, который я прописал в arp. Каким-то образом пакет долетает до тестового устройства и ответ следует уже от МАКа самого тестового устройства
Почему пакет уходит на 04:D1:69:8D:35:FF, а реально приходит на 00:24:54:ca:b0:ba?
Edited by tranger
Опишу всё ещё раз:
В sysctl.conf пишу:
sysctl -p
Если я воткну в сеть ноут с маком 00:24:54:ca:b0:ba и пропишу ip 1.2.3.4, я не должен иметь доступ к сети, пока мой мак не будет таким как я прописывал в arp.
Но нифига подобного, на ноуте есть внешка.
Причём в арп таблице мак ноута 00:24:54:ca:b0:ba не появляется.
tcpdump выдаёт такую картину:
05:C9:55:1E:86:FE - это роутер
04:D1:69:8D:35:FF - это мак, который я прописал в arp
00:24:54:ca:b0:ba - это ноут
Получается пакет с роутера летит на прописанный МАК, доходит до ноута с другим МАКом, а потом следует ответ с МАКа ноута на МАК роутера.
11 часов назад, tranger сказал:
Это делается на доступе. Например на длинках это называется
  IP-MAC-Port Binding (IMPB)
И вообще не стоит роутер в одной подсети с клиентами ставить. Если это не общажная локалка.
2 часа назад, BETEPAH сказал:
Зачем тогда придумали арп таблицу со статическими адресами?
В 27.02.2020 в 14:48, tranger сказал:
Каким-то непонятным образом начало работать. Отвлёкся по другим делам, через несколько часов решил продолжить, а всё работает...
Может кеш? После прописания нового МАС-а, кеш обнуляли?
В 26.02.2020 в 23:47, tranger сказал:
802.1x + радиус сервер вам в помощь.
Ваша привязка мака к ip просто смешной и неудобный костыль.
В 27.02.2020 в 14:34, tranger сказал:
Затем что бывает нужно иногда работать без ARP, или бывает что по какой то причине появляется ещё один компутер который анонсит тот же IP а подключится нужно очень сильно к одному конкретному.
А ещё есть юзкейсы когда арп кеш заполняется просто адресами из пролетающих мимо IP пакетов, без статических записей и без арп запросов.
Что касается ваших развлечений, то если какой то хост получает пакет с не его MAC адресом то не обязательно он его будет отбрасывать. И коммутатор тоже может слать пакеты или во все порты или в тот единственный где ещё есть линк, что в итоге и ломает вашу схему.
