ichthyandr Posted January 20, 2020 Posted January 20, 2020 Всем привет, есть девайс ASR1004 ASR1004#sh version Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.1(3)S, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2011 by Cisco Systems, Inc. Compiled Thu 21-Jul-11 22:41 by mcpre Есть просто netflow в main cache и есть aggregation as: ASR1004#sh ip flow export Flow export v9 is enabled for main cache Export source and destination details : VRF ID : Default Destination(1) X.Y.Z.W (9995) Version 9 flow records Cache for as aggregation v9 VRF ID : Default Destination(1) X.Y.Z.W (9996) 10189736203 flows exported in 357106096 udp datagrams 0 flows failed due to lack of export packet 0 export packets were sent up to process level 0 export packets were dropped due to no fib 0 export packets were dropped due to adjacency issues 0 export packets were dropped due to fragmentation failures 0 export packets were dropped due to encapsulation fixup failures 0 export packets were dropped enqueuing for the RP 0 export packets were dropped due to IPC rate limiting 0 export packets were dropped due to Card not being able to export main работает нормально, там собирается стата по адресам и портам, а as aggregation похоже не работает: ASR1004#sh ip cache flow aggregation as IP Flow Switching Cache, 0 bytes 5 active, 4091 inactive, 133 added 3011 ager polls, 0 flow alloc failures Active flows timeout in 45 minutes Inactive flows timeout in 200 seconds Src If Src AS Dst If Dst AS Flows Pkts B/Pk Active Po2.96 0 NULL 0 0 4287 46 1248.0 Po2.96 0 Po1.2 0 0 8572 454 1248.0 Po2.96 0 Po1.208 0 0 1626K 1038 2979.2 Po2.96 0 Po1.4 0 0 390K 1050 332.8 Po2.96 0 Local 0 0 78 163 1248.0 поля SRC/DST AS пустые, конфиг такой: ASR1004# sh run | b ip flow-aggregation cache as ip flow-aggregation cache as cache timeout inactive 200 cache timeout active 45 export version 9 export destination X.Y.Z.W 9996 enabled вобщем нужно мне стату по AS-кам собрать Вставить ник Quote
