pprogra Posted October 24, 2019 Posted October 24, 2019 root@lio:/home/nfs# opkg install swap-utils_2.21.2-1_atheros.ipk Installing swap-utils (2.21.2-1) to root... Collected errors: * wfopen: //usr/lib/opkg/info/swap-utils.control: No space left on device. * wfopen: /sbin/mkswap: No space left on device. * wfopen: /sbin/swapon: No space left on device. * wfopen: /sbin/swaplabel: No space left on device. * extract_archive: Cannot create symlink from ./sbin/swapoff to 'swapon': No space left on device. * set_flags_from_control: Failed to open //usr/lib/opkg/info/swap-utils.control: No such file or directory. * pkg_write_filelist: Failed to open //usr/lib/opkg/info/swap-utils.list: No space left on device. * opkg_install_pkg: Failed to extract data files for swap-utils. Package debris may remain! * opkg_install_cmd: Cannot install package swap-utils. * opkg_conf_write_status_files: Can't open status file //usr/lib/opkg/status: No space left on device. root@lio:/home/# df root@lio:/home/# df -h Filesystem Size Used Available Use% Mounted on rootfs 960.0K 896.0K 64.0K 93% / /dev/root 1.8M 1.8M 0 100% /rom tmpfs 6.4M 52.0K 6.3M 1% /tmp tmpfs 512.0K 0 512.0K 0% /dev /dev/mtdblock3 960.0K 896.0K 64.0K 93% /overlay overlayfs:/overlay 960.0K 896.0K 64.0K 93% / 192.168.1.2:/home/ 12.9G 8.6G 3.7G 70% /home/ root@lio:/home/nfs# root@lio:/home/nfs# NFS примонтирован, но при запуске программ - пишет нет места. Получается 3.7 гига, как бы есть, но в тоже время нет. Вставить ник Quote
jffulcrum Posted October 24, 2019 Posted October 24, 2019 /etc/exports с сервера покажите Вставить ник Quote
pprogra Posted October 24, 2019 Author Posted October 24, 2019 (edited) /home/nfs/ *(rw,async,no_root_squash,no_subtree_check,insecure) или /home/ *(rw,async,all_squash,no_subtree_check,insecure) Edited October 24, 2019 by pprogra Вставить ник Quote
jffulcrum Posted October 24, 2019 Posted October 24, 2019 Вроде все нормально. Теперь на клиенте: /home/# df -i параллельно на сервере прогнать fsck на диск, где лежит шара. Вставить ник Quote
pprogra Posted October 24, 2019 Author Posted October 24, 2019 fsck from util-linux 2.34 e2fsck 1.45.3 (14-Jul-2019) fsck.ext2: Это каталог while trying to open /home/nfs The superblock could not be read or does not describe a valid ext2/ext3/ext4 filesystem. If the device is valid and it really contains an ext2/ext3/ext4 filesystem (and not swap or ufs or something else), then the superblock is corrupt, and you might try running e2fsck with an alternate superblock: e2fsck -b 8193 <device> or e2fsck -b 32768 <device> root@r:/etc/init.d# df -i / Файловая система Iнодов IИспользовано IСвободно IИспользовано% Cмонтировано в /dev/sda7 864960 380869 484091 45% / но пока, не работает Вставить ник Quote
jffulcrum Posted October 24, 2019 Posted October 24, 2019 маловероятно, но: покажите rpcinfo на серверве и на клиенте Вставить ник Quote
pprogra Posted October 24, 2019 Author Posted October 24, 2019 program version netid address service owner 100000 4 tcp6 ::.0.111 portmapper superuser 100000 3 tcp6 ::.0.111 portmapper superuser 100000 4 udp6 ::.0.111 portmapper superuser 100000 3 udp6 ::.0.111 portmapper superuser 100000 4 tcp 0.0.0.0.0.111 portmapper superuser 100000 3 tcp 0.0.0.0.0.111 portmapper superuser 100000 2 tcp 0.0.0.0.0.111 portmapper superuser 100000 4 udp 0.0.0.0.0.111 portmapper superuser 100000 3 udp 0.0.0.0.0.111 portmapper superuser 100000 2 udp 0.0.0.0.0.111 portmapper superuser 100000 4 local /run/rpcbind.sock portmapper superuser 100000 3 local /run/rpcbind.sock portmapper superuser 100005 1 udp 0.0.0.0.160.99 mountd superuser 100005 1 tcp 0.0.0.0.152.167 mountd