Здравствуйте. Не получается настроить опцию 82 на коммутаторе, сетевая карта не получает адреса.
Вот конфиг свича нашего, подскажите что не так:
ip dhcp relay information option
ip dhcp snooping enable
ip dhcp snooping vlan XXXX
 ip dhcp snooping binding enable
 ip dhcp snooping information enable
 ip dhcp snooping information option allow-untrusted
vlan 1
vlan YYYY
 name MNGMNT_NEKR_YYYY
vlan XXXX
 name nekrasovka_park_opt82_XXXX
Interface Ethernet1/0/1
 switchport access vlan XXXX
 ip dhcp snooping binding user-control
 ip dhcp snooping binding user-control max-user 1
Interface Ethernet1/0/2
Interface Ethernet1/0/3
Interface Ethernet1/0/4
Interface Ethernet1/0/5
Interface Ethernet1/0/6
Interface Ethernet1/0/7
Interface Ethernet1/0/8
Interface Ethernet1/0/9
Interface Ethernet1/0/10
Interface Ethernet1/0/11
Interface Ethernet1/0/12
Interface Ethernet1/0/13
Interface Ethernet1/0/14
Interface Ethernet1/0/15
Interface Ethernet1/0/16
Interface Ethernet1/0/17
Interface Ethernet1/0/18
Interface Ethernet1/0/19
Interface Ethernet1/0/20
Interface Ethernet1/0/21
Interface Ethernet1/0/22
Interface Ethernet1/0/23
Interface Ethernet1/0/24
 switchport mode trunk
 switchport trunk allowed vlan YYYY;XXXX
 ip dhcp snooping trust vlan XXXX
Interface Ethernet1/0/25
Interface Ethernet1/0/26
Interface Ethernet1/0/27
Interface Ethernet1/0/28
interface Vlan1
interface VlanYYYY
 description MNGMNT_NEKR_YYYY
 ip address X.X.X.X 255.255.255.0
ip default-gateway X.X.X.254
no login
isolate-port group 1
captive-portal
end
Edited by snaky_85
Вот конфиг eltex 2124MB
console#sh running-config
ip dhcp relay enable
ip dhcp information option
ip dhcp snooping
ip dhcp information option format-type option bin
no spanning-tree
spanning-tree bpdu filtering
bridge multicast filtering
vlan database
 vlan ZZZZ,XXXX,YYYY
exit
ip igmp snooping
ip igmp snooping vlan XXXX
ip igmp snooping vlan YYYY
ip igmp snooping vlan YYYY mrouter interface gi1/0/25
ip igmp snooping vlan YYYY immediate-leave
ip igmp snooping vlan YYYY replace source-ip 192.168.80.100
ip arp inspection
ip arp inspection vlan XXXX
errdisable recovery interval 60
errdisable recovery cause loopback-detection
errdisable recovery cause stp-bpdu-guard
loopback-detection enable
username root password encrypted 5a1dc1dc45fd090a2df8a884f6cbc3f75a76a1ba privilege 15
username support password encrypted f51d6e51a462159e128ed59b18abdb5e6517e89d
snmp-server community encrypted dd878f2448b9e4287c rw view Default
interface gigabitethernet 1/0/1
 bridge multicast unregistered filtering
 storm-control broadcast enable
 storm-control broadcast level kbps 128
 switchport forbidden default-vlan
 switchport access multicast-tv vlan YYYY
exit
interface gigabitethernet 1/0/2
exit
interface gigabitethernet 1/0/3
exit
interface gigabitethernet 1/0/4
exit
interface gigabitethernet 1/0/5
exit
interface gigabitethernet 1/0/6
exit
interface gigabitethernet 1/0/7
exit
interface gigabitethernet 1/0/8
exit
interface gigabitethernet 1/0/9
exit
interface gigabitethernet 1/0/10
exit
interface gigabitethernet 1/0/11
exit
interface gigabitethernet 1/0/12
exit
interface gigabitethernet 1/0/13
exit
interface gigabitethernet 1/0/14
exit
interface gigabitethernet 1/0/15
exit
interface gigabitethernet 1/0/16
exit
interface gigabitethernet 1/0/17
exit
interface gigabitethernet 1/0/18
exit
interface gigabitethernet 1/0/19
exit
interface gigabitethernet 1/0/20
exit
interface gigabitethernet 1/0/21
exit
interface gigabitethernet 1/0/22
exit
interface gigabitethernet 1/0/23
exit
interface gigabitethernet 1/0/24
exit
interface gigabitethernet 1/0/25
 ip arp inspection trust
 switchport trunk allowed vlan add ZZZZ,XXXX,YYYY
exit
interface gigabitethernet 1/0/26
 switchport protected GigabitEthernet 1/0/25
exit
interface gigabitethernet 1/0/27
exit
interface gigabitethernet 1/0/28
exit
interface vlan ZZZZ
 name MNGMNT
exit
interface vlan XXXX
exit
interface vlan YYYY
 name NEKR_TV_YYYY
exit
Ворт часть конфига d-link
# DHCP_RELAY
disable dhcp_relay
config dhcp_relay hops 4 time 0
config dhcp_relay option_82 state disable
config dhcp_relay option_82 check disable
config dhcp_relay option_82 policy replace
config dhcp_relay option_82 circuit_id default
config dhcp_relay option_82 remote_id default
config dhcp_relay ports 1-26 state enable
# DHCP_LOCAL_RELAY
enable dhcp_local_relay
config dhcp_local_relay option_82 circuit_id default
config dhcp_local_relay option_82 remote_id user_define B8-A3-86-CE-4B-C0
config dhcp_local_relay vlan vlanid XXXX state enable
config dhcp_local_relay option_82 ports 1-26 policy keep
# NDP
# ROUTE
create iproute default X.X.X.254 1
# DHCPV6_LOCAL_RELAY
disable dhcpv6_local_relay
# RELAY6
config dhcpv6_relay hop_count  4
disable dhcpv6_relay
config dhcpv6_relay option_37 state disable check disable
config dhcpv6_relay option_37 remote_id default
config dhcpv6_relay option_18 state enable check disable
config dhcpv6_relay option_18 interface_id default
#             End of configuration file for DES-3200-26