superuser 100005 1 udp6 ::.139.104 mountd superuser 100005 1 tcp6 ::.228.225 mountd superuser 100005 2 udp 0.0.0.0.235.220 mountd superuser 100005 2 tcp 0.0.0.0.174.119 mountd superuser 100005 2 udp6 ::.225.116 mountd superuser 100005 2 tcp6 ::.156.125 mountd superuser 100005 3 udp 0.0.0.0.172.163 mountd superuser 100005 3 tcp 0.0.0.0.198.173 mountd superuser 100005 3 udp6 ::.189.21 mountd superuser 100005 3 tcp6 ::.205.147 mountd superuser 100003 3 tcp 0.0.0.0.8.1 nfs superuser 100003 4 tcp 0.0.0.0.8.1 nfs superuser 100003 3 udp 0.0.0.0.8.1 nfs superuser 100003 3 tcp6 ::.8.1 nfs superuser 100003 4 tcp6 ::.8.1 nfs superuser 100003 3 udp6 ::.8.1 nfs superuser 100021 1 udp 0.0.0.0.135.159 nlockmgr superuser 100021 3 udp 0.0.0.0.135.159 nlockmgr superuser 100021 4 udp 0.0.0.0.135.159 nlockmgr superuser 100021 1 tcp 0.0.0.0.171.209 nlockmgr superuser 100021 3 tcp 0.0.0.0.171.209 nlockmgr superuser 100021 4 tcp 0.0.0.0.171.209 nlockmgr superuser 100021 1 udp6 ::.215.211 nlockmgr superuser 100021 3 udp6 ::.215.211 nlockmgr superuser 100021 4 udp6 ::.215.211 nlockmgr superuser 100021 1 tcp6 ::.129.233 nlockmgr superuser 100021 3 tcp6 ::.129.233 nlockmgr superuser 100021 4 tcp6 ::.129.233 nlockmgr superuser на клиенте не работает. на клиенте rpcinfo нет. Вставить ник Quote
jffulcrum Posted October 24, 2019 Posted October 24, 2019 Я даже не знаю, все выглядит нормально. А проверьтесь-ка на https://blog.merovius.de/2013/10/20/ext4-mysterious-no-space-left-on.html В принципе, народ, при определенной удаче, ловил уже на 20000 файлов. Вставить ник Quote
pprogra Posted October 26, 2019 Author Posted October 26, 2019 root@OpenWrt:~# df Filesystem 1K-blocks Used Available Use% Mounted on rootfs 960 896 64 93% / /dev/root 1792 1792 0 100% /rom tmpfs 6544 52 6492 1% /tmp tmpfs 512 0 512 0% /dev /dev/mtdblock3 960 896 64 93% /overlay overlayfs:/overlay 960 896 64 93% / root@OpenWrt:/sbin# df -h Filesystem Size Used Available Use% Mounted on rootfs 960.0K 896.0K 64.0K 93% / /dev/root 1.8M 1.8M 0 100% /rom tmpfs 6.4M 336.0K 6.1M 5% /tmp tmpfs 512.0K 0 512.0K 0% /dev /dev/mtdblock3 12.9G 8.6G 3.7G 70% /overlay overlayfs:/overlay 960.0K 896.0K 64.0K 93% / 192.168.1.2:/home/nfs/ 12.9G 8.6G 3.7G 70% /overlay cd /overlay root@OpenWrt:/overlay# opkg install libcap_2.22-1_atheros.ipk Installing libcap (2.22-1) to root... Collected errors: * wfopen: //usr/lib/opkg/info/libcap.control: No space left on device. * extract_archive: Cannot create symlink from ./usr/lib/libcap.so to 'libcap.so.2': No space left on device. * wfopen: /usr/lib/libcap.so.2.22: No space left on device. * extract_archive: Cannot create symlink from ./usr/lib/libcap.so.2 to 'libcap.so.2.22': No space left on device. * set_flags_from_control: Failed to open //usr/lib/opkg/info/libcap.control: No such file or directory. * pkg_write_filelist: Failed to open //usr/lib/opkg/info/libcap.list: No space left on device. * opkg_install_pkg: Failed to extract data files for libcap. Package debris may remain! * opkg_install_cmd: Cannot install package libcap. * opkg_conf_write_status_files: Can't open status file //usr/lib/opkg/status: No space left on device. установка программ не получается нет места - это 3.7 гига . В сети пишут, что всё работает. Права разные? Операционка примотируемую часть "за свою не признаёт". Вставить ник Quote
DDR Posted October 27, 2019 Posted October 27, 2019 Вы точно df -i на клиенте/Openwrt запускали? Откуда там /dev/sda7 Вставить ник Quote
pprogra Posted October 27, 2019 Author Posted October 27, 2019 root@OpenWrt:~# df -i df: invalid option -- i BusyBox v1.19.4 (2013-03-14 17:30:13 UTC) multi-call binary. Usage: df [-Pkmh] [FILESYSTEM]... Print filesystem usage statistics -P POSIX output format -k 1024-byte blocks (default) -m 1M-byte blocks -h Human readable (e.g. 1K 243M 2G) клиент не потдерживает это значение, где то может не добавил слеш иои наоборот какая -та ошибка. Вставить ник Quote
pprogra Posted October 27, 2019 Author Posted October 27, 2019 (edited) Скрытый текст первый пакет сообщение о нехватке места нет. root@OpenWrt:/sbin# df -h Filesystem Size Used Available Use% Mounted on rootfs 960.0K 896.0K 64.0K 93% / /dev/root 1.8M 1.8M 0 100% /rom tmpfs 6.4M 52.0K 6.3M 1% /tmp tmpfs 512.0K 0 512.0K 0% /dev /dev/mtdblock3 12.9G 8.6G 3.7G 70% /overlay overlayfs:/overlay 960.0K 896.0K 64.0K 93% / 192.168.1.2:/home/nfs/ 12.9G 8.6G 3.7G 70% /overlay root@OpenWrt:/sbin# cd /overlay root@OpenWrt:/overlay# ls lible-ng1.1_atheros.ipk root@OpenWrt:/overlay# opkg install lible-ng1.1_atheros.ipk Installing lib-ng (1.1) to root... Collected errors: * satisfy_dependencies_for: Cannot satisfy the following dependencies for lible-ng: * lible1.1 * * opkg_install_cmd: Cannot install package lible-ng1.1_atheros.ipk. ну вот ставить стал дополнительный авкет по требованию и вот сообщение не понятно откуда двойной слеш? При этом повторю установка пакета 1 не сообщала нет места, только нехватка пакетов. root@OpenWrt:/overlay# opkg install lib1e-1_atheros.ipk Installing lible(1e-1) to root... Collected errors: * wfopen: //usr/lib/opkg/info/libo.control: No space left on device. * wfopen: /usr/lib/libcrypto.so.1.0.0: No space left on device. * set_flags_from_control: Failed to open //usr/lib/opkg/info/lible.control: No such file or directory. * pkg_write_filelist: Failed to open //usr/lib/opkg/info/lible.list: No space left on device. * opkg_install_pkg: Failed to extract data files for lible. Package debris may remain! * opkg_install_cmd: Cannot install package lible. * opkg_conf_write_status_files: Can't open status file //usr/lib/opkg/status: No space left on device. ну вот ставить стал дополнительный авкет по требованию и вот сообщение не понятно откуда двойной слеш? При этом установка пакета 1 не сообщала нет места, только нехватка пакетов. Edited October 27, 2019 by pprogra Вставить ник Quote
pprogra Posted October 28, 2019 Author Posted October 28, 2019 root@OpenWrt:/sbin# mount rootfs on / type rootfs (rw) /dev/root on /rom type squashfs (ro,relatime) proc on /proc type proc (rw,noatime) sysfs on /sys type sysfs (rw,noatime) tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime) tmpfs on /dev type tmpfs (rw,noatime,size=512k,mode=755) devpts on /dev/pts type devpts (rw,noatime,mode=600) /dev/mtdblock3 on /overlay type jffs2 (rw,noatime) overlayfs:/overlay on / type overlayfs (rw,relatime,lowerdir=/,upperdir=/overlay) debugfs on /sys/kernel/debug type debugfs (rw,relatime) 192.168.1.2:/home/nfs/ on /usr/nfs type nfs (rw,relatime,vers=3,rsize=131072,wsize=131072,namlen=255,hard,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.2,mountvers=3,mountport=53051,mountproto=udp,local_lock=all,addr=192.168.1.2) монтирование с опцией -o nolock получаем local_lock=all, в роликах на ютубе там local_lock-none. Может в этом ошибка и как исправить. Вставить ник Quote
pprogra Posted November 1, 2019 Author Posted November 1, 2019 (edited) Collected errors: * wfopen: //usr/lib/opkg/info/lib.control: Read-only file system. opkg.conf возможно настроить так, что бы пакеты ставил на примонтированую директорию? Почему файлы запускаются документы и фильмы например, но программы ни в какую? Никто выходит не использовал nfs как полноценное продолжение операционки? Edited November 1, 2019 by pprogra Вставить ник Quote
